Now where am I?! (Moore)
This is a DM who failed a Spot check. For shame.
It's spell writing. A scroll - read it and activate it by smashing the jar open. In particular, it's a scroll (jar) of meteor swarm.
Moore opens his mouth to say something, then shuts it.
"It's a magic clay pot that you read like a scroll and then smash to cast meteor swarm." Moore says. He puts it into his portable hole because he has absolutely nothing else to say about it.
He will fly over to the pentagon and touch it!
You touch the pentagon and it crumbles away. In its wake a bejeweled helmet appears, but begins to fall into the lava.
You can attempt a Dex check to catch it, or something else if you get creative/magical. Certain things may need a Dex check to see if you're fast enough regardless.
No relevant spells I can see, so he'll just try!
[22:30] <Nephrite> roll 1d20+12 dex check
[22:30] <Rei-chan> Nephrite rolled : 1d20+12 dex check --> [ 1d20=14 ]{26}
You're lightning fast, grabbing the helmet a second before it hits the lava.
Take 10 for 49 spellcraft.
He will put it away after analyzing it!
Time to head south!
You hold in your hands a mighty magical item - a helm of brilliance.
Wow!
"An honest-to-goodness helm of brilliance. I've heard of those but never seen one for real." Moore says as he puts it away and continues on to the south.
Ilsenine smiles, "I am familiar with those. They are expensive, Aurora's coffers and Afina's golems will appreciate it, as will your own pockets."
Moore nods. "Your own as well, Your Majesty. It would be remiss if we were to not share in what we've found here at the end of everything."
"I need little money," Ilsenine says, already turning to the passage south. "There are many better causes on Aurora."
"You could use it to buy some plants for the Court hall." Moore says as he goes along with her.
You pass through the tunnel - and it's getting hotter ahead. Blazing head as you go forward, the tunnel stretching on. It's starting to be felt again. But at the end, the very end of your vision, you can see a sparkling point of white light.
Moore will cast Haste on himself and Ilsenine as they continue along in case they need to go quickly!
What's that put your movement speed at?
