Surraruthru and spellhoarding (Surraruthru)
Started by Anastasia, February 22, 2017, 02:44:16 PM
Aannnnd I forgot to renew my spell list, so I guess back to basics.
Surraruthru snarls in return and launches himself at it, intent on ripping and tearing the larger dragon apart!
Okay then. If you'd mentioned before the enemy was known, I'd let you change it, but no way to be remotely impartial now.
Init.
Yeah, I didn't notice until I went and looked. I have a few left, but not a lot.
> roll 1d20+13 Init
<Serith> Iddy roll for Serith < 27 > [d20=14]
Surraruthru
HP: 246/347
AC: 38+4 (Deflection)
Init: +13, Touch Atk: 37
Active:
As in you didn't refresh spells from a previous day?
Do you still have the spells you cast on your sheet?
I'll assume you have those back but didn't change any. Refreshing your spells is generally assumed and automatic. Changing them if you're a prepared caster isn't, so you lose that chance, but I'd assume you refreshed your Benfal loadout.
> roll 1d20+13 (+5 nerveskitter) dragon
<Serith> Kotono roll for Serith < 16 > [d20=3]
Init is Surraruthru (27) > Dragon (16)
Open.
Alrighty, that'll help, at least.
Surraruthru focuses his magic, calling on a spell to take the dragon's power for himself!
Reaving Dispel, CL 32
+20 bonus to Dispel Checks.
Let me know how many effects to roll against.
Surraruthru
HP: 246/347
Active:
Zero. Anything else this round or was that it?
Surraruthru keeps his distance for now, biding his time and watching the much larger dragon.
The other dragon advances in one long, headlong charge, roaring as it tries to bite you in half.
> roll 1d20+49 (-10 PA)
<Serith> Kotono roll for Serith < 67 > [d20=18]
Hit.
> roll 12d8+88
<Serith> Kotono roll for Serith < 141 > [d8=7,1,2,4,8,1,1,5,7,8,3,6]
Pain for Surru.
Surraruthru isn't fast enough. The dragon bites down onto him viciously, nearly biting him in half. The maw is much bigger than Surraruthru, flames licking at his feet as he's chewed. Only a ragged, desperate word of power makes the wyrm relent. It's enough to open its mouth, just enough for Surraruthru to dart out. He's bloody, great teeth marks all over his middle, but he's intact.
Go. Suffice to say getting hit is a bad life choice here.
#179
Surraruthru uses his boots to teleport a safe distance away, then begins casting!
At-Will Greater Teleport, Move action. Aiming for 450 feet away, directly backward.
Casting Time Stop, CL 26.
> roll 1d4+1
<Serith> Iddy roll for Serith < 5 > [d4=4]
Round 1: Epic Mage Armor, CL 26, Duration 24 Hours
+20 AC.
Round 2: Superior Mighty Wallop, CL 26, Duration 26 Hours
+4 Size category for unarmed/bludgeoning weapons
Round 3: Haste, CL 26, Duration 26 Rounds
+1 Dodge AC, +1 Attack Rolls, +1 Attack, +30 ft. movement
Round 4: Greater Heroism, CL 26, Duration 260 minutes
+4 Morale Bonus to ATK/Save/Skill, +20 Temp. HP
Round 5: Elemental Body: Fire, CL 26, Duration 26 Hours
Immune to poison, sleep, paralysis, and stunning, and are not subject to extra damage from critical hits or flanking. You gain darkvision out to 60 feet.
Surraruthru
HP: 105+20/347
AC: 63=38+4+20+1 (Deflection/EMA/Dodge)
Init: +13, Touch/Atk: 38/42
Active: Epic Mage Armor (CL26), Superior Mighty Wallop (CL26), Greater Heroism (CL26), Elemental Body: Fire (CL26)
