I have Water Breathing (Ex): A Faerie Dragon can breathe underwater indefinitely and can freely use its breath weapon, spells, and other abilities while submerged. Other than that, I can hold my breath?
So noted.
You summon the creatures but nothing happens.
K:A check.
> roll 1d20+34 K:A
<Serith> Iddy roll for Serith < 49 > [d20=15]
Surraruthru can tell something's interdicting his summons. Can't tell what from this end of it, but odds are summoning anything is going to fail.
Surraruthru casts Disintegrate directly upwards, hoping to be able clear a cavity through and above whatever river of lava is above him.
How close are aiming in regards to the lava flow?
I'm tying to get as close to the ceiling as I can and cast directly up, hoping it clears through the lava and a small cavity above the lava river.
So like it goes through the lava and hits past it or hits the lava and also gets some other stuff with it?
Goes through the lava and hits past/through it. Trying to make it so I can fly above the lava river above me.
Lava and stone vanish in a 10ft cube above you. You see the lava chute extends higher than that, lava still pouring down after. Bought you some more vertical space, though the air's starting to become gassy and unpleasant to breathe.
#520
Surraruthru takes a moment to cast Superb Dispelling, hoping to knock out whatever is in the area blocking his magic!
Superb Dispelling, CL 30.
Maximum bonus of +40.
> roll 1d20+39 Superb Dispelling
<Serith> Iddy roll for Serith < 52 > [d20=13]
Surraruthru
HP: 291/296
AC: 32+6
Init: +12, Touch Atk: 29
Active: Mindblank (CL25), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20)
Passive: Improved Evasion, Diamond Body, True Seeing, Detect Magic, Moment of  Prescience, Energy Immunity (Fire)
Hits up to CL41. Impressive.
Lava continues to fall as everything shakes. Magic shatters all around you, crumbling apart in ethereal shapes of blue fire.
Surraruthru focuses again, casting Wish, "I wish Kashca, Ebony, Sylvie, and myself were teleported together to the most advantageous place in Secretus' domain!"
Surraruthru
HP: 291/296
AC: 32+6
Kascha, just FYI. Not Kashca.
You cast your wish and reality splits around you. You appear before a swirling black portal floating in the void, nothing around you anywhere save for the portal.
Surraruthru sighs in exasperation, since absolutely nothing seems to go his way on this trip, and looks around briefly before studying the portal.
