> roll 1d20+31 Listen
<Rei-chan> Iddy rolled : 1d20+31 Listen --> [ 1d20=4 ]{35}
> roll 1d20+34
<Rei-chan> Kotono rolled : 1d20+34 --> [ 1d20=11 ]{45}
> roll 1d20+24 Sylvie
<Rei-chan> Kotono rolled : 1d20+24 Sylvie --> [ 1d20=19 ]{43}
> roll 1d20+32 Ebony
<Rei-chan> Kotono rolled : 1d20+32 Ebony --> [ 1d20=18 ]{50}
All of you can hear an odd rustling beneath you, coming from the ground.
"Below!"
Surraruthru takes to the air, preparing a spell to splatter whatever this daemon threat is!
Surraruthru
HP: 296+12 (150HP 10/adamantine)
AC: 32+6
Init: +12, Touch Atk: 29
Active: Mindblank (CL25), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Stoneskin (CL28), Spell Turning (CL28)
Passive: Improved Evasion, Diamond Body, True Seeing
"Fly up!" Kascha eeps as she follows Surraruthru, the other two following. Thurra skitters away on the ground fast, out of the way in time. Where you were moments before explodes upwards as a massive worm erupts out, biting and trying to swallow air whole. Safe! At least for now. The worm is a sickly purple color and its maw is big enough to swallow Hanna whole, let alone any of you.
Init here, along with K:A if you want to identify.
Kascha
HP: 271+11/271
Spells Active: Mind Blank (CL25), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Superior Resistance (CL25), Stoneskin (CL28), Spell Turning (CL28)
Bonuses: +1 morale attack/will saves, immunity to poison and disease
Sylvie
HP: 305+17/305
Spells Active: Mind Blank (CL25), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Greater Mighty Wallop (CL23), Endure Elements (CL23), Overland Flight (CL23), Stoneskin (CL28), Spell Turning (CL28)
Bonuses: +1 morale attack/will saves, immunity to poison and disease, damage reduction 10/adamantine
Ebony
HP: 256+16/256
Spells Active: Mind Blank (CL25), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Stoneskin (CL28), Spell Turning (CL28)
[/quote]
> roll 1d20+34 K:A
<Rei-chan> Iddy rolled : 1d20+34 K:A --> [ 1d20=8 ]{42}
> roll 1d20+12 Init
<Rei-chan> Iddy rolled : 1d20+12 Init --> [ 1d20=1 ]{13}
Surraruthru
AC: 32+6
> roll 1d20+12 Kascha
<Rei-chan> Infinite_Xorn_Loop rolled : 1d20+12 Kascha --> [ 1d20=12 ]{24}
> roll 1d20+24 Sylvie
<Rei-chan> Infinite_Xorn_Loop rolled : 1d20+24 Sylvie --> [ 1d20=18 ]{42}
> roll 1d20+8 Ebony
<Rei-chan> Infinite_Xorn_Loop rolled : 1d20+8 Ebony --> [ 1d20=8 ]{16}
> roll 1d20+4 worm
<Rei-chan> Infinite_Xorn_Loop rolled : 1d20+4 worm --> [ 1d20=2 ]{6}
Init is Sylvie (42) > Kascha (24) > Thurra (20) > Ebony (16) > Surraruthru (13) > Worm (6)
All of you are 30ft above ground and the worm's mouth.
> roll 1d20+50 Kascha
<Rei-chan> Infinite_Xorn_Loop rolled : 1d20+50 Kascha --> [ 1d20=5 ]{55}
> roll 1d20+55 Sylvie
<Rei-chan> Infinite_Xorn_Loop rolled : 1d20+55 Sylvie --> [ 1d20=7 ]{62}
> roll 1d20+32 Ebony
<Rei-chan> Infinite_Xorn_Loop rolled : 1d20+32 Ebony --> [ 1d20=12 ]{44}
K:A checks.
The creature before you is a purple worm. You know it well - it swallows prey hole, has a poisonous bite and is a dumb animal past all the bulk and power. However, this one looks like it's been twisted by fiendish power - it's probably both smarter and has powers relating to that.
Worth noting OOC it may be smart enough now to gestalt, which introduces all sorts of possibilities. Anyway, Sylvie opens.
Sylvie flies another 30ft up, "Stay away, it'll struggle from afar!" she warns, extending her fingers out. Five magic missiles fly from her fingers, seeking the worm's gullet.
> roll 1d20+23 caster level check
<Rei-chan> Infinite_Xorn_Loop rolled : 1d20+23 caster level check --> [ 1d20=10 ]{33}
> roll 5d4+5
<Rei-chan> Infinite_Xorn_Loop rolled : 5d4+5 --> [ 5d4=11 ]{16}
The missiles strike the worm, leaving behind a few welts but nothing more.
