Surraruthru's Tree (Surraruthru)
Started by Anastasia, March 29, 2017, 11:03:08 PM
Okay, cool. Make a Listen check, Surru.
> roll 1d20+36 listen
<Serith> Iddy roll for Serith < 51 > [d20=15]
Surraruthru can hear a rustling in the bushes behind the party.
Surraruthru spins to face it with a rumbling growl of warning, loud enough to get the other's attention.
A familiar beast erupts from the bushes - a tiger. It's growling low at all of you, fur bristling as the beast is long, large and has deadly looking teeth bared at you.
The others turn at the same time, "Oh, how cute?" Simmer says, "I agree, fur looks better burnt off your body."
Make a Intimidate check, Surrur, since you're trying that.
I lack that skill, so Cha check it be.
[blockquote]Rolled 1d20+9 : 5 + 9, total 14[/blockquote]
The tiger doesn't relent, instead pouncing at the three of you fast. It's going right for you in particular, lots of sharp teeth seen closer and closer - !!!
Init.
Surraruthru briefly glows with magic, quickly throwing magic into the tapestry...
Using Nerveskitter (Sorc), CL 16, Target Tapestry
+5 bonus to Initiative
> roll 1d20+9+5 Init
<Serith> Iddy roll for Serith < 17 > [d20=3]
> roll 1d20+14 Kascha
<Serith> Kotono roll for Serith < 16 > [d20=2]
> roll 1d20+12 Simmer
<Serith> Kotono roll for Serith < 17 > [d20=5]
> roll 1d20+6 Pearwood
<Serith> Kotono roll for Serith < 8 > [d20=2]
> roll 1d20+11 tiger
<Serith> Kotono roll for Serith < 19 > [d20=8]
Init is Tiger (19) > Surraruthru = Simmer (17) > Kascha (16) > Pearwood (8)
Init is Simmer (22) > Kascha (21) > Tiger (19) > Surraruthru (17) > Pearwood (13)
Whoops, missed the group target nerveskitter. Okay, edited this post and the rest coming in a new post momentarily.
Simmer glows with heat as she steps forward, into the path as she explodes into a nexus of flames. "BURN!" Simmer cries out from within, as waves of hyper-intense heat blast the rest of you back.
Okay, she's casting a fiery empowered greater fireburst, using her metamagic rod to maximize it, using battle magic on it, using metamagic specialist so she can do it as a standard action.
That's a base of 150+75+15+45=285 base damage.
> roll 1d20+16 Ref
<Serith> Kotono roll for Serith < 22 > [d20=6]
Failed the save. Ouch.
You're sent back a solid 20ft, reeling from the flames. When you blink your eyes clear, everything within 10ft of Simmer is utterly destroyed. Only a bit of ash floats on the wind, parts of trees burnt away, foliage gone and most of the tiger dust on the wind. The hindquarters and back legs remain, out of the range, and fall over.
"Told you," Simmer says.
Free act. Simmer wanted to vent a bit so she did when she got the chance.
Kascha
HP: 279/279
Spells Active: Mind Blank (CL26), Greater Mage Armor (CL25), Energy Absorption (CL26), Elemental Body (CL26), SSD (CL26), Agility of the Dragon Princess (CL26), Strength of the Dragon Princess (CL26), Mind of the Dragon Princess (CL26)
Bonuses: Resistance to energy (all) 10, +3 natural armor bonus, +1 attacks when both you and enemy are on ground, +10 armor bonus to armor class, damage reduction 10/magic, +4 insight Dex, Strength and Int
Simmer
HP: 346/346
Spells Active: Mind Blank (CL26), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL25), Heroes Feast (CL20), Energy Absorption (CL26), Elemental Body (CL26), SSD (CL26), Agility of the Dragon Princess (CL26), Strength of the Dragon Princess (CL26), Mind of the Dragon Princess (CL26)
Resources Used: 1 7th level spell charge, 1 daily use of maximize rod, 1 daily use of battle magic, 1 metamagic specialist.
"Simmer. I feel the need to say something."
Surraruthru gives her a clawed thumbs up.
"Well done. I may need your help maximizing fire."
Pearwood's eyebrows go up as he surveys the radius, going to inspect a damaged tree with a hunk of it gone.
"Thank you," Simmer smiles, "I'll be glad to teach you more about fire. It's the best element."
Kascha looks around, "We should get going before a tree topples over," she says, "A few of the damaged ones may be unstable."
"And while it will have scared most animals away, the ones that will come to investigate will be even more of a problem. Let's get moving."
> roll 1d100
<Serith> Kotono roll for Serith < 85 > [d100=85]
Make a Spot and a Listen check for reference real quick.
> roll 1d20+36 Listen
<Serith> Iddy roll for Serith < 43 > [d20=7]
> roll 1d20+36 Spot
<Serith> Iddy roll for Serith < 45 > [d20=9]
