Random DM nagging 2: Endless nagging
Started by Anastasia, August 29, 2014, 12:50:41 AM
cmd: +6 bab, +7 dex (with weapon finesse), +2 size
cmd: same just add 10 for base
edit: I saw your post to Neph suggesting size bonuses are inverted for cmb. Corrected by subtracting 4 from each now. Which makes power selection easier later on!
Ability scores:
Starting stats: 17, 16, 15, 15, 13, 12
Modifiers after race/cat-form/spellwarped/collar/levelups: STR -4, DEX +8, CON +6, INT +8, WIS +2, CHA +2
Current abilities: Str 8, Dex 25, Con 22, Int 25, Wis 17, Cha 17
Required base:         12     17      16      17      15      15
So yeah, I had that 13 turned into a 17 somewhere along the line.
A slight rejigger gives me Str 8, Dex 23, Con 22, Int 25, Wis 17, Cha 15
Altered ac/cmb/skills to match (also added +2 to perception for racial bonus)
Feats: My second psion bonus feat is swapped for the telepathy feature.
Powers: Swapped Schism for Psionic Freedom of Movement.
Changed the languages to Aquan and Terran and made the other modifications. I figured my Init was +4 since of the armor, but I changed it back to +5.
Iddy's next.
- Okay, your HP is 60 but your rolls tab says 52. Where's the other +8 coming from?
- I'd suggest removing the +1 to AC from mindspy, as it's conditional on successfully skimming the surface thoughts of your opponent.
- Your CMB should be +8, not +7. You forgot to adjust it for your Strength modifier.
- Your CMD is low. You get to add any non armor, non natural bonuses to armor class. That means your +4 wisdom bonus to armor class applies for a total of 26. Likewise, your mindspy bonus applies to that when you have it active.
- Your full attack is wrong. 7+4+1 is 12, not 11. Likewise, your second attack is off. You have +2 BAB to it, not +1. It should be 7. Your ranged full attack is also 1 too low on both. I'd say don't apply point blank shot since it's a conditional, but your range limitations largely makes this irrelevant.
- Damage looks off as well. Your SA is one too high. In particular, dagger sneak attack is at +2d6 when it should be at +1d6.
- The DC of detect thoughts is one too low. It's 10 + 1/2 hit dice + Charisma modifier. That's a total of 16 (18 after ability focus) for you, not 15. (The save DC rises as you level and your Charisma score changes. I suspect you didn't calculate this at all, and the +2 is from Ability Focus. So it should be 18 and not 16.)
- Saves? Fort looks 2 too high. Your base save is 1 (+1 rogue, +0 IB, +0 mindspy), 3 from your Con modifier and 2 from your cloak of resistance. That's 6. Am I missing a booster somewhere? Ref and Will look right, though.
- Your inspiration should be 3, not 2. As noted in invisible blade, that and factotum's inspiration pool stack.
- Skills look right. I mention it since I've used so much red ink already.
- Re: Feats. Can you have them all listed together somewhere, rather than spread out amid class features?
- Your level six feat lacks the name of the feat. I know it's Ability Focus. Also, note what ability it applies to.
- Rogues get penetrating strike as a houserule rather than trap sense. Unless you want trap sense and ACF out penetrating strike. I doubt you do.
Everything else looks good. Whew.
Quote from: Ebiris on September 12, 2014, 02:22:01 PM
Cool.
QuoteAbility scores:
Yeah, I was sure one of them was off. Glad it's fixed.
QuoteAltered ac/cmb/skills to match (also added +2 to perception for racial bonus)
Noted to all of those.
Quote from: Nephrite on September 12, 2014, 02:31:00 PM
Fair enough. Fixed then, good to go.
Quote from: Anastasia on September 12, 2014, 02:53:52 PM
The rolls didn't include the +2 CON item I bought:
Level 1:8+3=11
Level 2:2+3=5
Level 3:4+3=7
Level 4:8+3=11
Level 5:5+3=8
Level 6:2+3=5
Level 7:3+3=6
Level 8:4+3=7
11+5+7+11+8+5+6+7=60.
Done.
Done.
Done.
Done. I kept the PBS stuff in since the limitations pretty much ensure I'll always get it. I did make a note for that, though.
Done.
Done. You're right, I just went off of Doppel instead of figuring for stats.
Not sure, I'll put what you got.
Done.
Alright. You'll have to tell me how you want them split.
Done.
Put Trap Sense back, added the House Rule feat.
Noted Iddy. Everything looks good and that makes sense on the HP.
As far as feats go, I talked to you in PM, so I'll summarize here. If it's a feat, put it with the other feats. It doesn't matter if it comes from gaining levels, bonus feats from classes, racial feats or from where ever else.
My game prep's mostly done. So if you make any large changes to your character from now to game start, toss a post up so I know.
Quote from: Anastasia on September 28, 2014, 09:43:59 PM
How goes that log, Iddy?
It is up. I did the edit of it and got sidetracked before I posted it. Woke up this morning at like 7 am and remembered I hadn't done so yet, and then did so.
Quote from: Iron Dragoon on September 29, 2014, 09:21:36 AM
Looks solid, thanks.
One more day! Be ready and be prepared. Last call for any pre-game questions or adjustments.
Quick update: You all rested last session. Restore hit points for a night's rest. It wasn't brought up yesterday by mistake.
Also, while I'm at it? Eb and Cor, when does DST end for you?
