The Twin Nephilim (Afina, Jaela)
Started by Anastasia, January 26, 2017, 02:09:28 PM
> roll 1d20+29 Hiya SR check
<Serith> Kotono roll for Serith < 42 > [d20=13]
> roll 1d20+29 Hiwa SR check
<Serith> Kotono roll for Serith < 48 > [d20=19]
They both get a total of 48 for the SR roll, so that beats your defenses there. Accidentally got non-rolled, the joy of the DM running multiple rooms at once.
The blast leaves all of you reeling, minds sluggish and will weakened. It hurts all over, your bodies screaming at you. A dozen tiny injuries, cuts and nicks, all trickling blood, leaving you wet with your lifesblood all over.
The twins take an offense stance, as if inviting blows against them. Jaela knows that trick anywhere, alright.
Initiative is Afina (46) > Sylvie (37) > Hiya = Hiwa (36) > Jaela (31) > Fenrir (24) > Garm (21) > Mirajane (15) > Dana (6)
Go Jaela.
Todo: Dana power points and Sylvie's divine casting adjusted for -8 Wisdom.
Dana
HP: 259/344 (-8 Wisdom)
Bonuses: Immunity to fear and poison, +1 morale attack rolls and will saves
Resources Used: Power Points: 282/282
Sylvie
HP: 269/369
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Mass Death Ward (CL24)
Bonuses: +1 morale attack and will saves, immunity to fear and poison.
Negative Conditions: (-8 Wisdom)
Resources Used: Zone of Revelation, 13/13 inspiration
Mirajane
HP: 296/311
Resources Used: Mass Death Ward, Mirajane's Revelation, Miracle.
Jaela tosses out a dispel of her own, musing about how much she seems to be following Afina's lead today. Then again, there are certainly worse role models!
[21:32] <@Rin> roll 1d100
[21:32] <Serith> Rin roll for Serith < 69 > [d100=69]
[21:33] <@Rin> roll 2#1d20+35 #01
[21:34] <@Rin> roll 2#1d20+35 #02
[21:34] <Serith> Rin roll for Serith < 49, 52 >
[21:34] <Serith> Rin roll for Serith < 48, 55 >
[21:34] <@Rin> roll 2#1d20+35 #03
[21:34] <Serith> Rin roll for Serith < 48, 41 >
[21:34] <@Rin> roll 2#1d20+35 #04
[21:34] <Serith> Rin roll for Serith < 37, 38 >
[21:34] <@Rin> roll 2#1d20+35 #05
[21:34] <Serith> Rin roll for Serith < 51, 47 >
[21:34] <@Rin> roll 2#1d20+35 #06
[21:34] <Serith> Rin roll for Serith < 46, 53 >
[21:34] <@Rin> roll 2#1d20+35 #07
[21:34] <Serith> Rin roll for Serith < 54, 47 >
[21:34] <@Rin> roll 2#1d20+35 #08
[21:34] <Serith> Rin roll for Serith < 43, 55 >
[21:34] <@Rin> roll 2#1d20+35 #09
[21:34] <Serith> Rin roll for Serith < 49, 46 >
[21:34] <@Rin> roll 2#1d20+35 #10
[21:34] <Serith> Rin roll for Serith < 52, 36 >
[21:34] <@Rin> roll 2#1d20+35 #11
[21:34] <Serith> Rin roll for Serith < 39, 47 >
[21:34] <@Rin> roll 2#1d20+35 #12
[21:34] <Serith> Rin roll for Serith < 50, 38 >
Then, her robes melt away as her favorite armor takes their place, and Jaela tries to call upon the Triune's guidance.
[21:39] <@Rin> roll 1d100
[21:39] <Serith> Rin roll for Serith < 29 > [d100=29]
Alas, Recitation failed.
HP: 271/490
AC: 72 =65base+1AotDP(armor max dex +8)+2Foresight+4CV, 20% miss chance (airborne creatures take a —1 penalty on attack rolls and damage rolls against you).