Kascha meanwhile joins Sylvie 30ft higher and begins to cast, "The sixth gate crumbles ot the seventh, and from it comes the breath of undeath!" A thin purple beam flies from her finger...
Empowered maximized enervation for 6 negative levels. No SR check since she can't fail it.
> roll 1d20 touch AC only misses on a 1
<Rei-chan> Infinite_Xorn_Loop rolled : 1d20 touch AC only misses on a 1 --> [ 1d20=11 ]{11}
The worm is hit directly, shrinking down and slumping. It looks far less, scales cracking and a few falling off. It's starting to slump back down into the hole it came from.
"No. You will not escape from this reckoning, worm," Ebony says, as a single ray of sunlight comes from above. It shines down on the worm, before exploding in a potent burst of radiance.
Purified righteous smite.
> roll 1d20+22 caster level check
<Rei-chan> Infinite_Xorn_Loop rolled : 1d20+22 caster level check --> [ 1d20=17 ]{39}
> roll 20d10
<Rei-chan> Infinite_Xorn_Loop rolled : 20d10 --> [ 20d10=107 ]{107}
> roll 1d4 rounds blind
<Rei-chan> Infinite_Xorn_Loop rolled : 1d4 rounds blind --> [ 1d4=3 ]{3}
This magic makes the worm's eyes burst into white flames as it trills - a horrifying, skin crawling sound that makes the insides of your teeth ache - andthrashes, tearing up the ground below. "Surraruthru, finish it!" Ebony demands.
Meanwhile, amid the combat, Thurra's falling back and well out of range of the worm, but she doesn't attack it, either.
Go, Surraruthru.
Kascha
HP: 271+11/271
Sylvie
HP: 305+17/305
Ebony
HP: 256+16/256
Spell-like abilities
At will-aid, charm monster, color spray, comprehend languages, continual flame, dancing lights, detect evil, detect thoughts, disguise self, dispel magic, hold monster, greater invisibility(self only), major image, see invisibility, greater teleport (self plus 50 pounds of objects only); 1/day-chain lightning, prismatic spray, wall of force. Caster level 23rd. The save DCs are 17 + spell level.
Kascha casts as a 23rd level wizard. (Caster level 26th for spells with the fire descriptor; caster level 25rd for other spells. +6 caster level bonus to overcome spell resistance.) The save DCs are 20 + spell level. Her spell themes are spells learned from Seira, fire magic and minor buffing. Her metamagic options are Empower Spell (+2), Maximize Spell (+3), Twin Spell (+4) and Quicken Spell (+4). She may apply the following metamagics to the following spells once per day without adjusting their casting time or spell level: Magic Missile, empower; Inner Beauty, quicken; Summon Greater Elemental, quicken.
[6/day]6: Empowered Enervationx2, Summon Greater ElementalSC, SR, Surge of Hopex2Home.
[4/day]8: Dimensional Lock, Maximized Greater Fireburst, Quickened Empowered Scorching Ray, Mind Blank.
[4/day]9: Mass Heal, Twinned Greater Fireburst, Empowered Righteous Smite, Wish
[4/day]10: Celestial ValorHome, Energy ImmunityHome, Quickened Greater Dispel Magic, Seira's Unicorn ApocalypseHome
Sylvie casts as a 13th level chameleon (Caster level 23rd.) Her save DCs are 24 + spell level (arcane) or 15 + spell level (divine). Her spell selection themes are personal power and planar survival.
Arcane casting
[4/day]0: Detect Magicx2, Prestidigitationx2
[8/day]1: Improvisationx3SC, Magic Missilex2, Shieldx2
[8/day]2: Body of the SunSC, Detect Thoughts, Electric LoopSCx2, Resist Energyx2, See Invisibilityx2
[7/day]3: Amorphous FormSC,, Displacement, Greater Mighty WallopRD, Heroism, Sylvie's Speedy AppraisalHome, Vampiric Touch
[7/day]4: Assay Spell ResistanceSC, Attune Formx2SC, Dimensional Anchor, Dimension Door, Enervationx2
[7/day]5: IndomitabilitySC, Overland Flight, Teleportx2, Wall of Forcex2.
[7/day]6: Bite of the Weretigerx3SC, Disintegratex2, Greater Heroismx2.
[3/day]7: Greater Teleport, Limited Wish, Waves of Exhaustion.
RD - Races of the Dragon.
SC - Spell Compendium.
Divine casting
[4/day]0: Create Waterx3, Cure Minor Wounds.
[5/day]1: ConvictionSC, Divine Favorx2, Foundation of StoneSC, Goodberry
[5/day]2: Aid, Lore of the Godsx3CC, Spiritual Weapon
[5/day]3: BlindsightSC, Cure Serious Woundsx3, Ghost Touch WeaponSC
[5/day]4: Death Wardx2, Divination, Divine Power, Freedom of Movement.
