That's all I can do at current, yes. But hey, I'm not dead! Yet!
Init is Moore (46) > Horror (38) > Surraruthru (25) > Finnegan (24)
The horror is relentless - and you surge up, through the last of the tunnel far faster than you rose up. You're in the open air now and rising up fast, everything a blur around you. The green tentacles are now free and starting to come your way, while tentacles holding Moore...
> roll 1d20+60 CMD Moore
<Serith> Zombie_Ko roll for Serith < 80 > [d20=20]
You're pulled down into a vent into the creature, flesh closing in behind you. Its' pitch black in here, as inside you can see jagged, saw-like teeth and pores that ooze hissing green acid. They begin to close in on you, chewing and dissolving your flesh.
> roll 15d6 chewing damage
<Serith> Zombie_Ko roll for Serith < 59 > [d6=4,2,3,4,6,4,3,5,4,3,6,3,6,4,2]
> roll 10d6 acid damage
<Serith> Zombie_Ko roll for Serith < 37 > [d6=4,6,6,4,3,1,5,5,1,2]
DR applies to the first and acid resistance to the second.
What's that put your HP at, Moore?
I'm using the secondary effect from Energy Absorption to nullify the acid damage and heal 18 instead. with that in mind it's at 197.
Noted.
Above Finnegan curses and shouts, "We  need to finish this damn thing off!"
Surraruthru, go.
#769
Surraruthru dives into the meat of the horror, empowered now by both his own magic and Moore's, he's confident he can gouge his way through the monster's hide.
> roll 1d6 Flailing Strikes
<Serith> Iddy roll for Serith < 3 > [d6=3]
> roll 1d20+28+7 Unarmed
> roll 1d20+25+7 Unarmed
> roll 1d20+18+7 Unarmed
> roll 1d20+13+7 Unarmed
<Serith> Iddy roll for Serith < 52 > [d20=17]
<Serith> Iddy roll for Serith < 33 > [d20=1]
<Serith> Iddy roll for Serith < 33 > [d20=8]
<Serith> Iddy roll for Serith < 25 > [d20=5]
> roll 1d20+23+7 Bite
> roll 1d20+23+7 Claw
> roll 1d20+23+7 Claw
<Serith> Iddy roll for Serith < 48 > [d20=18]
<Serith> Iddy roll for Serith < 33 > [d20=3]
<Serith> Iddy roll for Serith < 31 > [d20=1]
> roll 1d20+28+7 Flailing Stirkes
<Serith> Iddy roll for Serith < 37 > [d20=2]
<Serith> Iddy roll for Serith < 46 > [d20=11]
<Serith> Iddy roll for Serith < 47 > [d20=12]
> roll 7#3d8+10 (Unarmed)
> roll 1d6+10 (Bite)
> roll 2#1d4+10 (Claw)
<Serith> Iddy roll for Serith < 26, 26, 14, 26, 18, 29, 16 >
<Serith> Iddy roll for Serith < 12 > [d6=2]
<Serith> Iddy roll for Serith < 11, 11 >
Edit, with Moore's bonuses and in attack order:
69 Unarmed 1
50 Unarmed 2(But a 1 so still failure)
50 Unarmed 3
42 Unarmed 4
65 Bite
50 Claw 1
48 Claw 2(But a 1 so still failure)
54 Flailing Strikes 1
63 Flailing Strikes 2
64 Flailing Strikes 3
Damages:
Unarmed: 43, 43, 31, 43, 35, 46, 33
> roll 7#2d6 Holy Property (Forgot this)
<Serith> Iddy roll for Serith < 10, 4, 6, 2, 6, 5, 8 >
Bite/Claw: 29, 28, 28
Surraruthru
HP: 344/344+5(Temp)
AC: 78 = 38+20+4 (Deflection)+12(Moore)+4(sacred)
Init: +13, Touch Atk: 29, +4 to Attack Rolls
Active: Epic Mage Armor (CL 25), Mindblank (CL 28), Fortunate Fate (CL15), Planar Tolerance (CL7), Moment of Prescience (CL 25), Energy Absorption (CL 28), Celestial Valor (CL 25)
Passive: Improved Evasion, Diamond Body, True Seeing, Detect Magic, Water Breathing, Magic Tattoo (+1 Luck to Attack), Magic Tattoo (+2 Competence to Attack), Mighty Wallop (Greater), Heroes' Feast (+1 Morale to Attack Rolls & Will Saves, Immunity to Fear, 1d8+1 Temp. HP.)
You rip and you tear. So invigorated by Moore's music and commands, you're able to rip into the flesh of the horror. It's hard - damnably hard - but you manage to draw blood and tear away slaad-flesh. You dig into it, ripping into two large cavities, teeth filled and half full of bubbling acid. The beast's entire body quivers at this abuse.
"Keep on it!" Finnegan shouts, "Get it to stop!"
> roll 1d20+56 (+1 luck, +2 competence, +6 sacred, +20 Moore, -20 PA)
<Serith> Zombie_Ko roll for Serith < 70 > [d20=14]
> roll 1d20+51 (+1 luck, +2 competence, +6 sacred, +20 Moore, -20 PA)
<Serith> Zombie_Ko roll for Serith < 69 > [d20=18]
> OOC: Taking 10 on the third for 56.
> roll 1d20+46 (+1 luck, +2 competence, +6 sacred, +20 Moore, -20 PA, +5 weapon supremacy)
<Serith> Zombie_Ko roll for Serith < 62 > [d20=16]
> roll 1d8+87+3d6+1d6
> roll 1d8+87+3d6+1d6
> roll 1d8+87+3d6+1d6
<Serith> Zombie_Ko roll for Serith < 106 > [d8=3][d6=5,4,5,2]
<Serith> Zombie_Ko roll for Serith < 102 > [d8=1][d6=5,2,2,5]
> roll 1d8+87+3d6+1d6
<Serith> Zombie_Ko roll for Serith < 105 > [d8=2][d6=3,2,6,5]
<Serith> Zombie_Ko roll for Serith < 97 > [d8=1][d6=4,1,1,3]
Finnegan leaps past tentacles and parries them with Val, knocking them away as he leaps for the thing's mouth. He lands in the tentacles there and stabs down, over and over again, acid and blood pouring out from the wounds. The beast screams, a too high pitched sound as you continue to race up.
Moore.
Moore takes a moment to teleport himself back out again and to the others.
This is presuming that it didn't drag him more than 30 ft down, anyway.
"That was awful." He mutters, taking a moment to focus all his attention onto the creature. That is NOT happening again.
Using Melody of Misfortune, -5 penalty on all attack, skills and ability checks. If other parts of it are counted as individual entities they are entitled to a Will save against DC 31 to reduce it to -1.
Does it allow a Will save for the main target?
No, but here's the text just for your reference so you don't have to go look it up: Melody of Misfortune (Su): This ability functions as Fated Failure (which is the -5 version), except it also targets all foes within 30 ft of the Fatesinger that he is aware of. Additionally, the main target of the Melody does not receive a Will save as with Fated Failure as the power of the melody focuses mostly on that foe.
I meant the fated failure part, but I looked it up myself.
> roll 1d20+26
<Serith> Zombie_Ko roll for Serith < 38 > [d20=12]
Your melody settles over the battlefield, a discordant sound that heralds doom and defeat. As it happens you rush up, into clouds. Purple clouds that crackle with green ice, clustering in strange geometric patterns. You hardly have a chance to watch as you fly through the cloud, as the green tentacles come for all of you.
<Serith> Zombie_Ko roll for Serith < 67 > [d20=20]
> roll 1d20+47 (-1 fated failure, at this point it's clear that it's immune to the negative levels Finnegan's dishing out) Surraruthru
<Serith> Zombie_Ko roll for Serith < 49 > [d20=2]
> roll 1d20+47 (-1 fated failure, at this point it's clear that it's immune to the negative levels Finnegan's dishing out) Finnegan
<Serith> Zombie_Ko roll for Serith < 60 > [d20=13]
> roll 1d20+47 (-1 fated failure, at this point it's clear that it's immune to the negative levels Finnegan's dishing out) Moore crit?
<Serith> Zombie_Ko roll for Serith < 59 > [d20=12]
Touch ACs, all? This is a touch attack, so bear that in mind.
Even if the bonuses stacked with touch I don't think it'd matter in my case.
#776
53 I think.
[22:06] <Nephrite> roll 1d20+41+12+4 (+12 greatness, +4 celestial valor) mettle
[22:06] <Serith> Nephrite roll for Serith < 66 > [d20=9]
<IronDragoon> roll 1d20+28+12+4 Moore/Celestial Valor
<Serith> IronDragoon roll for Serith < 64 > [d20=20]
