The Gossip Board mk 2
Started by Anastasia, June 01, 2012, 01:47:16 AM
Iddy, you were interested in crafting some poisons? What sorta poisons? The Styx Tears you gathered up?
Yarp. I suppose since I'm up, I can check near camp for anything additional, too.
Okay, you have enough time in the morning to either look around or attempt to craft one dose. Your call on which, since the party isn't looking to linger.
#183
I'll use what I have on hand, and keep a look-out while we travel.
Edit: You said I had 2-4 doses of Styx Tears.
Paste how much of that herb you have from loot real quick?
Okay, make a herbalism check and post the result.
> roll d20+7-2+2 Herbalism
* Hatbot --> "Iddy rolls d20+7-2+2 Herbalism and gets 21."12 [d20=14]
That +2 is from MW Herbalist kit.
Thyan makes a single dose of the following. Further, he has enough to make two more doses, assuming time later. The format used is from here: http://www.dandwiki.com/wiki/SRD:Poisons
Styx Tears; ingested DC 20; despair for 1d4 hours and deeper despair.
This means as follows. The poison type is ingested, which means it has to be eaten or otherwise consumed. The fortitude save to resist is 20. The result of initial damage is despair, which is treated as a crushing despair spell. The secondary damage is deeper despair, which causes the victim to need to make a DC 20 will save after every hour of the duration or succumb to despair and attempt suicide. The secondary damage lasts as long as the initial damage.
VySaika
Reposting from Post of the Day, since don't think everyone here checks that.
<@ZombieGate> hmm
<@ZombieGate> bored
<@ZombieGate> tired
<@ZombieGate> blarg
<KoFOOTBALL> Gate.
<@ZombieGate> Ko.
<KoFOOTBALL> If you're bored, could you make a Ko PrC?
<KoFOOTBALL> I'm getting that look, aren't I?
See attatchment. He quite litterally asked for this.
All About Monks
<Marisa> They're OP as fuck
<Marisa> just by being monks
I suppose I can only say one thing: Terrifying.
Sierra
Because it was request by Dunes: new spells for level 7 were Attune Form and Stoneskin.
Remember that stone skin has a 250 gold material component per casting, Cid. You'll need to get to some sort of civilization to buy some diamond dust.
Sierra
...Orb of Fire it is, then!
Dune, assuming we ever make it to high enough level to finish off our prestige class (fastest for me since Outcast Champion is only a 5 level prestige class), can we pick a new prestige class, or are you going to stick with the 2-base+1-prc only model?
Most likely stick with the current model, but I'll re-evaluate it as it comes closer to happening. Ask me again in three levels.
