Boots on the ground (Moore)
Okay, counts as a restart.
Your spell wraps around you as you continue to perform. The soldiers are advancing ans then Adrian's heard in your head, 'Look ahead, a small group of air ele-' He begins, then grunts over the connection, 'Nevermind, hold your position!' An explosion rocks a building about a block away, 'Hostages will be running down the street, make sure nothing attacks them!'
No problem.
Moore looks ahead to see if there's anything obvious chasing after the hostages that he can see!
Active Spells: mind blank (CL17), fortunate fate (CL15), planar tolerance (CL7) and greater mage armor(CL5), Superior Resistance (CL 24)
HP: (11)311+16
AC: 56, 32 touch
24/25 Bardic music uses, Refrain 2/3
Spells:
0th - 7/7 (DC 21)
1st - 7/7
2nd - 7/7
3rd - 6/6
4th - 6/6
5th - 6/6
6th - 5/5
7th - 5/5
8th - 2/2
Favored Soul:
0th - 9/9
1st - 9/9
2nd - 9/9
3rd - 8/8
4th - 8/8
5th - 8/8
6th - 7/7
7th - 4/4
+1 Luck Bonus on Attack Rolls
It's a group of elves - two mature ones and three children, wearing rags. They stumble and run down the street.
Spot check since you're on watch for them, see if you can catch anything bad.
Why, that would be a Take 10 for 45 then.
> roll 1d100
<Serith> Sunshine_Ko roll for Serith < 65 > [d100=65]
Luck is with you - nothing comes and you see them run to waiting soldiers, who escort them to the ship.
'They're safe.' Moore confirms.
He continues playing his music on the harp for now.
Actually, since I seem to be spotting things, I'll also toss up a Vision of the Omniscient Eye for +10 to spot for the next 25 minutes.
So noted.
As you play, you get a message. 'Moore, this message is going to all Aurora officers. Canderella is dead. An unknown force tore her apart, the assailant was not seen except for a rippling in the air described as stretching. If you see this, send word immediately and assume a defensive pose. It has means to defeat typical sensory abilities, due to the fact it penetrating our blocking force, killed her and escaped. More information will follow as we obtain it, it does not seem to be tied to the sky issue.'
For the briefest of moments, his fingers stop dead on one of the wires on his harp.
She's going to reform somewhere, right?
She has to.
It's just like that time... when he heard KAMHOFF IS DEAD!!!
...No. No.
His fingers resume on his harp. He has to stay strong, to keep an eye out. If something like that comes for him...
For now he continues his music. He has to.
'Understood.' Is all he can manage in reply.
[13:53] <Nephrite> roll 1d20+47 Will
[13:53] <Rei-chan> Nephrite rolled : 1d20+47 Will --> [ 1d20=18 ]{65}
It's okay. Pepo didn't die, he made it home.
All of you did.
You feel dizzy for a few moments, still playing on autopilot as you cope.
All of you made it to exactly where you were meant to be.
There's a twitch in his fingers -- is he getting sore?
He shakes his head and continues to watch the streets and alleys below.
Everyone else is doing well, so he has to continue to do his part.
You're a good man, Charlie Brown
