Author Topic: DM Nagging: It's pretty much my job  (Read 55599 times)
Online Iron Dragoon
  • Duke
  • Tarrasque
  • And One Rogue.
Re: DM Nagging: It's pretty much my job
« Reply #2085 on: May 20, 2019, 08:41:38 pm »
Water-blasting
Transmutation/Conjuration [Water, Earth]
Level: Drd 8, Sor/Wiz 8
Components: V, S, M.
Target: 1 creature
Duration: Concentration; up to 1 round/level
Saving Throw: Reflex half; see text
Spell Resistance: Yes
Opening a tiny portal to the plane of Water you summon a jet of water, pressurized by all the weight of the plane. When this jet passes through your portal, small grains of Sand are called into it increasing the abrasive damage of it. The caster must succeed on a ranged touch attack to hit the target, and this jet deals 1d6 damage per caster level (maximum of 15d6) per round to the target and knocks it prone, a successful reflex save halves this damage and prevents the knock down.
Any creature wither the Water or Earth sub-type takes half damage from this spell, while Constructs and objects take double damage.
Material Component
A small jar of water and sand.
Process: Attempting to Give a Shit
║█████░░░░░░░░░░░░░░░░░░░░░░║ (25%)
Estimated Time Until Completion : FATAL RUN TIME ERROR
"Whenever I'm about to do something, I think, 'Would an idiot do that?' And if they would, I do not do that thing."
Online Anastasia
  • Erin
« Reply #2086 on: May 20, 2019, 09:00:02 pm »
That's about right, I'll check some things and get back to you on it.
Online Nephrite
  • Tarrasque
  • -This guy!-
« Reply #2087 on: May 20, 2019, 09:06:24 pm »
Greater Mana Flux
Abjuration
Level: Cleric 10, Sorc/Wiz 10
Components: V, S,
Area: 40-ft.-radius emanation centered on a point in space
Duration: 1 round/level
Spell Resistance: No
This spell functions as Mana Flux, except as noted here. The chance for failure increases to 50%.
Online Iron Dragoon
  • Duke
  • Tarrasque
  • And One Rogue.
« Reply #2088 on: May 21, 2019, 12:57:48 am »
Would Emily know the Dragon Princess spells from Surraruthru to teach Alyssa?
Offline Corwin
  • Tarrasque
  • No matter how evil the tactics... a win is a win~
« Reply #2089 on: May 21, 2019, 09:17:58 am »
I don't see why not, they're not a secret of the faith or anything.
Online Anastasia
  • Erin
« Reply #2090 on: May 21, 2019, 10:46:35 am »
Pretty much this.
Online Nephrite
  • Tarrasque
  • -This guy!-
« Reply #2091 on: May 22, 2019, 12:15:25 pm »
I donít mean to nitpick, but I donít think Mooreís group has actually ever met Latha except vaguely in B3 unless I am misremembering.
Itís not a big deal or anything!
Online Anastasia
  • Erin
« Reply #2092 on: May 22, 2019, 12:59:18 pm »
I think she did, but it was in a topic in another node and I'd have to dig it up. I'll check once I'm done with this Iddy post.
Online Iron Dragoon
  • Duke
  • Tarrasque
  • And One Rogue.
« Reply #2093 on: May 23, 2019, 02:07:25 am »
Throwing this up because I feel like there needs to be something between 8 and 14 for this sort of perception type deal.
Archmage's Prying Eyes
Divination
Level: Sor/Wiz 11
Components: V, S
Casting Time: 1 minute
Range: One mile
Effect: Ten or more levitating eyes
Target: Personal
Duration: 1 hour/level
This spell functions exactly as Prying Eyes, Greater except the eyes report what they see as the spell Telepathic Bond, limiting the number of eyes to 1d4+1 per 3 caster levels (to a maximum of +6).
The target is never flatfooted. The eyes gain a Hide modifier equal to the target's Caster Level. The eye's maximum Spot modifier is +35 instead of +25.
Online Anastasia
  • Erin
« Reply #2094 on: May 23, 2019, 12:22:58 pm »
Water-blasting
Target: 1 creature
Material Component
Yeah, that's fine and worth trying.
Online Anastasia
  • Erin
« Reply #2095 on: May 23, 2019, 12:28:25 pm »
It's now in the spell collection.
Online Anastasia
  • Erin
« Reply #2096 on: May 23, 2019, 12:35:07 pm »
Greater Mana Flux
Abjuration
Components: V, S,
I'm tentatively rejecting this one, since I have to do a lot of homework on it and make some decisions. This no may become a yes over the weekend, but for now I'm punting it with an expectation it'll be rejected.
I'll get back to you on this by Monday.
Online Anastasia
  • Erin
« Reply #2097 on: May 23, 2019, 12:44:21 pm »
Prying eyes tonight, it's a bit beyond the time I have to sort into all of that.
Adding this to the spell collection.
Balor Lord Nimbus
Transmutation [Fire]
Level: Clr 6, Sor/Wiz 6
This spell is identical to balor nimbus, except as noted here. The fire damage you deal to any creature grappling you rises to 10d6 and you gain a +4 bonus to grapple checks.
Offline Corwin
  • Tarrasque
« Reply #2098 on: May 24, 2019, 06:32:59 pm »
Spell question. I've been thinking Disintegrating Burst was from this source. The Spell Compendium has Disintegrating Burst that does the regular Disintegrate damage on a passed save (5d6), not 8d6. Is that correct?
Online Anastasia
  • Erin
« Reply #2099 on: May 24, 2019, 06:36:17 pm »
It's not. It's from...I believe Imix's writeup, though it was used before by others, it's not remotely exclusive to him.
Disintegrating Blast
Transmutation
Level: Duskblade 12, Sor/Wiz 12
Range: 100ft
Area: 100ft radius burst centered on you
This spell is identical to disintegrating burst, except as noted here. This spell can inflict a maximum of 60d6 damage (8d6 on a successful save).
Transmutation
Level: Duskblade 9, Sor/Wiz 9
Range: 20ft
Area: 20ft radius burst centered on you
This spell is identical to disintegrate, except as noted here. All creatures and unattended objects (except yourself and your familiar) are affected by a disintegrate spell. You do not need to make ranged touch attacks against the creatures in the burst, though spell resistance and the Fortitude saving throw still apply.
A case of same idea, same name but not the same thing. I wasn't aware of that spell until now.
