Survivors
Started by Anastasia, December 03, 2018, 12:35:37 PM
And scrambled, you'd imagine, yes.
How about just dispelling them, then, or an unbinding? Yes, I am going to be very technical about this!!
Give me another Spellcraft check.
Take 10 for 66! Actually, let's use some GI points, and make it 82. :)
It's expertly designed - it would indeed trigger on dispelling it or the like. It's very completely and thoroughly enchanted. Perhaps only suitable for an abjurer.
Moore pinches his brow.
Then he snaps his fingers and grins.
How about if someone was affected by dimensional anchor?
You'd imagine the dimensional anchor would stop the teleport, based on your arcane knowledge.
"Nice try." Moore murmurs. He taps himself once.
I'm assuming I can just auto-fail the check for this, so I am now affected by Dimensional Anchor.
"Now then..." He says as he gestures.
Unbinding, assuming that that would, in fact work on them from the previous checks. If Unbinding wouldn't work then let me know and I'll anchor Xandra instead.
Sure enough, the barriers come down as the rest of the party watches. "Onward," Cresiel agrees, "Less time for him to prepare or escape."
"Just remind me to remove this later." Moore says. He tries the door north, first!
Ahead is a short hall with one problem. A cloud of floating knives, wet-looking and vast, blocks the way. It's hovering in place, the center of it a floating red gem. The moment it sees Moore, it lunges at him.
Init.
What in the world is 'wet-looking'?
[14:28] <Nephrite> roll 1d20+40 Moore init
[14:28] <Penuche> Nephrite invokes Penuche's magic: < 55 > [d20=15]
[14:28] <Nephrite> roll 1d20+30 Cresiel Init
[14:28] <Penuche> Nephrite invokes Penuche's magic: < 34 > [d20=4]
[14:28] <Nephrite> roll 1d20+21 Xandra
[14:28] <Penuche> Nephrite invokes Penuche's magic: < 23 > [d20=2]
[14:28] <Nephrite> roll 1d20+20 Jetina
[14:28] <Penuche> Nephrite invokes Penuche's magic: < 39 > [d20=19]
AS in wet. Beads of moisture are gathering on it. Like someone dipped them in water or some sort of clear liquid.
> roll 1d20+12 knives
<Penuche> Kotono invokes Penuche's magic: < 29 > [d20=17]
Init is Moore (55) > Jetina (39) > Cresiel (34) > Knives (29) > Xandra (23)
Open Moore.
Can I take a quick Spellcraft for 66 or K:A for 90 to identify if this is, mm, basically, is this an animated set of knives or some sort of construct in and of itself?
You'd think it's just a construct or animated objects, but that gem in the center is suspect. If you had to guess, it's some of control or overmind for it, perhaps even making it a golem.
