"If we need to run, I have ways." Moore says with a nod.
The elementals will head towards the monsters, unless they're already in range?
Their AOE is a full round, so yeah, unless they're already inside of 60ft to the monsters.
They aren't, it's a couple of of hundred feet to the bottom and they weren't in range.
In this case init, I'll describe after.
Add 13 to these if Moore's range allows.
> roll 1d20+13 Init
<Serith> Iddy roll for Serith < 19 > [d20=6]
> roll 1d20+4 Elemental Init
<Serith> Iddy roll for Serith < 23 > [d20=19]
[20:46] <Nephrite> roll 1d20+31
[20:46] <Serith> Nephrite roll for Serith < 47 > [d20=16]
> roll 1d20+23 Finnegan
<Serith> THECOLDFINALXORNOFFSEASON roll for Serith < 39 > [d20=16]
> roll 1d20+20
<Serith> THECOLDFINALXORNOFFSEASON roll for Serith < 30 > [d20=10]
Finnegan should be +24, so 40 for him.
Init is Moore (47) > Finnegan (40) > Horrors (30) > Elementals (23) > Surraruthru (19)
The strange creatures immediately begin to thrash about all around, as tendrils fly.
Tentacles are rising from the mud, all around Surraruthru. As this happens...
Moore.
Moore casts a spell to summon the same elementals as Surraruthru brought in!
[21:05] <Nephrite> roll 1d4+1 More Storm Elementals
[21:05] <Serith> Nephrite roll for Serith < 5 > [d4=4]
Summoning these 90 ft ahead of us towards the Horrors. I don't think they're actually in range to do anything though, and if not they'll just double-move fly 200 (100+100) towards the middle between Surru and the horrors.
They are, they're all moving around that range. You could attack them with thunder and lightning or move into melee.
Moore commands the elementals to create a storm of sound of fury! It may not be as potent as the other elementals was, but it may still frighten the creatures with all the noise!
Okay. In that case I'll go with thunderbolts and lightning!
[21:13] <Nephrite> roll 5#4d6 DC 18 Fort (I really doubt they can fail this) Sonic
[21:13] <Serith> Nephrite roll for Serith < 18, 11, 11, 10, 18 >
[21:14] <Nephrite> roll 5#8d6 DC 18 Reflex (I really doubt they can fail this either) Lightning
[21:14] <Serith> Nephrite roll for Serith < 31, 29, 34, 24, 32 >
> roll 4#1d20 yeah, only fail on a 1
<Rei-chan> THECOLDFINALXORNOFFSEASON rolled : 4#1d20 yeah, only fail on a 1 --> [ 1d20=15 ]{15}, [ 1d20=15 ]{15}, [ 1d20=6 ]{6}, [ 1d20=5 ]{5}
<Rei-chan> THECOLDFINALXORNOFFSEASON rolled : 4#1d20 yeah, only fail on a 1 --> [ 1d20=6 ]{6}, [ 1d20=12 ]{12}, [ 1d20=14 ]{14}, [ 1d20=5 ]{5}
Roll damage.
I did roll the damage in the above post! It's 34 Sonic and  75 Lightning since they made the save.
Oh wow, I misread that. Warning: Do not DM with a head cold.
> roll 1d20
> roll 1d20
<Rei-chan> THECOLDFINALXORNOFFSEASON rolled : 1d20 --> [ 1d20=5 ]{5}
<Rei-chan> THECOLDFINALXORNOFFSEASON rolled : 1d20 --> [ 1d20=12 ]{12}
Two more saves since I undercut it by one each. Wow.
Thunder bursts everywhere, the creatures going crazy from the fury. Finnegan stays on guard, not wading in for now.
Not a whole lot Finnegan can do right away. Horrors are up.
The tentacles around Surraruthru strike, rising up to try and ensnare him.
> roll 1d20+44 (+4 ???)
<Rei-chan> Kotono rolled : 1d20+44 (+4 ???) --> [ 1d20=13 ]{57}
AC, Surraruthru?
62 AC.
Surraruthru
HP: 344/344+5(Temp)
AC: 62 = 38+20+4 (Deflection)
Init: +13, Touch Atk: 29, +4 to Attack Rolls
Active: Epic Mage Armor (CL 25), Mindblank (CL 28), Fortunate Fate (CL15), Planar Tolerance (CL7), Moment of Prescience (CL 25), Energy Absorption (CL 28)
Passive: Improved Evasion, Diamond Body, True Seeing, Detect Magic, Water Breathing, Magic Tattoo (+1 Luck to Attack), Magic Tattoo (+2 Competence to Attack), Mighty Wallop (Greater), Heroes' Feast (+1 Morale to Attack Rolls & Will Saves, Immunity to Fear, 1d8+1 Temp. HP.)
