Soulriders 4.0: Row, Row, Fight Da Powa
September 06, 2010, 04:36:49 am *
Welcome, Guest. Please login or register.
Did you miss your activation email?
Login with username, password and session length
News: "He's not fancy city boy, with fancy expertise, and all those fancy new temperature measuring devil machines."
   Home   Help Search Login Register
Pages: [1]
  Print
Author Topic: Dreams of Battle(Combat Stats)  (Read 250 times)
Gatewalker
Moderator
Surface Dweller
Offline Offline
THIS PAW OF MINE IS BURNING RED!
« on: February 23, 2009, 06:40:39 pm »
Alright, here's where we have a basic summary of combat, and where I'll be keeping people's quick and simple combat numbers you need to know.
This is a work in progress, of course.
Combat Flow
1: Initiative
Because this is on IRC and thus goes a bit slower then in person games, we roll Init once and use that order thereafter. Makes thing a bit less dynamic, but rolling init every round will bog down an IRC game.
2: Action
Simple here. When your turn comes around, you decide on an action. This can be an attack, a non combat action, whatever.
2.5: Hold
You can also hold your action and choose to act on a lower init.
3: Attack/Defense Phase
This is where rolling gets nutsy.
To attack, you roll 2d8 and compare the number to your ACV(which gets modified by various stuff). If what you roll is LOWER then your modified ACV, you hit. If it's higher, you miss. Also a natural roll of 2 is a Critical Hit which cannot be negated by the opponent's defense check, while a natural roll of 16 is a complete miss and no amount of modifiers can save you.
When someone is successfully attacked, they get to make a defensive roll. There are 3 kinds of defenses.
Dodge/Parry Defense: Avoids the attack entirely. Roll 2d8 and check against your DCV(with modifiers, yadda, yadda). Roll under and you dodge.
Block Defense: Only usable if you have something to block with. Roll 2d8 and check against your DCV+2(and additional mods). However, does not avoid the damage entirely, but reduces it by the Armor value of whatever you blocked with.
Attribute Defense: Really just a fancy version of Dodge/Parry Defense using an Attribute that could be argued to let you avoid the attack(Teleport is the classive example). Same as D/P Defense, you roll 2d8 and check against your DCV.
Multiple Defenses: Every Defense you take in a round after the first suffers a cumulative -4 penalty to your DCV. So if you have a DCV of 8 and you dodge once, then try to dodge again in the same round, you have to roll against a 4 instead of an 8. A third time and you have to roll agianst a 0(meaning natural 2 or bust).
4: Damage
Damage is it's own can of worms. Whenever you land an attack, you roll 2d8 to determine damage, as per the following:
2-4=100% Damage
5-8=75% Damage
9-13=50% Damage
14-16=25% Damage
Your ACV is added to the final damage, AFTER the roll. No worries on doing these calcs though, I'll have that all taken care of in your individual posts after this one.
Logged
All About Monks
<Marisa> They're OP as fuck
<Marisa> just by being monks
Gatewalker
Moderator
Surface Dweller
Offline Offline
« Reply #1 on: February 23, 2009, 07:12:04 pm »
Mykasi's Combat Information
HP: 70
EP: 95
ACV: 9
DCV: 10
Attacks
Naginata Stab: 10/8/5/3 +9, Physical Damage
Anvil of Light: 60/45/30/15 +9, Light Damage
Ghost Waltz: 20/15/10/5 +9, Light Damage
Linked to Illusions. If the targets fail thier check to disbelieve the illusions, Mykasi can damage them without needing an attack roll.
Cold As Ice: 60/45/30/15 +9, Ice Damage
Defenses
Extra Defenses 1 (Mike may make 2 DCV rolls per round before taking penalties)
Weakness to Fire attacks.
