Where hope dies (Afina, Surarruthru, Calleigh)
Started by Anastasia, February 03, 2016, 01:54:24 PM
Surraruthru takes the chance to cast a couple of extra spells on the angel while Afina is scouting out the next section.
Casting Mind Blank and Freedom of Movement on the angel.
Mind Blank: CL 24, Duration 24 hrs
Freedom of Movement: CL 24, Duration 240 min, DC 24.
Surraruthru: 238/238 HP, Mind Blank
AC: 32 (Touch: 17, Flat Footed: 26) SR: 18, Immunity to Fear, Sleep, Paralysis, Reflective Fear, Darkvision 60 ft, Low-Light Vision, Waterbreathing
Spells/SLAs: http://www.soulriders.net/forum/index.php/topic,101754.msg1059635.html#msg1059635
Modify message
The next room is rather large and has strobing, moving lights. It's a mix of shadow and light. In the center of the room are a dozen coffins, open lidded and sorted to each point towards the wall. A 12 point circle. Each one has a pale figure tied and nailed into the coffin, unclad and with wide, crazed eyes. Above them a ball of white stone rotates, shedding bright light down in an ever moving circle. As it moves, it sets the pale figures aflame, but doesn't linger too long. As it passes, the coffins glow slightly, the burns healing.
Around it stand two Necrolytes, back to you. As you slip in, you can hear them talk in Infernal. "...and is as should be."
The other replies, "As only it can be."
Afina withdraws back to relay her findings. "Two necrolytes and a dozen undead in some sort of apparatus... they're nailed to coffins but that doesn't mean they can't hit us with strange effects. Go in with area attacks to wipe out everything," she suggests, once more delegating the important job of door kicking to someone with the legs for it.
Cresiel does just that - after gently checking the door, which doesn't seem to be locked. He kicks it open, rushing in, "Today is the day you lament your sins!"
The two Necrolytes visibly startle, starting to turn around. The undead don't react.
Surprise round, y'all. Go ahead and take it, PCs.
#244
Leading by example, Afina flits in over Cresiel's shoulder and whips her arm forward as she conjures forth an indiscriminate spray of molten hot magma to flood the room and coat everything in it!
Searing Deadly Lahar
[17:34] <@Ebiris> roll 10d6 searing deadly lahar, DC 33 ref half, no SR.
[17:34] <Serith> Ebiris roll for Serith < 33 > [d6=3,2,4,5,3,5,4,3,2,2]
If the save is failed they're slowed as per the spell for 3 rounds and take 5d6 damage per round for the same duration
Also note fire resistance/immunity is completely bypassed
Afina: 208+20/208, heroes feast (CL 20), greater mage armour (CL 23), moment of prescience (CL 23), resist energy (cold) (CL 23), resist energy (acid) (CL 23), shadow form (CL 23), mind blank (CL 25), shield (CL 23), greater heroism (CL 23), haste (CL 23)
AC 72, spell resistance 38, blindsense 30, immunity to fire, water, disease, poison, fear, 50% miss chance (applies to spells as well), freedom of movement
Spell charges: 6/9/7/6/8/5/4/7/6/6
> roll 1d20+21 ref necrolyte 1
<Serith> Kotono roll for Serith < 37 > [d20=16]
> roll 1d20+20 ref necrolyte 2
<Serith> Kotono roll for Serith < 32 > [d20=12]
The undead in coffins autofail since they're helpless.
Lava pours into the room, setting the necrolytes ablaze and burning the coffins. The undead in them don't react, and as they burn, Cresiel barges in and just glares at them, a blast of pearly white power buffeting them from all around.
Holy smite.
> roll 1d20+22 SR
<Serith> Kotono roll for Serith < 25 > [d20=3]
But the fiends resist it, enduring as...
Surraruthru and Calleigh and co are up. Go.
Manifesting a twinned Energy Barrage. Can I get a d100 roll before proceeding?
> roll 1d100 for Yuth
<Serith> Kotono roll for Serith < 32 > [d100=32]
That is a failure. Stupid spell failure chances.
26 PP burned. Alas.
Nothing happens! Calleigh looks faintly annoyed!
Surraruthru casts a spell, trying to focus on slowing the Necrolytes down for the big hitters to kill them!
Casting Confusion, Heighten spell from level 3 to level 7. Assuming still hidden, so factoring for Concealed Casting.
CL: 26 (Spells vs. Evil: +1 CL/+2 CL vs. Subtype), Bypasses SR, Will save vs. DC 34, Duraction 26 rounds (More if CL is boosted).
