Date night
Started by Anastasia, June 11, 2019, 01:05:31 PM
"That was lovely," Alicia says, Marie taking notes for her own performances. A gate is opened and they pass through, arriving on Earth in a tunnel close to that toxic enclosed lake.
Alicia: 772+20/772
Active spells: Many moments of prescience (CL 33), extended mind blank (CL 33), extended nondetection (CL 33), sensual blessing (CL 33), epic mage armour (CL 33), recitation (CL 33), greater heroism (CL 33), repelling shield (CL 33), spell turning (CL 33), dance of the unicorn (CL 33), foresight (CL 33), vision of the omniscient eye (CL 33), extended ray deflection (CL 33), telepathic bond (CL 33)
Defences: AC 96, CMD 107, spell resistance 48, energy immunity (fire and cold), status immunity (polymorph, petrification, disease, poison, stunning, sleep, paralysis, death effects, disintegration, energy drain, ability damage, ability drain, mind-affecting, and fear, dazzled & blinded), nondetection (DC 48), ray deflection, freedom of movement
Stat buffs/penalties: +25 competence perception, doubled crit range, +10 armour AC, +3 luck attack/saves, +9 shield AC, +4 morale skills, +2 insight AC/reflex, +10 insight perception, +8 morale attack/damage, +6 morale saves/dodge AC, +4 competence attack, +3 competence fort
Perceptions: Darkvision, tremorsense, blindsight 3 miles, scent, arcane sight, perception +89
Sorcerer spell slots: 6/16/16/14/8/9/15/9/8/4/8/7/6/6/4
Duskblade spell slots: 6/23/23/21/11/7/7
Marie: 711+20/711
Active spells: Extended mind blank (CL 33), extended nondetection (CL 33), sensual blessing (CL 33), epic mage armour (CL 33), recitation (CL 33), greater heroism (CL 33), repelling shield (CL 33), extended ray deflection (CL 33), greater arcane sight (CL 33), bibliotheca arcana (CL 33), telepathic bond (CL 33), freedom of movement (CL 33)
Defences: AC 92 (CMD 86), spell resistance 48, energy immunity (electricity), status immunity (petrification, polymorph, form-altering, energy drain, ability drain, ability damage, mind-affecting), nondetection (DC 48), ray deflection, freedom of movement
Stat buffs/penalties: +25 competence perception, +3 luck attack/saves, +9 shield AC, +4 attack/saves/skills, +15 insight knowledge
Perceptions: Darkvision, tremorsense, blindsight 60, scent, greater arcane sight, perception +77
Sorcerer spell slots: 6/10/10/9/7/8/9/8/7/8/7/4/6/4
The smell.
The smell is the first thing you have to endure.
It's like trash and rot and sun baked filth, boiled and intensified a dozen times over. You're certain that if you were still mortal, you'd be violently ill right now. A greenish-black sludge clings to the walls, everything here damp, moist.
Alicia has dance of the unicorn up in case that helps with the smell as well as poisons.
You surround yourself with a purifying swirling mist with a radius of 5 feet per caster level that washes the air clean of smoke, dust, and poisons.
Your magic soon cleanses away the smell, and just in time.
"Disgusting," Jessica wrinkles her nose, "Thank you for that spell, sister."
Lady Sanzha is unperturbed, "At least it's not Bwimb."
"Yes, that spell's key to this whole endeavour," Alicia smiles. "Never had the pleasure, though a visit to the wilds of Ooze was bad enough," she adds to Sanzha, starting to head down towards the tainted water.
Marching order and give me a quick d100.
Order is Alicia, Jessica, Sanzha, Marie.
[18:44] <@Ebiris> roll 1d100
[18:44] <Kobot> Ebiris rolled 1d100 --> [ 1d100=10 ]{10}
You progress down the tunnel. Around a bend and another, the way further head blocked. The tunnel is clogged with green black slime, blocking the way entirely.
"Was it like this before?" she asks Jessica, a lance of silver fire evaporating the slime in her path to clear the way.
The slime is burned away, recoiling, "Yes," Jessica says, "Though I didn't come on a blocked passage."
"Hurry along then, they may be prepared for our arrival," Alicia says, flying along down the now revealed path.
Down, down and down some more. Down a t unnel to an opening - and ahead is a sphere of filth, of tainted water. No one is obviously about here, at least to your eyes. The waters are tinted red, seeming to spread all over it, as well as many reddish stones floating about in the water.
Past all of that you can see a great city, a city of stone and wealth. A city full of dao, glimpsed amid gaps in the stones and things blocking your vision.
With her godly vision able to behold everything within three miles, it's not as if the polluted water offers anything to stop her. "Stick close now," she says, pinching space between herself and a spot halfway towards the dao outpost, stepping through and waiting for the others to follow, the tainted waters cleansed around her by her magic so as to not prove any obstacle. One more should bring them into the clean and dry area in the middle and then things can go off.
Gimme a quick Perception check.
[15:55] <@Ebiris> roll 1d20+89 perception
[15:55] <Rei-chan> Ebiris rolled : 1d20+89 perception --> [ 1d20=13 ]{102}
Alicia: 772+20/772
Marie: 711+20/711
