Salvation at last (Tryll)
Started by Anastasia, February 20, 2017, 04:07:59 PM
Your check wasn't that high, but you did get some relevant info.
An Astral Dreadnought is a silent hunter of the Astral Plane. Despite not needing to eat, it nonetheless hunts and devours creatures on the Astral Plane. As an outsider, it has darkvision.
An Astral Dreadnought is feared for its cone of antimagic, which extends from its center eye 150ft ahead of it. It can turn the eye in any direction to move the cone as it sees fit. Interestingly, as you're 300ft away, this suggests this is an advanced specimen with greater powers than normal.
The Dreadnought is more than happy to swallow foes whole. This naturally leads to be consumed and digested, which is rather unpleasant for all concerned.
Oh thank god it's a cone. That really solves a lot of problems, actually.
<Horphant_Underwaxer> roll 1d20+6-1 Tryll
<Serith> Horphant_Underwaxer roll for Serith < 18 > [d20=13]
<Horphant_Underwaxer> roll 1d20+7-3 Calleigh
<Serith> Horphant_Underwaxer roll for Serith < 17 > [d20=13]
> roll 1d20+12 Mei
<Serith> Kotono roll for Serith < 31 > [d20=19]
> roll 1d20+7 Rosa
<Serith> Kotono roll for Serith < 18 > [d20=11]
> roll 1d20+3 Fantase
<Serith> Kotono roll for Serith < 22 > [d20=19]
> roll 1d20+4 Patar
<Serith> Kotono roll for Serith < 22 > [d20=18]
> roll 1d20+8 AD
<Serith> Kotono roll for Serith < 14 > [d20=6]
Mei (31) > Fantase = Patar (22) > Rosa = Tryll (18) > Calleigh (17) > Astral Dreadnought (14)
Mei makes a show of rolling up her robe's sleeves and advances on the dreadnought, coming to within 100ft of it, dead ahead. She gestures at it, beckoning for it to come forth at her.
Fantase turns and retreats to the side, while Patar hurries to the other side.
Rosa and Tryll.
Rosa goes first, then Tryll and Calleigh will act together. Sync Tryll's Init with Calleigh's, please.
Rosa flies to the side on consideration, getting out of the way of this thing for the moment, or perhaps setting up a flank.
Done. Init is:
Mei (31) > Fantase = Patar (22) > Rosa (18) > Tryll = Calleigh (17) > Astral Dreadnought (14)
Go you two.
Calleigh and Tryll head in the direct opposite direction, hoping to flank as well, or at least get out of the cone.
How far do each of you move? Remember Astral movement is a factor here along with automatic quickening.
Remind me how Intelligence influences travel speed? 10 ft per point of intelligence?
Calleigh is at 160 ft. Tryll is double that at 320 ft. Due to the nature of this combat and the unlikelihood of Calleigh immediately attracting the beast's attention over Mei or Rosa, Tryll will speed ahead and use his move action to attempt to escape the affecting cone.
Calleigh doesn't escape the antimagic, but Tryll is able to with all of his movement speed.
Go ahead.
Current distance to monster from Tryll?
300ft away, it's so huge that moving to the side doesn't meaningfully impact that. There's a lot of dreadnought to go around.
That'll do.
Manifesting Tornado Blast, Twinned & Augmented
Augmentation: 4 PP spent to increase secondary damage by 4d6, DCs increased by 2.
Notes: Initial damage has no save. Secondary damage allows for Reflex DC 32 to halve. Regardless of whether the save is made, all creatures in the area find themselves hurled about and facing a random new direction 1d4*10 feet from their prior location. Secondary damage and effects apply even if initial attack misses.
Ranged touch! SCREWED IT UP
[blockquote]Rolled 1d20+21 : 5 + 21, total 26[/blockquote][blockquote]Rolled 1d20+21 : 10 + 21, total 31[/blockquote]
Calleigh
HP: 221
Spells Active: Inertial Armor
Bonuses:
Resources Used: 27 PP
Default Aurora boosts
Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20)
Calleigh
HP: 110 hp
Bonuses:
Psicrystal
HP: 110
Bonuses:
