Boots on the ground (Moore)
Adrian takes a defensive position.
Total defense for +4 dodge to armor class.
"Giving up?" The hooded creature says, twin beams this time going exclusively for Adrian.
> roll 1d20+41 only misses on a 1 Rei
<Rei-chan> Koaway rolled : 1d20+41 only misses on a 1 Rei --> [ 1d20=8 ]{49}
<Rei-chan> Koaway rolled : 1d20+41 only misses on a 1 Rei --> [ 1d20=6 ]{47}
> roll 1d20+25 vs 34 Adrian Rei
<Rei-chan> Koaway rolled : 1d20+25 vs 34 Adrian Rei --> [ 1d20=12 ]{37}
<Rei-chan> Koaway rolled : 1d20+25 vs 34 Adrian Rei --> [ 1d20=1 ]{26}
Only one gets through.
> roll 36d6
<Rei-chan> Koaway rolled : 36d6 --> [ 36d6=149 ]{149}
Adrian bursts into flames anew, grunting in pain from them. He's holding his ground mostly, a few desultory slashes at the barrier that springs up with every attack.
Go.
+8 dodge from heroics, +4 from defending.
Adrian
HP: 159/358 (fast healing 1)
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Surge of Hope (CL25)
Bonuses: +1 morale attack and will saves, immunity to fear and poison, +4 morale to attack rolls, saving throws, ability checks and skill checks, immunity to fear, +4 morale saving throws, +4 sacred to saving throws, -1 each save
#152
Moore flies over and next to Adrian as he puts a hand on him!
Heals 150 HP.
He clears his throat and utters more words of encouragement that empower them both! "Come on, surely you can do better than that one trick?" Moore says, reappearing.
Adrian and Moore get +6 dodge to AC and +6 morale to saves.
EDIT: OOC I forgot that Moore also has Spell Turning on him, but since the spell didn't penetrate his SR I doubt it matters.
Active Spells:  fortunate fate (CL15), planar tolerance (CL7), Superior Resistance (CL 24), Conviction (+4 saving throw), Tyche's Touch (+4 sacred saving throw), Haste (+1 ac, dodge, reflex, 30 move), surge of hope
HP: (56)289/311
AC: 56, 32 touch
22/25 Bardic music uses, Refrain 0/3
Spells:
0th - 7/7 (DC 21)
1st - 7/7
2nd - 7/7
3rd - 6/6
4th - 6/6
5th - 3/6
6th - 5/5
7th - 5/5
8th - 2/2
Favored Soul:
0th - 9/9
1st - 9/9
2nd - 7/9
3rd - 8/8
4th - 8/8
5th - 8/8
6th - 6/7
7th - 4/4
+1 Luck Bonus on Attack Rolls
Do you have any flame resistance?
Adrian
HP: 310/358 (fast healing 1)
[/quote]
Yes, Fire Res 10 from Energy Absorption
Touching someone on fire isn't wise, but your protections save the day.
Adrian's injuries heal as he defends himself. The robed creature glides back a bit, "Waiting for reinforcements, I imagine," he announces aloud, before pointing at the tow of you, "Fine, live a little longer."
Ref saves.
#156
[14:12] <Nephrite> roll 1d20+55 evasion (+4 tyche's touch, +6 inspire)
[14:12] <Rei-chan> Nephrite rolled : 1d20+55 evasion (+4 tyche's touch, +6 inspire) --> [ 1d20=20 ]{75}
EDIT: Oh! Is this a spell-turnable spell?
Yes, as a matter of fact.
The spells surround the two of you but are promptly reflected back at the hooded creature, who immediately tries to dodge.
> roll 1d20+29 evasion 1
<Rei-chan> Koaway rolled : 1d20+29 evasion 1 --> [ 1d20=12 ]{41}
> roll 1d20+29 evasion 2
<Rei-chan> Koaway rolled : 1d20+29 evasion 2 --> [ 1d20=12 ]{41}
He just barely clears both of them - shimmering black spheres that would have completely entrapped him.
Go Moore.
Let's try and get rid of that magic again!
Targeted dispel at the creature, just to be clear.
[14:34] <Nephrite> roll 1d20+20 dispel
[14:34] <Rei-chan> Nephrite rolled : 1d20+20 dispel --> [ 1d20=13 ]{33}
Again you dispel him, but again nothing happens. Adrian holds his defense as he steps back, "...hmph." The creature grunts, before vanishing.
"Adrian!" Stille's voice, as he flies up with Mirima and a squad of lillends. He's approaching from behind and below, leading the forces.
Free act.
Taking 10 on Spellcraft for 55 to see if I can figure out what direction he went in or something along those lines.
No dice there, unfortunately. It's greater teleport, you can tell that much, so he could be anywhere on plane.
Moore shakes his head. "No idea where he went... or who that was -- my magic didn't seem to affect him at all, so he must've been pretty strong."
"One of Taelfagn's servants, probably, or someone he hired. It felt like an assassination," Adrian admits, "Good work. Back to street level, let's not make it easy on him again."
Moore nods and flies down with Adrian after a wave to Stille.