« Last Edit: April 29, 2010, 06:52:06 pm by Gatewalker » Logged
All About Monks
Gatewalker
Moderator
Surface Dweller
Offline Offline
« Reply #2 on: February 23, 2009, 07:23:04 pm »
Hikari's Combat Information
HP: 105
EP: 75
ACV: 9
DCV: 8
Special Ranged Attack combat skill: 1
Melee Attack combat skill: 1
Attacks
Bow Shot: 10/7/5/3 +9, Physical Damage
Golden Lightblade: 40/30/20/10 +19, Physical Damage.
Roll vs 10
Melee Range, Muscle powered
Helreio Brynhildar: 60/45/30/15 +9, Physical Damage
Roll vs 10(Special Ranged Attack)
Effect Incorporeal Opponents
Betrayal: 20/15/10/5 +9, Physical Damage
Reduces target's Body stat by 2.
Firewall: 40/30/20/10 +9, Fire Damage
Burns 10 EP/use
Defenses
Physical Armor: 15
Weakness to Dark attacks.
« Last Edit: July 29, 2010, 08:45:18 pm by Gatewalker » Logged
All About Monks
Gatewalker
Moderator
Surface Dweller
Offline Offline
« Reply #3 on: February 23, 2009, 07:37:02 pm »
Valeriya's Combat Information
HP: 80
EP: 80
ACV: 8
DCV: 6
Attacks
Fallen Cry: 20/15/10/5 +8, Almighty Damage
Ignores 30 points of Armor
Deals equal damage to HP and EP
Forgotten Night: No Damage
Attack Roll checks against ACV+2 to hit
Target must check against Soul+1 or be killed/knocked out.
Volt Spire: 40/30/20/10 +8, Electric Damage
Covers a 3 Meter(roughly 9ft) radius.
Defenses
Electric Armor: 40
Wind Armor: 40
Logged
All About Monks
Gatewalker
Moderator
Surface Dweller
Offline Offline
« Reply #4 on: November 19, 2009, 10:10:05 pm »
Nagare's Combat Information
HP: 75
EP: 90
ACV: 8
DCV: 6
Attacks
The Lying Prince: 40/30/20/10 +8, Dark Damage
Roll vs 9
Reduces Target's Soul stat by 2
Burns 10 EP/use
Summon Lilim - Sealing Kiss: 20/15/10/5 +8, Dark Damage
Roll vs 9
Does no damage to targets HP. Damage applies to EP instead.
Defenses
Universal Armor: 10
Dark Armor: 20(so reduces Dark by 30)
Weakness to Light attacks.
« Last Edit: January 28, 2010, 10:07:57 pm by Gatewalker » Logged
All About Monks
Gatewalker
Moderator
Surface Dweller
Offline Offline
« Reply #5 on: April 29, 2010, 06:42:20 pm »
Shiro's Combat Information
HP: 140
EP: 75
ACV: 9
DCV: 7
Unarmed/Melee Attack Skill: 2
Unarmed/Melee Defense Skill: 2
Attacks
Fengjia(Wind Ride): 80/60/40/20 +19 Wind Damage
Roll vs 11.
Melee Range, Muscle Powered
Can only be used with Leap Attack. Requires a spear/polearm type weapon to use.
Qinglong yanyue daodeyun(Blue Dragon Rushing Spear): 40/30/20/10 +9 Physical Damage
Roll vs. 11
Melee Range, "Autofire"
Cannot move and use this attack in the same round. Requires a spear/polearm type weapon to use.
Baofengyu zasi(Tempest Crash): 60/45/30/15 +19 Wind Damage
Roll vs 11
Knockback: Sends target flying back 1 meter(~3 feet) for every 2 points of damage inflicted.
Spear stab: 10/7/5/2 +19 Physical Damage
Roll vs 11
Defenses
Physical Armor: 15
Light/Dark Armor: 20
Regeneration: Heal 5hp/minute
« Last Edit: July 30, 2010, 12:52:50 am by Gatewalker » Logged
All About Monks
Pages: [1]
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