Full Attack (Gae Bolg, GMW, HW, K:D +5, CMT +1luck, CMT +2competence, HF +1morale, SofDP +2 attack/+3 damage, CV +4sacred attack/damage, DM, vs devils only): +60/+55/+50/+45 or +64 AoO, 2d8+61+8d6+2d6+2d6 last is goldenfire
Spells Active: Energy Absorption CL 26, Create Magic Tattoo x2 CL 26, Elemental Body/Air CL 26, Surraruthru's Stupendous Dragonskin CL 26, Agility of the Dragon Princess CL 26, Strength of the Dragon Princess CL 26, Mind of the Dragon Princess CL 26, Stoneskin CL 26,
Spell Turning CL 26, Contingency CL32, Permanency/Greater Blindsight CL32, Permanency/Mantle of Good CL33, Moment of Prescience CL23, Foresight CL25, Conviction CL29, Longstrider CL23, Righteous Halo CL28, Divine Insight CL28, Lore of the Gods CL28, Mind Blank (CL26), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Mass Death Ward CL24, Celestial Valor CL24.
Resistances and Immunities: Fire Resistance 10, Cold Resistance 10, Acid Resistance 20, Electricity Resistance 20, Sonic Resistance 20, Damage Reduction 25/Epic and Evil and Cold Iron, Spell Resistance 35 (45 vs Evil spells/permanent Mantle of Good), Immunity to Disease (normal and supernatural/magical), Immunity to Compulsion effects, Immunity to Petrification, Immunity to Sickened/Nauseated, Immunity to fear and poison/Heroes's Feast, Never surprised or flat-footed/Foresight, Immune to poison, sleep, paralysis, and stunning, and are not subject to extra damage from critical hits or flanking/Elemental Body (Air), immunity to negative energy (Mass Death Ward).
Spells Left (1-9): 8/9/9/2/9/7/8/5/7
Spells Left (10-11): 7/(3)
Saves: Fort +56, Ref +52, Will +52
-True Strike x1
-Teleport x1
-1 smite
-3 negative levels
-8 wis damage
MIRACLE x1
Magic crashes and collapses around the two, broken spells shooting off arcane energy in all directions. Great bursts of purple and blue spellfire, lightning up the sky even brighter around you. Afina has to dodge a particularly large bolt and Mirajane smoothly dives under another, as...
Fenrir and then Garm. Go.
Unbothered by their wounds or diminished capacities, the two giant fey hunting hounds howl with bloodlust and split off, darting in to tackle a giant each before peeling away to leave the immediate area clear for fireballs and the like!
Hunters howl x2, DC 28 will or shaken
[19:48] <@Ebiris> roll 1d20+38 Garm vs Hiwa
[19:48] <Serith> Ebiris roll for Serith < 42 > [d20=4]
[19:48] <@Ebiris> roll 1d20+38 Fenrir vs Hiya
[19:48] <Serith> Ebiris roll for Serith < 56 > [d20=18]
[19:48] <@Ebiris> roll 2d6+25+10d6 and dimensional anchor, Garm if hit
[19:48] <Serith> Ebiris roll for Serith < 64 > [d6=5,3,5,3,1,5,5,1,2,1,4,4]
[19:49] <@Ebiris> roll 2d6+25+10d6 and dimensional anchor, Fenrir if hit
[19:49] <Serith> Ebiris roll for Serith < 71 > [d6=1,6,1,3,6,3,5,6,5,4,2,4]
They have spring attack so won't provoke AoOs for moving against their targets. Ending up 50 feet away on either side from the twins
Afina: 207/287, glaciante's spiteful ward (CL 27 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 25), see invisibility (CL 25), greater heroism (CL 25), interplanar telepathic bond (CL 24), shield (CL 25), magic tattoo (CL 26), magic tattoo (CL 26), energy absorption (CL 26), stupendous dragonskin (CL 26), seira's agility (CL 26), seira's strength (CL 26), seira's mind (CL 26), mind blank (CL 27), stoneskin (CL 26), spell turning (CL 26), control weather (CL 27), haste (CL 25)
AC 98, spell resistance 40, blindsense 30, immunity to fire, water, earth, cold, disease, poison, fear, 50% miss chance, freedom of movement
Spell charges: 5/9/9/6/5/9/6/8/7/3/7/2
Wisdom reduced, currently 20
Fenrir: 285/370, heroes feast (CL 20), greater mage armour (CL 7), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7)
AC 42, spell resistance 25, freedom of movement, immunity to electricity, exhaustion, mind affecting, fatigue, fear, poison
Wisdom reduced, currently 22
Garm: 174/370, heroes feast (CL 20), greater mage armour (CL 7), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7)
Attack: +38 (2d6+25) +10d6 skirmish, dimensional anchor
Wisdom reduced, currently 14
Since it wasn't precisely clear even though I all but said it OOC - my fault there - the two are in gambit. +4 to hit but they trigger an AoO. You okay with that?