[4/day]5: Plane Shift, Righteous Mightx2, Spell Resistance, Zone of RevelationSC
[4/day]6: Healx4.
[1/day]7: Aura of VitalitySC
CC - Complete Champion
Arcane Dilettante casting. 9 spells with a maximum of level 8. Save DCs are 22 + spell level.
Bite of the Werebear, Cone of Cold, Enervation, Greater Mirror Image, Greater Invisibility, Greater Mighty Wallop, Greater Heroism, Polar Ray, Shield.
Ebony casts as an 23rd level bard. (Caster level 27th vs dispel) The save DCs are 20 + spell level. Her metamagic options are Consecrate Spell (+1) and Purify Spell (+1). Ebony may use Consecrate Spell and Purify Spell spontaneously without increasing the casting time of the spell.
[6/day]3: Charm Monster, Cure Serious Wounds, Fear, Gaseous Form, Major Image.
[6/day]4: Cure Critical Wounds, Greater Invisibility, Hold Monster, Modify Memory, Sirine's GraceSC
[4/day]7: Heal, Rain of EmbersBoED(1d2 str drain), True Seeing, Vision.
Frost - Frostburn.
Ebony casts as a 22nd level sorcerer. (Caster level 26th vs dispel) The save DCs are 20 + spell level. Her metamagic options are Consecrate Spell (+1) and Purify Spell (+1). Ebony may use Consecrate Spell and Purify Spell spontaneously without increasing the casting time of the spell.
[7/day]7: Greater Teleport, Holy Word, Righteous SmiteBoED.
[6/day]8: Greater Planar Ally, Polar Ray, Lightning RingSC.
[4/day]10: Planet DefenderHome, Unseen NeedleHome
Surraruthru draws up a bit, chanting under his breath before snapping his head forward and opening his maw, launching the spell from in front of his mouth!
Lightning Bolt, level 3, CL 25
Reflex Half, SR allowed
> roll 10d6 Lightning Bolt
<Rei-chan> Iddy rolled : 10d6 Lightning Bolt --> [ 10d6=44 ]{44}
Surraruthru
AC: 32+6
> roll 1d20+25 CL Check
<Rei-chan> Iddy rolled : 1d20+25 CL Check --> [ 1d20=17 ]{42}
Surraruthru
AC: 32+6
Quick note, the previous post omitted the purple worm's Will save against righteous smite. It was made but not posted due to an oversight. It's below, then the Ref save against Surraruthru's lightning bolt.
> roll 1d20+11 Will vs 27
<Rei-chan> Infinite_Xorn_Loop rolled : 1d20+11 Will vs 27 --> [ 1d20=14 ]{25}
> roll 1d20+14 Ref
<Kobot> Koaway rolled 1d20+14 Ref --> [ 1d20=3 ]{17}
The bolt of lightning hits the worm directly in the maw, making it convulse and smoke. It lets out a strange, buzzing trill as it retreats down, the tunnel it came from collapsing behind it. All that's left is an indent in the ground to show the battle happened, the worm outright retreating.
Free act. It ran after getting beaten around good.
Kascha
HP: 271+11/271
Sylvie
HP: 305+17/305
Ebony
HP: 256+16/256
Arcane casting
Divine casting
[4/day]6: Healx4.
Frost - Frostburn.
[/quote]
Surraruthru snorts at the worm.
"Filthy worms. Thurra's lack of effort has been noted, though I'll admit I don't recall anyone ever making her help against enemies part of the deal. We should address this before we confront Secretus and she joins him against us."
Surraruthru stares at Thurra as he finishes.
Surraruthru
AC: 32+6
Thurra dusts herself off and sends to you, 'I have no obligation to aid you in battle, only to guide you.'
"I'm aware, and said as much. But you turning on us once we find Secretus is something to be addressed. After all, delivering multiple agents of Aurora might just be enough to earn the forgiveness of a Daemon Lord for ousting him in the first place. May earn quite a chunk of reputation as well, if played off as part of a cunning plan."
Surraruthru
AC: 32+6
Sylvie drifts down, "You know what will happen if you betray us. Will you betray us like Surraruthru said, or in any way we would consider it?"
> roll 1d20+53 intimidation (+23 inspiration, +5 circumstance)
<Kobot> Koaway rolled 1d20+53 intimidation (+23 inspiration, +5 circumstance) --> [ 1d20=7 ]{60}
Something in what Sylvie says makes the daemon draw back, 'I will not,' she hisses in all your minds, to which Sylvie nods.
"She's telling the truth."
Surraruthru chuckles.
"She's been exceedingly trustworthy so far... For a daemon. I'm impressed. We'll have to do what we can to help spread that part of your reputation around. But for now, let us continue."
Surraruthru
AC: 32+6
