> roll 1d20+4 brains
<Plushie_Mushroom_Ithea> Kotono roll for Plushie_Mushroom_Ithea < 8 > [d20=4]
Init is Surraruthru (25) > Brains (8)
Open.
Surraruthru winces at the sound, snarling at the brains before casting a Lesser Orb of Sound at the nearest one!
Orb of Sound, Lesser, CL 25
> roll 5d6
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 18 > [d6=1,2,6,4,5]
The brain is hit and scrambled by the noise, but still overall intact. Just a bit mixed up and burst.
The sound gets louder and...
Are you warded from mind-affecting right now?
Mindblank at CL 25
Surraruthru
HP: 291/296
AC: 32+6
Init: +12, Touch Atk: 29
Active: Mindblank (CL25), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20)
Passive: Improved Evasion, Diamond Body, True Seeing, Detect Magic, Moment of  Prescience, Energy Immunity (Fire)
Nothing happens, Surraruthru's wards holding.
Go.
Surraruthru launches an Acid Arrow at the brains!
Acid Arrow, CL 25, Duration: 6 Rounds
> roll 2d4
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 5 > [d4=3,2]
Surraruthru
HP: 291/296
AC: 32+6
The acid arrow sizzles on the brain, eating away at it slowly. The screams continue in vain meanwhile, pounding futilely against your wards.
Go.
Surraruthru decides to play the long game, studying the brains while the acid does its work.
Do you want me to just roll all 6 rounds of damage for it?
Surraruthru
HP: 291/296
AC: 32+6
Just roll this round's for the moment.
> roll 2d4
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 7 > [d4=3,4]
Surraruthru
HP: 291/296
AC: 32+6
The acid sizzles - and the door is thrown open.
The creature that steps out is ten feet tall, shambling and hunched over. Fat, bloated limbs of gray flesh, cracking in places and oozing blood. Despite all the fat on its arms and legs, it is stick thing from the torso to the neck, bony and its ribs showing. It merely has a nub of flesh for a head, no face at all. In one bleeding hand it carries a whip, which it cracks menacingly.
Joining init.
> roll 1d20+10 init
<Plushie_Mushroom_Ithea> Ko-NitoriisLezard roll for Plushie_Mushroom_Ithea < 22 > [d20=12]
Init is Surraruthru (25) > Bloated Nightmare (22) > Brains (8)
Go. Roll acid damage for this round as well.
Surraruthru stares at the monstrous newcomer and takes a 5 foot step back, trying to angle himself so that he can hit the monster and brains as much as he can while he casts Greater Shout!
Greater Shout, CL 25, DC 26, allows Save/SR
Stone, crystal, and metal objects in the area take 20d6 points of damage.
Creatures holding vulnerable objects can attempt Reflex saves to negate the damage.
Objects that survive the spell's primary effect are not subject to the secondary effect.
The spell's secondary effect is a cone of sound.
Creatures within the cone take 10d6 points of damage, and are stunned for 1 round and deafened for 4d6 rounds.
A successful Fortitude save negates the stunning and halves both the damage and the duration of the deafness.
Any brittle or crystalline object or crystalline creature takes 1d6 points of damage per caster level (maximum 20d6).
Creatures holding fragile objects can negate damage to them with successful Reflex saves.
> roll 10d6 Sonic
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 37 > [d6=2,4,4,2,5,6,3,4,5,2]
> roll 2d4 Acid
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 6 > [d4=4,2]
Surraruthru
HP: 291/296
AC: 32+6
> roll 1d20+25 CL Check
<Plushie_Mushroom_Ithea> Iddy roll for Plushie_Mushroom_Ithea < 39 > [d20=14]
> roll 1d20+19 Fortitude vs 26
<Kobot> Kotono rolled 1d20+19 Fortitude vs 26 --> [ 1d20=11 ]{30}
The scream hits the brains, scrambling them. The injured one falls apart into dead meat, while the others leak green fluid all over.
The bloated thing before you merely  keeps going, undeterred despite the blast of power. It lashes out where it is, whip extending farther than it should, the tip of it aimed at your face.
> roll 1d20+24
<Kobot> Kotono rolled 1d20+24 --> [ 1d20=11 ]{35}
But Surraruthru is fast enough to jerk back, narrowly missing the attack altogether.
Surraruthru's up. Go.