Yes. So they hit AC 46 for Hiwa and 60 for Hiya for reference there. Willing to take the hits.
Fenrir charges first, biting at Hiya. He manages to bite the nephilim on the wrist, and at the same time the giant swings at him with one oversized fist.
> roll 1d20+50
<Serith> Kotono roll for Serith < 64 > [d20=14]
> roll 4d10+34 and 2 Wisdom
<Serith> Kotono roll for Serith < 55 > [d10=6,1,9,5]
The blow is heavy as Hiya's wound...is simply not there.
Spot check, y'all.
[20:07] <@Ebiris> roll 1d20+43 spot
[20:07] <Serith> Ebiris roll for Serith < 63 > [d20=20]
-4 on that from wis damage so 59 sorry.
> roll 1d20+38 Mirajane
<Serith> Kotono roll for Serith < 43 > [d20=5]
> roll 1d20+16 Sylvie
> roll 1d20
<Serith> Kotono roll for Serith < 23 > [d20=7]
<Serith> Kotono roll for Serith < 17 > [d20=17]
> OOC: d20 is Dana and isn't going to matter for her anyway.
Afina's sharp eyes notice something. The moment Hiya's wrist is bit, Hiwa's wrist shimmers slightly. The wound then vanishes from Hiya entirely.
Go ahead and note if that changes any commands you'll give Garm or if he'll stick to his.
#25
"Garm, back off!" Afina calls. "Only simultaneous attacks on them both have a chance of sticking!" she adds for everyone else's benefit.
Even with his diminished wits, Garm remains wiser than most people and so immediately aborts his attack, retreating to a position opposite Fenrir on the field at the same distance so they can coordinate for later attacks. Such tactics are of course familiar from their many hunts under the Huntsmaster, even if this is a new wrinkle.
Fenrir: 245/370, heroes feast (CL 20), greater mage armour (CL 7), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7)
"Dana, wait on me," Jaela says tersely at that. "Mirajane, get big enough to match their reach."
Intent is to have Dana hold so we strike at each twin on my next go together, and for Mirajane to cast Righteous Might in preparation of hitting these dudes with me.
"Wrong," Hiya growls, more power gathering around him. As this happens, Mirajane quickly chants, "The Triune is three in one, let my body grow by three!" She increases in size, as golden light surrounds her.
Righteous might plus righteous fury as a swift. Dana holds. Afina?
Dana
Sylvie
HP: 269/369
Mirajane
HP: 296+50/311
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Mass Death Ward (CL24), Righteous Might (CL24)
Bonuses: +1 morale attack and will saves, immunity to fear and poison, righteous might bonuses, +4 sacred strength.
Resources Used: Mass Death Ward, Mirajane's Revelation, Miracle, Righteous Might, Righteous Fury.
