Deeper into the sewers (Surraruthru)
Started by Anastasia, February 10, 2017, 03:26:17 PM
> roll 1d20+28 Fort
<Rei-chan> Iddy rolled : 1d20+28 Fort --> [ 1d20=17 ]{45}
You endure that sounds as other scouts do not. Some fall over and others cry and hold their head.
It hardly matters as your blood races. Your heart soars. You know what that sound is after a moment.
It's a dragon's roar. A roar of challenge.
Surraruthru feels it deep. Deep in his chest, pouring from his heart and washing over him like a tidal wave. How dare another challenge him? This will not stand.
Breathing deep, he lets loose his own roar, doing his utmost to pump his own magic and power into it as he bellows his response, trying to make it last as long as the challenging roar, at the very least.
Once the draconic rage is emptied from him into the roar, the haze over him goes with it, giving him a chance to think and respond. With it comes a plan..
'Tepen. There's another dragon here. Haven't seen it yet, but it just challenged me. The Courre with me couldn't withstand the challenge. I'm going.'
Before setting off, he focuses on his Tapestry, releasing the stored magic in it, and then begins to cast new spells into the Quisecent Weaving.
Couple things here. Right now, these are the spells I have from my Reaving Dispel of the Pit Fiend and that I cast on myself during Time Stop:
Mind Blank (CL20), Freedom of Movement (CL20), Superior Resistance (CL20), See Invisibility (CL20), True Seeing (CL20), Death Ward (CL20), Bear's Endurance (CL20), Owl's Wisdom (CL20), Eagle's Splendor (CL20), Barkskin (CL20), Greater Mage Armor (CL20), Might of the Planetar (CL26), Celestial Valor (CL 29), Greater Heroism (CL26), Shield (CL29), Spell Turning (CL29), Duelward (CL29)
Freedom of Movement, Death Ward, Bear's Endurance, Owl's Wisdom, Eagle's Splendor, Barkskin, Might of the Planetar, Celestial Valor, Greater Heroism, Duelward, and Shield all have round, 1 or 10 minutes/level duration. What's expired?
Casting these spells into Quiescent Weaving:
Might of the Planetar (CL26), Dimension Jumper (CL26), Haste (CL26), Duelward (CL29)
'Understood. Be careful,' Tepen sends. 'Call for reinforcements if you need them.'
Death ward, the three stat boosters, might of the planetar, celestial valor, duelward and shield are expired.
"Scouts, retreat until you can recover. Take those that can't move with you. Elementals, guard them just in case, but I want a small group of Earth and Water elementals to follow me as a guard. Stay in the walls and in the water, and stay clear of the fight, if there's going to be one. Your main job is to make sure this whole place doesn't collapse and destroys the city above."
With that, Surraruthru starts flying towards the challenge, pulling up his innate invisibility power as he goes.
Surraruthru
HP: 282/347
AC: 53 =38+4+5+6 (Def/Barkskin/GMA)
Init: +13, Touch Atk: 37, ATK/Damage: +4,
Active: Mind Blank (CL20), Freedom of Movement (CL20), Superior Resistance +6 Saves (CL20), See Invisibility (CL20), True Seeing (CL20), Barkskin (CL20), Greater Mage Armor (CL20), Spell Turning (CL29), See Invisibility (CL20), True Seeing (CL20), Greater Heroism (CL26)
Going to try and follow the sound then?
You think you can follow it. Ahead, to the left and down that path, you think.
Surraruthru follows cautiously, fighting another dragon in an area that, at the very least, they've prepared is always more dangerous. And if it's this... whatever's lair, even worse.
As an aside, is there any chance I can identify the dragon type by the sound of the roar? Some kinda knowledge check or something?
> roll 1d20+40+4 K:A/GH Gimmie a 20 ya damn cat
<Serith> Iddy roll for Serith < 45 > [d20=1]
You aren't sur-!!!
All of reality flashes white. There is a violent shaking, everything trembling. A howl comes from afar, like a vast creature crying out.
