"I expect that was Moore. Let's do a quick check for treasure and head after him."
Surraruthru searches for treasure before heading off!
> roll 1d20+27 Search Serith
<Serith> Iddy roll for Serith < 46 > [d20=19]
All you find is a level, already pulled. As you do this, Moore floats back, invisible.
"Oh, hey!" Moore waves, turning back visible. "Sorry, I didn't think it was actually going to do that... I misunderstood the message, right flat."
"Well, it was bound to happen, to be honest. We just need to find the way out. What have you seen so far?"
"Down here are three paths, but one is blocked with a grate." Moore explains. "The left leads out and to some sort of sky with a path that you can't fly in and I hadn't explored the second before we were united by fate."
In the interests of refreshing, there's a door to the south in the throne room y'all are in.
"Well, let's check out the door here before heading down to the branches."
Don't try to trick us! The hidden passage is clearly the way to more treasure! Or is that a ruse, and the hidden passage simply leads further on?? YOU SCOUNDREL! Iddy sees through your lies...
Moore nods. "All right."
Rather predictably, the door is locked. Finnegan mutters, "Damn slaad is trying to make me need new boots. Step back."
"Why not just stab it?" Moore asks. "Or is that too insulting to merit?"
"Breaking down doors with Val's a lot less efficient than a good kick," Finnegan says, rearing back and kicking the door open.
> roll 1d20+8
<Kobot> Sunshine_Ko rolled 1d20+8 --> [ 1d20=17 ]{25}
It pops open. Ahead is a crumbling hall. Sunlight comes in from cracks and holes in the roof and patches of the floor are gone. Where the floor's gone grass grows. Ahead is a T intersection, halls going to the right and to the left. In the center of the T intersection a life-size statue of a gray slaad sits. Even from here you can tell it's an exquisite work.
"Fair enough." Moore says with a smile. Moore flies over to the slaad statue to inspect it.
Take 10 on Appraise for 32 and 47 on Spot and 32 on Search as needed.
It's a statue of a slaad and looks like excellent work. The slaad statue stares straight ahead. Nothing unusual is noted about it otherwise.
