Moving on
Started by Anastasia, December 03, 2018, 12:41:47 PM
"Well, that was unexpected. But another point we can use to study. Ready?"
Jarem smiles - really smiles - and adds, "Yeah, I'm ready," he says. "Do it."
Alyssa begins casting!
Visions of the Past, CL 32
Target: Alyssa (Jarem accompanying)
When you cast this spell, you are able to relive your past or the past of a touched creature. An unwilling creature requires a successful melee touch attack and is allowed a Will save to negate.
This spell allows you to relive up to one hour per caster level of the target's life. This may be any time you see fit, but must be one unbroken block of time. You may also share this spell with up to one creature per four caster levels, all creatures affected must within 30ft of you. Those who relive the past do so instantly, experiencing everything the target did in all of the target's senses (including senses those who relive the past do not normally possess). For all purposes, it is as if the creatures lived the experiences themselves.
While the memories are completely lifelike, those who relive the past do not suffer any ill effects from it (except for any trauma the memories would cause naturally, such as viewing the memories of a creature being tortured).
What memories are you giving him?
The feeling of the bond activating for him, Emily, and Ianvasah, the last few times. I don't recall specifics off hand.
"It feels about the same," Jarem says after the memories are passed over. He glances down at himself then slowly rubs his side, "Also, another person's memories are strange."
"I can imagine. Well, at least we've verified that there's no real differences between each, so it works the same with everyone. That simplifies things, though not in a major way."
"Anyway, I'll work on it," Jarem says, "Going to work on the land now?"
"Yes. Next big step of the plan."
Okay, so what ya doin' here?
Well, I figure I ha e enough ranks in K: Engineering and K: Geography to plan the placement well enough, but I want to consult with Ianvasah and one of Jarem's siege engineers for their input on it. What we haven't discussed is size/amount type stuff, and if I can magically engineer different climares for different cultivation, or if that's even needed.
Climate will be that of the prevailing region, unless altitude effects it (mountains for example). Otherwise the spell creates islands - usually simple beaches, jungle and then a mountain in the center.
Alright, well just figuring out placement then.
What I'd like you to do is make a rough sketch of the archipelago your guild has and how you want to expand it. I think a visual aid would be profoundly useful. Do you think that's something you could do? Be it by stick figures, paint, a graph, whatever.
I can figure something out, but it won't be possible until I get home.
