Lady Sanzha reaches level 34.
- Marid 34 and Madalani 10.
- Maximum hit points per hit die, for a total of 18 hit points and a grand total of 612 hit points.
- +1 BAB for a total of +34.
- Channel elements DC rises by 1.
- Spell resistance rises by 1 to 45.
- Damage reduction rises by 5 to 25, gains the axiomatic property.
- Gains melody of water (rise). A nice booster.
- Wish SLA now can be used 2/day.
- Gains 32nd level bard casting. She'll grab sensual blessing because it's really solid.
- No change to saves.
- All skills go up as normal.
Okay enough level, solid.
Kascha reaches level 34.
- Ghaele 34 and Wyrm Wizard 24.
- Max hit points per hit die for a total of 19 hit points and a grand total of 649 hit points.
- +1 spell resistance for a total of 49.
- Gains another draconic discovery. She takes Syala's Blessing from druid 14.
- Gains 34th level wizard casting. Her new 14th level spell slot goes to Syala's Blessing.
- Skills go up as normal.
Pretty solid level for her.
Elle reaches level 34.
- Wizard 34 and Dragon Disciple 24.
- Max hit points per hit die for a total of 25 hit points and a grand total of 826 hit points.
- +1 BAB for a total of +24.
- School mastery for evocation rises by 1.
- Gains 34th level casting and a bonus spell. For now this is just another radiant storm and triple boom. I'm going to tweak her spells for twin as a later todo.
Okay level, but boring as anything.
Donald reaches level 34.
- Duskblade 34 and Dragon Disciple 14.
- Max hit points per hit die, for a total of 26 hit points and a grand total of 842 hit points.
- Gains 34th level duskblade casting.  He'll go with Asgeroth's Groundbreaker.
- His new feat is Great Ability(Strength)(D14). This is meant to unlock pulverize later.
Okay enough level.
Words of Creation, can, at its base, be used on most of the bardic musics.
Inspire Excellence is not included in this, and that makes sense, as it's an epic feat.
Would you see some other feat (or something) being allowed to ...uh, allow, WoC to work on Inspire Excellence? I was thinking either another epic feat or something like that, but I wasn't sure if you'd even want to go down that road at all.
You'd have to investigate IC if it's possible.
Ranbar reaches level 34.
- Cloistered Cleric 34 and Perfectus 24.
- Max hit points per hit die for a total of 21 hit points and a grand total of 704 hit points.
- +1 BAB for a total of +23.
- Spell resistance rises by 1 to 49.
- Lore rises by 1 to 46.
- Gains 34th level cleric spellcasting. Ranbar'll go with greater divine power again for now, since a spell rework and adjustment is a todo. No sense sweating it when I'm going in there soon enough.
Off level, but with a lot to tweak that's okay.
Today's new spell:
Waters of Lunia
Evocation [Good, Water]
Level: Sanctified 11
Components: V, S, Sacrifice
Area: 10ft/level radius spread
Duration: Instantaneous
Spell Resistance: Yes
When this spell is cast, a great wave of the holy waters from Lunia spread out and purge any evil it touches. Evil creatures suffer 20d6 points of damage. Additionally, any evil divine caster damaged by the waters loses 7 divine prepared spells or spell slots, as if they were expended. Highest level spells are lost first, this is otherwise identical to losing spells by negative levels. A successful Fortitude save halves the damage and negates the spell loss.
Spell slots or prepared spells lost by this spell can be regained normally.
Sacrifice
1d4 points of Strength damage.
The previous spell is now in the Spell Collection. This one I could use a few opinions on, let me know what you think.
Crystalle's Barrage
Evocation
Level: Sor/Wiz 12
Components: V, S, M
Targets: 3 creatures a round; see text
Duration: 1 round/level
When you cast this spell, you are surrounded with one sphere per three caster levels (maximum 15 spheres). Each sphere is a smooth crystal about 10 inches in diameter. Each round on your turn as a standard action, you can send up three spheres at creatures within range of the spell. You can send the spheres at the same target or divide them up between multiple targets. Each sphere requires a ranged touch attack to strike their target. On impact the spheres shatter, dealing 10d6 points of piercing damage per sphere. There is no saving throw allowed, but damage reduction applies. The spheres count as piercing and epic to overcome damage reduction.
For every two spheres the caster is surrounded by, they gain a +1 shield bonus to armor class. A sphere can be sundered, each sphere has an armor class of 20, hardness 10 and 20 hit points.
Unused spheres vanish when the spell expires.
Material Component
A small fragment of quartz.
Cor, I have a todo about your loot. Refresh me on what that is so I'm clear? Any others if any are pending too.
DM work update:
- Added a new spell to the Spell Collection, Waters of Lunia. This accomplished one part of the fill out Xandra's spell list todo.
- Posted another spell for commentary and feedback, Crystalle's Barrage.
- Tweaked and adjusted Elle's spells for twin. Mostly swaps since she's primarily an offensive mage.
- Finished Alicia's spoiler block update, Seira'n'Moore in the morning.
- Posted a question for Cor about his item todo, get that cleared out in the morning.
Morning should be spoiler blocks, Cor response if he's responded by then and either more sun domain, Ranbar spells or Xandra spells. We'll see where I'm at tomorrow morning before session.
Quote from: Anastasia on August 22, 2019, 02:39:42 AM
1) http://www.soulriders.net/forum/index.php/topic,104121.msg1153310.html#msg1153310
2) Could I get the daoin information from the dao? I'd like to do something about the daoin ring, and this was part of the peace settlement with the dao.
3) http://www.soulriders.net/forum/index.php/topic,104121.msg1149208.html#msg1149208
Let's say that I get the choker, Honeydip gets the sword while I throw the orb into a vault fo rnow. Just want to settle this already.
Spoiler blocks updated for all three leveled up nodes. Alyssa and Tryll as level ups happen and events warrant.
1 and 3 are answered. Let me know if I missed anything due to the time delay, in case I did a stupid.
Quote2) Could I get the daoin information from the dao? I'd like to do something about the daoin ring, and this was part of the peace settlement with the dao.
Sure. Refresh me on the agreement real quick?
