Dragon mail (Moore)
Started by Anastasia, August 02, 2016, 12:54:15 PM
Moore nods and takes him to Baleruk's lair. While he's on his way he does cast a spell for some divine guidance... and a little luck.
Divine Insight and Improvisation as they're on their way.
Just casting it right in the open?
Before they get to the lair, but yes.
As you cast those spells in the courtyard, Arrel gives you a curious look and your guest does the same. "Why such magic when greeting an ally?"
Taking 10 on relevant checks.
"You'll see." Moore says with a bit of an exasperated sigh. "Although I suppose he's just as likely to greet us with a smile and a nod than like usual..."
"I doubt it." Your new friend says, "Oh, I deeply doubt it."
Moore smiles. "It's good to be optimistic, but it's also good to be prepared, regardless of the circumstances, right?" He takes a breath and heads in to see the great rainbow dragon.
You fly on up and into Baleruk's lair. The prismatic dragon is there, hunched over a huge aquarium - dozens and dozens of feet long and two dozen feet tall. Right now it's full of water and the dragon holds a single gold piece between his claws. He carefully angles, seeming to be figuring where precisely to drop it in.
Moore glances at the aquarium to see if he can be helpful in this particular regard.
Taking 10 for 32 on K:A&E.
What precisely are you trying to learn here, Moore?
if there was an aesthetically and structurally sound place to put the gold.
It's a huge aquarium. Structurally sound isn't an issue. It's also empty, so aesthetically is a wash. At least to traditional senses, Baleruk likely operates to his own opinions.
"How about right in the middle, to showcase and accentuate the rest?" Moore calls out. May as well get this over...
Baleruk looks up and peers at both of you. He is silent and locks eyes with the gold dragon. Long seconds turn into a minute as the two stare at each other. The humanoid gold dragon has a look of disdain and superiority, while Baleruk's expression is inscrutable.
"Baleruk, I'd like to introduce you to Goldanariux. He's a new ally of Aurora." Moored says simply.
