"You haven't challenged us yet, sir!" Moore calls out, all around him. "I hope this is a a better show of what you can muster!"
Inspire Courage, +14 to weapon and damage rolls and fear and charm saves, and an additional +2 to attack rolls on top of that.
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Create Magic Tattoo (CL25), Create Magic Tattoo (CL25), Greater Mighty Wallop (CL25), Energy Absorption (CL28), Tyche's Touch (+3) (CL 24)
Bonuses: +1 morale attack and will saves, immunity to fear and poison, +1 luck attack rolls, +2 competence attack rolls, +2 size category for bludgeoning and unarmed weapons, resistance 10 to all elements
HP: (14)269/277
AC: 47, 27 touch
22/24 Bardic music uses (0/3 left from Refrain)
Spells:
0th - 4/7 (DC 21)
1st - 7/7
2nd - 7/7
3rd - 6/6
4th - 6/6
5th - 5/6
6th - 5/5
7th - 5/5
8th - 1/1
Favored Soul:
0th - 9/9
1st - 9/9
2nd - 9/9
3rd - 8/8
4th - 7/8
5th - 8/8
6th - 6/6
Pre-loading Resist Energy to Tapestry: Fire/Cold/Acid/Sonic
Casting the following into the Tapestry (everyone gets these):
Create Magic Tattoo, CL 25, 24 Hour Duration.
+1 Luck Bonus on Attack Rolls.
+2 Competence Bonus on Attack Rolls.
Mighty Wallop, Greater, CL 25, 25 Hour Duration.
+2 Size Category to Bludgeoning/Unarmed Weapons.
Mage Armor, Greater, CL 25, 25 Hour Duration.
+6 armor bonus to Armor Class.
Energy Absorption, CL 28, 28 Hour Duration.
The subject gains resistance 10 against all five energy types: acid, cold, electricity, fire, and sonic.
As an immediate action, the subject can cause the spell to absorb the power of a single energy-based attack. The subject gains immunity to any energy types used in that attack (but only for that attack), and also heals a number of points of damage equal to 1/2 the damage the effect would normally have caused.
Finnegan'll hold for Surraruthru here.
Go Surraruthru.
Bardsong+14 attack/damage/fear saves
Finnegan
HP: 342/342
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Create Magic Tattoo (CL25), Create Magic Tattoo (CL25), Greater Mighty Wallop (CL25), Energy Absorption (CL28), Share Talents (CL13)
Bonuses: +1 morale attack and will saves, immunity to fear and poison, +1 luck attack rolls, +2 competence attack rolls, +2 size category for bludgeoning and unarmed weapons, resistance 10 to all elements, +2 swim checks.
[/quote]
[/quote]
Surraruthru begins casting a spell, concealing it with his skill, and launches the spell from his mouth!
Disintegrate, CL 25, Conceal Spellcasting Skill Trick
> roll 1d20+25 CL
<Rei-chan> Iddy rolled : 1d20+25 CL --> [ 1d20=10 ]{35}
> roll 40d6 Disintegrate
<Rei-chan> Iddy rolled : 40d6 Disintegrate --> [ 40d6=140 ]{140}
Surraruthru
HP: 344/344+5(Temp)
AC: 62 = 38+20+4 (Deflection)
Init: +13, Touch Atk: 29, +4 to Attack Rolls
Active: Epic Mage Armor (CL 25), Mindblank (CL 28), Fortunate Fate (CL15), Planar Tolerance (CL7), Moment of Prescience (CL 25), Energy Absorption (CL 28)
Passive: Improved Evasion, Diamond Body, True Seeing, Detect Magic, Water Breathing, Magic Tattoo (+1 Luck to Attack), Magic Tattoo (+2 Competence to Attack), Mighty Wallop (Greater), Heroes' Feast (+1 Morale to Attack Rolls & Will Saves, Immunity to Fear, 1d8+1 Temp. HP.)
You can cast a spell without revealing that you are doing so. Make a Sleight of Hand check as part of the action used to cast the spell, opposed by the Spot checks of onlookers. If you are successful, an observer can't tell that you're casting a spell. That observer cannot make an attack of opportunity against you for casting, nor can it attempt to counter your spell.
Forgot the SoH check;
> roll 1d20+12 SoH
<Rei-chan> Iddy rolled : 1d20+12 SoH --> [ 1d20=10 ]{22}
Okay, cool. Make your ranged touch attack roll for disintegrate.
I'm not sure if Moore's bonus applies to Touch Attack or not. If so, add 14.
> roll 1d20+29+4 Touch Attack
<Rei-chan> Iddy rolled : 1d20+29+4 Touch Attack --> [ 1d20=6 ]{39}
> roll 1d20+13
<Rei-chan> Kotono rolled : 1d20+13 --> [ 1d20=3 ]{16}
Your beam hits one of the tentacles and completely obliterates it. Nothing is left of that one and soon the others crumble.
That worked out well. Free act.
"...I feel like we're constantly being underestimated." Moore says. He shrugs and decides to continue down for the time being, surely there has to be a bottom to this, doesn't there?
"Or they're wearing us down," Finnegan remarks, "That could be it."
"If it's a case of being worn down, then why not just hit us with something harder?" Moore considers for a moment as he flies. "I suppose you can look at it as using this as a testing ground for us, to determine how best to show us his ardor. It's probably not very interesting for him if people come in and instantly 'lose,' as it were."
"Might be. Damn slaad's awfully methodical if he's doing that. Out of character for his race." Finnegan follows you.
"I've found that when dealing with chaotic things, one must occasionally expect something to actually be logical and thought out." Moore says with a laugh. "It seems impossible, but sometimes when it comes to something chaotic, the pattern can in fact be quite ordered all about."
