[21:21] <Nephrite> roll 1d20+33 spot
[21:21] <Kobot> Nephrite rolled 1d20+33 spot --> [ 1d20=15 ]{48}
[20:21] <Merc> roll d20+9 spot Balyss
[20:21] <Kobot> Merc rolled d20+9 spot Balyss --> [ 1d20=2 ]{11}
[20:22] <Merc> roll d20+6 spot Crystal
[20:22] <Kobot> Merc rolled d20+6 spot Crystal --> [ 1d20=8 ]{14}
[20:22] <Merc> roll d20+32 spot Hope
[20:22] <Kobot> Merc rolled d20+32 spot Hope --> [ 1d20=1 ]{33}
Moore and Ithea both notice something as you fly along and follow the track. Far away on both sides are further minecart track lines, leading on in the same directions. Quite far away, but they're there. Meanwhile you fly ahead for a bit, about 1000ft or so. Ahead you can see the other side of the chamber, a passage for the minecart to pass into.
Ithea gestures in that direction for both Crystal and Balyss and begins to fly in that direction seeking a landing spot. Hopefully it's within her teleporting range and has a path for travel by foot, or things will get tricky with Rosa and Smrgol.
What's yoru teleport range?
The party lands there, a slope going down with more minecart tracks. It only looks to go down 30ft before evening out once more.
Just barely.
"Well," Crystal lands,  "Will we go back or...?"
"I'll go bring them back here, you guys start checking things out, make sure we don't get caught by surprise by anything," Ithea says in response after making sure there's enough space for everyone.
It'll take two trips for space reasons, Ithea thinks. The space constraints just won't work all at once.
If that's the case, I'll have someone come with me to lead the others then. Don't see the point in teleporting more than Rosa/Smrgol since the others can fly there easily enough.
Moore can go with Ithea and use a Dimension Door himself.
That works.
Getting people to and across is without incident - surprisingly. Still no more sign of attack. Rosa frowns as she looks around, "I don't like this. They're baiting us ahead into something."
"Well, what do we intend to do about it?" Moore asks. "I mean... it feels like there's not much else to do but go forward -- but I suppose if we know it's a trap we can try and have magical protections about us to prepare?"
"Maybe," Ithea admits at Rosa's concern. "But I still feel we can accomplish something before leaving if we keep moving forward. Don't worry, I know what limits not to cross. If something big enough that we can't handle shows up, we'll be able to sense it before it hits us and abort."
"If there's any protections you want to use, go ahead and use them. I'm fairly sure we'll need them soon if they haven't abandoned this base."
Any things you all would like cast on you by Balyss?