#28
Digging deeply into her magical reserves, Afina accelerates herself judiciously and then lots of things happen at once, all of them bad if you're a giant in a toga!
Saccing an 11th level slot for 6 rounds of time stop.
Round 1: Cast planar bubble
Round 2: Cast summon monster X for hollyphants (SMVIII summon)
[18:09] <@Ebiris> roll 1d4+1 hollyphants
[18:09] <Serith> Ebiris roll for Serith < 2 > [d4=1]
Round 3: Move to where Jaela is and Cast summon monster X for hollyphants (SMVIII summon)
[18:09] <@Ebiris> roll 1d4+1 hollyphants x2
[18:09] <Serith> Ebiris roll for Serith < 5 > [d4=4]
Round 4: Move back to previous location and cast blistering searing delayed blast fireball on twins, spell enhancer
Round 5: Searing delayed blast fireball on twins, spell enhancer
Round 6: Searing delayed blast fireball on twins, spell enhancer
Seven tiny golden elephants with butterfly wings appear to lend aid to those in need! Six of them split off to heal those that are injured...
The hollyphants have heal as an SLA at CL 15. So +150 hp and ability damage cured, they cast on Afina, Dana, Jaela, Sylvie, Garm, and Fenrir.
But the one healing Afina will take damage from her elemental bubble and have to roll concentration against it first.
[18:15] <@Ebiris> roll 3d10 fire damage to hollyphant healing Afina
[18:15] <Serith> Ebiris roll for Serith < 18 > [d10=5,10,3]
It has +10 concentration against a DC of 34 so autofails.
The last of the hollyphants lacking anyone to heal instead bravely challenges the titans itself, flying in and trumpeting a deafening noise at them!
DC 14 fort save here.
[18:18] <@Ebiris> roll 2d10 sonic if save failed
[18:18] <Serith> Ebiris roll for Serith < 12 > [d10=3,9]
[18:18] <@Ebiris> roll 1d10 sonic if save passed
[18:18] <Serith> Ebiris roll for Serith < 4 > [d10=4]
if the save fails they're stunned for 2 rounds, if it passes they're stunned for 1 round
But that's all something of a sideshow to the rolling cascade of explosions which detonates over and over between the two giants!
Blistering searing delayed blast fireball does 176 fire damage ignoring all immunity/resistance, DC 36 ref halves. If the save fails they take -2 to everything for 1 round.
[18:29] <@Ebiris> roll 1d20+31 blistering delayed blast fireball SR
[18:29] <Serith> Ebiris roll for Serith < 36 > [d20=5]
Searing delayed blast fireball does 162 fire damage ignoring all immunity/resistance, DC 36 ref halves.
[18:29] <@Ebiris> roll 1d20+31 delayed blast fireball SR
[18:29] <Serith> Ebiris roll for Serith < 51 > [d20=20]
[18:29] <Serith> Ebiris roll for Serith < 47 > [d20=16]
And to cap it all off, four flaming meteors coalesce around Afina as she flies back from the melee, sparing the nearby hollyphant any further burns as two meteors each streak off to impact Hiya and Hiwa simultaneously! Also hopefully at 150 feet away from the twins she's out of range if they do that area blast thing again.
Searing meteor swarm
[18:25] <@Ebiris> roll 1d20+47 ranged touch Hiya meteor swarm
[18:25] <Serith> Ebiris roll for Serith < 65 > [d20=18]
[18:25] <Serith> Ebiris roll for Serith < 67 > [d20=20]
[18:25] <@Ebiris> roll 1d20+47 ranged touch Hiwa meteor swarm
[18:25] <Serith> Ebiris roll for Serith < 66 > [d20=19]
[18:25] <@Ebiris> roll 1d20+47 ranged touch Hiya meteor swarm crit check
[18:25] <Serith> Ebiris roll for Serith < 55 > [d20=8]
[18:28] <@Ebiris> roll 1d20+29 meteor swarm SR
[18:28] <Serith> Ebiris roll for Serith < 42 > [d20=13]
Hiya takes 42 and 84 bludgeoning.
