A book and many things to do
Started by Anastasia, July 09, 2019, 11:04:47 PM
The wound begins to scab over as it heals, relief filling you as the blood flow stops. You feel woozy but that's abating, your injury at least no longer bleeding.
Alyssa takes the time to inspect the room, suspecting another teleportation.
There are no exits. The walls are plain and bare. It's another empty torture room.
Is Xorn Movement still active? I doubt it. Would be 34 rounds.
Alyssa focuses and chants a spell!
Disintegrate (Chain, Echoing), CL 33
Send 1 ray where the sphere was, a few at the walls to check for hidden doors, rest in the same place I found the stairs on previous levels.
Nothing.
The wall are but a thin shell. Beyond them is blank nothing, emptiness as far as anything can see.
Do you have anything that provides you air or protects your breathing. Or for that matters, relieves you from having to breathe at all?
Yup:
Talisman of Long-Life, 17,250: Immune to all harmful vapors and gases (such as cloudkill and stinking cloud effects, as well as inhaled poisons) and allowing him to breathe, even underwater or in a vacuum, and continually provides its wearer with life-sustaining nourishment, its wearer needs only sleep 2 hours per day to gain the benefit of 8 hours of sleep.
There is no air, yet you can breathe, your talisman proving its worth.
Alyssa considers.
"A demi-plane made into a dungeon? How appallingly wasteful, Shar. You've had your fun, tortured those here. Unless you take a more direct hand and draw more attention than you're ready for, this little outpost is lost to you. End this with dignity and a small tick in my favor and let's both be about our business."
There is nothing around you, no reply either. Your only companion is the void all around you.
Alyssa shakes her head.
"Petty. I expected more elegance from a Goddess. Though I suppose that's part why you're always regulated to Selune's shadow. To think you once stood next to her."
Alyssa inspects the void, trying to decipher the magic creating it to better understand it's strength and how to break it.
There is no magic here. It is empty, void of even magic, save what surrounds you.
Alyssa attempts a Plane Shift back to Ash!
Greater Plane Shift, CL 33.
Nothing happens, the spell fails.
