Now where am I?! (Moore)
"Well, the only way out of a maze is to go forward, right?" Moore says as he now flies out of the water and helps Ilsenine out herself. "Let's see..."
He'll cast a spell to help him see a little better, just to be on the safe side.
Casting Vision of the Omniscient Eye and then taking a look around. Take 10 on Spot for 56 if that's the relevant one.
You only see one way ahead - straight up, to the tops of those waterfalls and beyond, to the top of this absurdly tall cavern.
That's not much of a maze if there's only one direction...
Either way, he'll dry off himself and Ilsenine with some magic (didn't She always do that...?) before he gestures.
"Shall we?" Moore says as he starts to rise.
"Let's," Ilsenine says.
As the two of you fly up, you see the waterfalls come to life. The waters move as if a living thing, weaving above you. Before you eyes they form walls and paths, making a solid building of waters above you, with an entrance on the bottom, which is directly above you. A simple hole for one to fly into the building from. It takes up the entire space all around, large enough so you can't simply fly around it.
"Even if the way they got us here was a bit insulting, you can't fault their craftsmanship." Moore says as he takes Ilsenine's hand again and flies into the hole!
Do you have any supernatural senses, darkvision, low-light vision or anything like that?
WELL I WOULD IF SOMEONE HADN'T STOLEN MY MASK!!!!!!!!!!!!!!!!
He has low-light vision and always-on detect magic.
Pixie morale -100.
You fly in. You find it's dim but your low-light vision is sufficient. The entry room is small and there's another hole 15ft up through a the roof to continue further, as well as small holes in the western and southern wall to go through.
"Do you have an opinion on the direction?" Moore asks. "The traditional method to find your way out of a maze is to hold your hand on the right wall and keep it that way -- you end up traversing every path. This one is... uh... a little different, obviously..."
Queen Ilsenine frowns, "Three dimensions rather complicates it," She says, "Can your magic find the way?"
"I doubt it would work." Moore says. "Even then, I think that it ruins the spirit of the invitation." He smiles and gives her hand a squeeze. "I understand your trepidation -- I was rather taken aback my first few times dealing with them. Let us treat it as if we were invited by a fellow fey to test one of their own tricks."
Ilsenine smiles, "Then I suggest we rise, as that is the intended path, I would suspect."
"Three dimensions really -does- complicate it..." Moore says as he rises. "I suppose we can always backtrack if we need to."
You fly up. This is a fairly uninteresting square room on one side, then abruptly narrows into a tight passage to the western side, with small tunnel there. There's also tunnels to the north and the south, just before the room narrows.
On the inner wall of the tight passage to the western tunnel, a line of rock rests within the still waters.
"Maze decor...?" Moore asks aloud as he flies over. "Hmm... Well, no one got anywhere just sitting around." He offers as he tentatively starts to head towards the southern tunnel.