> roll 1d20+23
> roll 1d20+23
<Kobot> Kotono rolled 1d20+23 --> [ 1d20=16 ]{39}
<Kobot> Kotono rolled 1d20+23 --> [ 1d20=9 ]{32}
Second Necrolyte is confused.
As lava scorches the devils and undead, Surraruthru throws his own brand of confusion into it. As the mind magic works through him, Sylvie and the Master rush in, dogpiling on the first Necrolyte.
> roll 1d20+54 Syvlie (+1 heroes feast, +14 inspiration 11/12 left, stunning fist 6/7 left)
<Kobot> Kotono rolled 1d20+54 Syvlie (+1 heroes feast, +14 inspiration 11/12 left, stunning fist 6/7 left) --> [ 1d20=1 ]{55}
> roll 1d20+36 Master (+1 heroes feast, stunning fist 21/22 left)
<Kobot> Kotono rolled 1d20+36 Master (+1 heroes feast, stunning fist 21/22 left) --> [ 1d20=8 ]{44}
> OOC: +1 to that
> roll 4d8+14
<Kobot> Kotono rolled 4d8+14 --> [ 4d8=24 ]{38}
> roll 1d20+22 vs DC 35
<Kobot> Kotono rolled 1d20+22 vs DC 35 --> [ 1d20=15 ]{37}
Sylvie's a touch too fast, overshooting it and narrowly missing the Necrolyte. The Master leaps on this, fist hitting the cornugon right in the jaw. The withered creature's head snaps back from the blow, as...
Init here.
Sylvie
HP: 290+11/290
Effects: Heroes Feast (CL20), Overland Flight (CL22), Deeper Darkvision (CL22), Greater Mighty Wallop (CL22), Endure Elements (CL22), Attune Form (CL22), Mind Blank (CL 24), Shield (CL 22), Resist Energy(Cold) (CL22), Freedom of Movement (CL22)
Boosts: Immune to fear and poison, +1 morale bonus to attack rolls and Will saves, immunity to planar conditions, mind blanked, +4 shield bonus to AC, cold resistance 30,  (Note, her normal boosts aren't included since they're factored into her main stat block.)
Resources used: Arcane casting: 1st: Endure Elements, Shield 2nd: Resist Energy 3rd: Deeper Darkvision, Greater Mighty Wallop 4th: Attune Form 5th: Overland Flightx3 Divine casting: 6th: Heal Stunning fist 6/7 left
Other: Current inspiration: 11/12
Master
HP: 295+15/295
Effects: Heroes Feast (CL20), Overland Flight (CL22), Attune Form(CL22), Mind Blank (CL25)
Boosts: Immune to fear and poison, +1 morale bonus to attack rolls and Will saves, immunity to planar conditions, mind blanked.
Resources used: -
Other: -
Tannin
HP: 218+11/218
Resources used: -
Other: -
> roll 1d20+12 Init
<Kobot> Iddy rolled 1d20+12 Init --> [ 1d20=16 ]{28}
[16:39] <@Ebiris> roll 1d20+26 init
[16:39] <Kobot> Ebiris rolled 1d20+26 init --> [ 1d20=18 ]{44}
> roll 1d20+24 Sylvie
<Kobot> Kotono rolled 1d20+24 Sylvie --> [ 1d20=9 ]{33}
> roll 1d20+9 Tannin
<Kobot> Kotono rolled 1d20+9 Tannin --> [ 1d20=1 ]{10}
> roll 1d20+9 Master
<Kobot> Kotono rolled 1d20+9 Master --> [ 1d20=12 ]{21}
> roll 1d20+11 necrolyte 1
<Kobot> Kotono rolled 1d20+11 necrolyte 1 --> [ 1d20=4 ]{15}
> roll 1d20+7 necrolyte 2
<Kobot> Kotono rolled 1d20+7 necrolyte 2 --> [ 1d20=17 ]{24}
Waiting on Tryll and company inits. Eb or Iddy, could you roll for him if you see this before Yuth pops up?
[21:01] <@Ebiris> roll 1d20+6 Tryll init
[21:01] <Kobot> Ebiris rolled 1d20+6 Tryll init --> [ 1d20=15 ]{21}
[21:01] <@Ebiris> roll 1d20+7 Calleigh init
[21:01] <Kobot> Ebiris rolled 1d20+7 Calleigh init --> [ 1d20=11 ]{18}
[21:01] <@Ebiris> roll 1d20+2 psicrystal init
[21:01] <Kobot> Ebiris rolled 1d20+2 psicrystal init --> [ 1d20=15 ]{17}
