I dunno, about 70 feet? That puts one in the tunnel with a second squeezing in. Should prevent multiple from having line of attack on us?
One additional question; if I decide to summon that's huge, the size chart lists that as 16 ft - 32 ft. Since the tunnels is only 50 ft, can I control which size I summon? Like I decide I want 16 ft ones so I can have multiple?
Depends on the creature summoned. Of course, a creature has to be summoned on something that can support them, so bear that in mind.
Roll init and we'll start on this then.
[12:32] <Nephrite> roll 1d20+31 init
[12:32] <Serith> Nephrite roll for Serith < 42 > [d20=11]
> roll 1d20+13+11 Init
<Serith> Iddy roll for Serith < 42 > [d20=18]
> roll 1d20+24 Finnegan
<Serith> Kotono roll for Serith < 31 > [d20=7]
> roll 1d20+20 They're baaaack
<Serith> Kotono roll for Serith < 30 > [d20=10]
Init is Moore = Surraruthru (42) > Finnegan (31) > Tentacle Abominations (30)
Y'all won init completely so go ahead and go, position yourselves as you please.
Surru can do his thing and then I'll buff everyone!
Surraruthru begins chanting, hovering above the oncoming rush of weird gigantic eyeball and tentacle monsters, letting loose his spell!
Time Stop, CL 25
> roll 1d4+1 Time Stop
<Serith> Iddy roll for Serith < 2 > [d4=1]
Surraruthru
HP: 344/344+5(Temp)
AC: 74 = 38+20+4 (Deflection)+12 (Dodge/Moore)
Init: +13, Touch Atk: 29, +4 to Attack Rolls
Active: Epic Mage Armor (CL 25), Mindblank (CL 28), Fortunate Fate (CL15), Planar Tolerance (CL7), Moment of Prescience (CL 25), Energy Absorption (CL 28)
Passive: Improved Evasion, Diamond Body, True Seeing, Detect Magic, Water Breathing, Magic Tattoo (+1 Luck to Attack), Magic Tattoo (+2 Competence to Attack), Mighty Wallop (Greater), Heroes' Feast (+1 Morale to Attack Rolls & Will Saves, Immunity to Fear, 1d8+1 Temp. HP.)
Okay, cool. Two rounds of timestop, what are you doing in it?
As time slows and then freezes for him, Surrraurthru begins casting more spells!
1st Round: Summon Monster IX, CL 25. Summoning from the VIII: Storm Elemental, Huge
> roll 1d4+1 Summon Monster 9/8
<Serith> Iddy roll for Serith < 4 > [d4=3]
That gives me 4 Huge Storm Elementals.
I'll summon them ahead/below us, between us and the oncoming monsters.
2nd Round: Wall of Force, Sculpted, CL 25.
Positioning this between our group and the Storm Elementals and monsters. Sculpting it so that it's a flat disc between us, capping the tunnel, but with a hole big enough for us to pass through (so one Finnegan can slip through).
General intent is to let the four Storm Elementals go insane with their Sonic/Electricity explosions, grinding down the monsters and healing each other, while we take potshots and buff as needed through the hole, while the wall protects us from the explosions.
Surraruthru
HP: 344/344+5(Temp)
Okay.
How far are you spacing the storm elementals apart and how big are they? The flavor for them should give details.
Where exactly are you putting the hole in the wall? How big is it?
The Monster Manual III just lists them as Huge; the size chart says that's 16-32 ft. I'd want them to be roughly 18 ft. That's big enough to have three of them in a triangle formation as the first line with a fourth above and centered. With a 60 ft radius on their explosions, they should cover each other.
The Wall of Force will be right under our feet, so we can stand on it if we want. the hole should be center and about 3-4 feet wide. That should be big enough for Finnegan to slip through.
