Surraruthru's Tree (Surraruthru)
Started by Anastasia, March 29, 2017, 11:03:08 PM
"We'll fly several more hours before resting. I will need it at the least, what of you?" Pearwood asks you, "Do you require sleep or trance?"
"To renew my spells, yes. When I do have new spells I should be able to give everyone the ability to fly much easier than everyone's individual spells. Other than that, I sleep normally."
As a note, I plan to give everyone Elemental Body: Air which will give everyone a flight speed at their normal speed with perfect maneuverability.
"Then onward, we'll make more time before rest," Pearwood says.
> roll 1d100
<Serith> Kotono roll for Serith < 25 > [d100=25]
The terrain slowly becomes more wild, with tree branches reaching out farther and farther along the river, which stays about this width, give or take 10ft at places. Less and less of the deep red sunset sunshine makes it to the river, casting the banks in shadow instead of sunny crimson. At last Pearwood veers to the side, coming to a small clearing near the banks. It's dry ground and clear, not much else to recommend it.
"This will do," Pearwood says. "We rest here."
Simmer hops out of Kascha's arms and stretches, "Guh. I'll see to the campfire."
Kascha lands and dusts herself off, "I'll fix up something simple for dinner. Unless you two are going to forage for that?"
"I can try for fish if you like."
"Fish is good," Kascha says, "Go for it."
Okay, OOC for a few things. You and Pearwood need to sleep. How much do you need to sleep? I presume you'll have Kascha and/or Simmer see to watches? Anything else?
I assume a full count of rest. I don't have anything that will reduce that. I will suggest we throw the portable hole somewhere decently hidden and use that as a camp hole. It'll be easier to hide and control entrance to. I really need to get that mage's mansion spell thing rolling... As for watches, if they want to. I don't mind doing a rotation.
Pearwood will sleep outside regardless, the other two don't care since they'll be on patrol. Anything else to set up?
If no one else will use it, then I'll just sleep wherever too. Other than that... Not really. Swimmin' for fishies time.
> roll 1d100
<Kobot> Kotono rolled 1d100 --> [ 1d100=57 ]{57}
Rest passes uneventfully. Any spell changes to make?
Only one. Getting another casting of Superb Dispelling. Has it been 24 hours since we started or are my previous buffs still active?
Okay, the following. Nothing really changed except Elemental Body: Air:
Tapestry:
Level 3:
Greater Magic Armor: (Spell Compendium, p. 136), CL 25, Duration 25 hours
This spell functions like mage armor (PH 249), except that it requires no material component and its tangible field of force provides a +6 armor bonus to Armor Class.
Level 7:
Energy Absorption: (Complete Mage, p. 103), CL 26, Duration 26 hours/expended
The subject gains resistance 10 against all five energy types: acid, cold, electricity, fire, and sonic. As an immediate action, the subject can cause the spell to absorb the power of a single energy-based attack. The subject gains immunity to any energy types used in that attack (but only for that attack) and also heals a number of points of damage equal to 1/2 the damage the effect would normally have caused.
Elemental Body: (Spell Compendium p. 78), CL 26, Duration 26 hours
You have the benefits of the attune form spell (page 17) with respect to the appropriate element. If you choose a water body, for example, you can breathe normally on water-dominant planes.You are immune to poison, sleep, paralysis, and stunning, and are not subject to extra damage from critical hits or flanking. You gain darkvision out to 60 feet. Your creature type remains unchanged, so you are unaffected by spells that target elementals, but you gain the air, earth, fire, or water subtype depending on the elemental substance you chose.
Note: If the others want a different elemental type, they can say so and I can post what their bonus would be.
Level 8:
The subject is protected from all devices and spells that detect, influence or read emotions or thoughts. This spell protects against all mind-affecting spells and effects as well as information gathering by divination spells or effects. Mind blank even foils limited wish, miracle, and wish spells when they are used in such a way as to affect the subject's mind or to gain information about it. In the case of scrying that scans an area the creature is in, such as arcane eye, the spell works but the creature simply isn't detected. Scrying attempts that are targeted specifically at the subject do not work at all.
Additionally, the below are pre-loaded into the Tapestry for activation as Quiescent Weaving:
Resist Energy, CL 26, Duration 260 Minutes. (4 castings)
Subject gains energy resistance to: Acid, Electricity, Fire, Sonic of 30 points.
These spells are personal buffs for Surraruthru:
Moment of Prescience, CL 26, Duration 26 hours/discharged
This spell grants you an insight bonus equal to your caster level (maximum +25) on any single attack roll, opposed ability or skill check or saving throw. Alternatively, you can apply the insight bonus to your AC against a single attack (even if flat-footed). Activating the effect doesn't take an action; you can even activate it on another character's turn if needed.
Superior Mighty Wallop, CL 26, Duration 24 hours
As greater mighty wallop, except the bludgeoning melee weapon damage increases by four size categories.
Epic Mage Armor, CL 26, Duration 26 hours
This spell is identical to mage armor, except that it grants a +20 armor bonus to armor class.
Cool.
The next day begins quietly. You rise and study, then get a meal of berries and rabbit stew. "We should reach the next layer with any luck today, if the elves were right," Kascha says, "Be ready in case there's guardians or trouble."
Simmer's humming to herself, letting her berries char in the fire before popping them into her mouth.
Kascha
HP: 279/279
Spells Active: Mind Blank (CL26), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Energy Absorption (CL26), Elemental Body (CL26), SSD (CL26), Agility of the Dragon Princess (CL26), Strength of the Dragon Princess (CL26), Mind of the Dragon Princess (CL26)
Bonuses: +1 morale attack and will saves, immunity to fire and poison, resistance to energy (all) 10, +3 natural armor bonus, +1 attacks when both you and enemy are on ground, +10 armor bonus to armor class, damage reduction 10/magic, +4 insight Dex, Strength and Int
Simmer
HP: 346/346
[/quote]
"Always. We've also got Simmer here to balance the odds. With this much flammable material around here, at the very least we can smoke-screen our way through."
Pearwood sits by the fire, eating and keeping to himself until this point. "We'll begin now," he says, taking one last bite of breakfast before standing. His body flickers and swirls, the power of air all throughout him. "Follow me."
The party takes to the air, flying over the river and towards your destination.
> roll 1d100
<Kobot> Kotono rolled 1d100 --> [ 1d100=1 ]{1}
You fly several hours like this. It's unremarkable and chatty time, just whiling away the hours of travel.
"...and that's why you don't mix alchemist's fire and gust of wind," Simmer concludes, "At least when anyone's nearby."
"Hold on," Pearwood calls, the river below much the same as the last several hours.
