The final door isn't hot to the touch or anything like that. It also doesn't look to be locked.
Moore opens it, but hides behind the door as he does anyway. No sense in getting surprised.
Within this small room is a switch on the back wall. A black dog sleeps on the floor before it, curled up and not reacting to your presence.
Aww. Well, this seems obvious, but Moore will try anyway. He turns invisible and will fly over to hit the switch, doing so as quietly as he can.
Take 10 for 31 on Move Silently.
The dog doesn't stir as you flip the switch.
When you flip the switch, the dog wakes up, yawns and stretches. It then paces about, slowly morphing into a door, which takes its place on the eastern wall.
Moore turns visible once again. "I was not expecting... ...Well, let's see what else we find." He says as he goes to the new, eastern door to open it.
Annoyingly, it's yet another locked door. There's even a keyhole this time.
Ah! Finally! The time is nigh!
Moore takes out the key they just got from the slaad and tries it!
No good. The iron key does not work.
"I'm thinking the iron key needs to be applied to that transmuting puzzle we found earlier. A metal type for each level, perhaps. Iron opens doors on the first level, silver the second, and so on."
I can't remember if we got another key? I think we did.
We got the silver key. You may as well try that one.
Okay, if you're going to try it do so.
"Perhaps the silver key?"
Surraruthru retrieves said key and attempts to open the door with it!
It works. The silver key falls about into ash as the door is opened. Within the door is a small room. On a hook on the wall is a gold necklace and beyond that is a glowing circle of green light.
Same color as the other circle of green light we found before?