Hiwa takes 42 and 42 bludgeoning.
They both take 144 fire damage, ignoring resistance and immunity, no save.
Afina: 207/287, glaciante's spiteful ward (CL 27 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 25), see invisibility (CL 25), greater heroism (CL 25), interplanar telepathic bond (CL 24), shield (CL 25), magic tattoo (CL 26), magic tattoo (CL 26), energy absorption (CL 26), stupendous dragonskin (CL 26), seira's agility (CL 26), seira's strength (CL 26), seira's mind (CL 26), mind blank (CL 27), stoneskin (CL 26), spell turning (CL 26), control weather (CL 27), haste (CL 25), planar bubble (CL 25)
AC 94, spell resistance 40, blindsense 30, immunity to fire, water, earth, cold, disease, poison, fear, 50% miss chance, freedom of movement
Spell charges: 5/9/9/6/2/9/6/8/4/2/5/1
Fenrir: 370/370, heroes feast (CL 20), greater mage armour (CL 7), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7)
Garm: 324/370, heroes feast (CL 20), greater mage armour (CL 7), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7)
Hollyphants: 33/33 hp (one at 15/33)
Initiative is Afina = Hollyphants (46) > Sylvie (37) > Hiya = Hiwa (36) > Jaela (31) > Fenrir (24) > Garm (21) > Mirajane (15) > Dana (6)
Wounds heal as fire erupts around the twins, a torrent of delayed fireballs and meteors striking them.
First fireball fails to beat SR.
> roll 1d20+25 Hiya
<Serith> Kotono roll for Serith < 42 > [d20=17]
> roll 1d20+25 Hiwa
<Serith> Kotono roll for Serith < 31 > [d20=6]
They both get a total of 42 for the second fireball and halve it.
> roll 1d20+25 Hiya
<Serith> Kotono roll for Serith < 45 > [d20=20]
> roll 1d20+25 Hiwa
<Serith> Kotono roll for Serith < 28 > [d20=3]
They both get Hiya's natural 20 on the third and halve it.
Fireballs erupt between the two twins. Flame and meteors pepper them as they're burnt, screams of fury as flesh melts and warps, charred black.
"That's it," Hiwa snaps, holding his burned face with one hand, "I'm going to fucking break all of you until you beg to join my harem, whores!"
"Shut up," Is Sylvie's reply, voice cold. She holds 21 in hand, overwhelming light coming down onto both of them.
> roll 1d20+25 Hiwa vs 21 needs a 20 here
<Serith> Kotono roll for Serith < 29 > [d20=4]
> roll 1d20+25 Hiya vs 21 needs a 20 here
<Serith> Kotono roll for Serith < 27 > [d20=2]
> roll 21d12+21
<Serith> Kotono roll for Serith < 148 > [d12=1,10,1,7,3,3,11,6,1,1,7,4,6,6,9,4,11,7,8,10,11]
The light of 21 bombards them even further, hunks of them gone and innards leaking blood where exposed.
"Father will hear about this and he'll claim your souls, all of you!" Hiya says, holding his intestines in with one hand. They begin to gather magic and...can't. The trumpeting of the hollyphants is too much, leaving them reeling from it.
They only fail that save on a 1, so they need two 1s in a row to fail.
> roll 1d20
<Serith> Kotono roll for Serith < 19 > [d20=19]
> roll 1d20
<Serith> Kotono roll for Serith < 18 > [d20=18]
> roll 1d20
<Serith> Kotono roll for Serith < 14 > [d20=14]
> roll 1d20
<Serith> Kotono roll for Serith < 3 > [d20=3]
> roll 1d20
Not happening so minimal damage. Go Jaela.
Go Jaela.
Dana
HP: 344/344
Sylvie
HP: 369/369
Mirajane
HP: 311+50/311
