Afina and Jaela's planning session (Afina, Jaela)
Started by Anastasia, May 16, 2017, 02:49:23 PM
It's okay, presumably he needs to hit my AC and miss chance or I need to roll a ref save?
> roll 1d20+44 touch AC 1
> roll 1d20+44 touch AC 2
<Rei-chan> Space_Cat rolled : 1d20+44 touch AC 1 --> [ 1d20=5 ]{49}
<Rei-chan> Space_Cat rolled : 1d20+44 touch AC 2 --> [ 1d20=2 ]{46}
> roll 1d20+44 touch AC 3
> roll 1d20+44 touch AC 4
<Rei-chan> Space_Cat rolled : 1d20+44 touch AC 3 --> [ 1d20=4 ]{48}
<Rei-chan> Space_Cat rolled : 1d20+44 touch AC 4 --> [ 1d20=12 ]{56}
Touch AC?
A single sweep of your spear parries all four lances of hellfire, snuffed out like a candle dunked into water. Both devils pull back, eyes on you as you stay untouched from their sorcery.
Unfortunately for them, 27 does not stay still. He flies on the air, just making it to 80ft below them. Reality around him ripples, twists. It's wrong and right at the same time, everything changing wildly and engulfing the two devils and the nightmares.
> roll 32d6
<Rei-chan> Space_Cat rolled : 32d6 --> [ 32d6=120 ]{120}
> roll 1d20+38 pit fiend fort
<Rei-chan> Space_Cat rolled : 1d20+38 pit fiend fort --> [ 1d20=16 ]{54}
Paeliryon is immune.
The twisting space turns the cries of the devils into writhing maggots that become rays of sunshine onto to slowly become letters of Infernal describing their pain most exquisitely. Yet both of them seem to endure, twisted but not down, as...
Go. You're up since the Inquisitor held.
Jaela shoots straight up, unable to resist the invitation for much longer! Rather than the usual direct assault she's known for, however, Jaela stops abruptly when a hundred feet away from the devils and grants them the honor of witnessing her newest spell! While at its epicenter, of course.
Jaela summons Terror Fog with the devils at the center, it spreads in a 100ft radius and is 100ft high. She will remain at the very edge of it upon casting, the 100ft away mentioned earlier. Jaela's dimensional travel block is still up, making life needlessly difficult for the devils. Jaela threatens everyone in the fog and is considered flanking them.
[22:18] <@Annerose> Are the Nightmares immune as well?
[22:19] <@Annerose> Maybe 27 will get them and we'll get a nice chariot
> roll 1d20+13 nightmarers, dur
<Serith> Space_Cat roll for Serith < 19 > [d20=6]
The nightmares are consumed, crumbling in the chaos and leaving behind the chariot, which plunges to the ground and crashes loudly. Not that they have time to deal with that, as you position. You are everywhere in the fog, senses extending as you see the paeliryon begin to gesture.
Provokes an AoO. You can also try to counterspell if you miss or if she makes the Concentration check after damage.
Jaela takes poorly to gesturing within her fog!
[10:38] <@Annerose> roll 1d20+69 AoO
[10:38] <Serith> Annerose roll for Serith < 80 > [d20=11]
Forgot flanking, so should be 82.
[10:46] <@Annerose> roll 2d8+60+11d6+4d6 last is goldenfire, 1 negative level, silver+good+anarchic+epic
[10:46] <Serith> Annerose roll for Serith < 111 > [d8=2,5][d6=3,2,6,2,1,1,1,4,2,6,2,2,4,2,6]
[10:47] <@Annerose> roll 1d20+33 CL
[10:47] <Serith> Annerose roll for Serith < 40 > [d20=7]
[10:47] <@Annerose> roll 15d12 channeled bolt of glory
[10:47] <Serith> Annerose roll for Serith < 81 > [d12=4,7,6,2,9,5,10,1,1,3,6,3,12,7,5]
If she saves vs all this I'm counterspelling her.
Not rolling Concentration, she can't make the DC.
You stab forward, your spear everywhere - including the back of the paeliryon. She gasps as you impale her, spear tip sticking out of her upper stomach before it vanishes, your moment of flanking done. She bleeds from both ends of the new hole she has, holding her middle with one arm. "This sorcery!" she manages to gasp out, as the pit fiend simply hovers in the air as his chariot crashes to the ground. Energy begins to gather around him, a pale night-black nimbus all around him.
Does not provoke an AoO.
27 will hold for the moment and play intercept if any of them have a way out of the fog or a new trick. Go Jaela.
#189
She could take her time and draw this out, but instead Jaela decides to see how far she can take things with her current preparation! It wouldn't be a proper test of her new spell if she stacked the deck too much-- she stops, giddy as she is at the prospects, and reminds herself of just where she is.
Properly focused, Jaela stabs at the pit fiend as Gae Bolg passes through his armor as if it weren't even there!
[18:55] <@Annerose> roll 1d20+65
[18:55] <Rei-chan> Annerose rolled : 1d20+65 --> [ 1d20=13 ]{78}
[18:55] <Rei-chan> Annerose rolled : 1d20+65 --> [ 1d20=10 ]{75}
[18:55] <@Annerose> roll 1d20+60
[18:55] <Rei-chan> Annerose rolled : 1d20+60 --> [ 1d20=4 ]{64}
[18:55] <@Annerose> roll 1d20+55
[18:55] <Rei-chan> Annerose rolled : 1d20+55 --> [ 1d20=11 ]{66}
[18:55] <@Annerose> roll 1d20+50
[18:55] <Rei-chan> Annerose rolled : 1d20+50 --> [ 1d20=13 ]{63}
Brilliant Aura ignores his armor and shield. If he happens to die from one of the attacks, the rest are diverted to his body-painted friend.
[18:56] <@Annerose> roll 2d8+60+11d6+4d6 last is goldenfire and 1 negative level
[18:56] <Rei-chan> Annerose rolled : 2d8+60+11d6+4d6 last is goldenfire and 1 negative level --> [ 2d8=13 11d6=44 4d6=12 ]{129}
[18:56] <Rei-chan> Annerose rolled : 2d8+60+11d6+4d6 last is goldenfire and 1 negative level --> [ 2d8=11 11d6=44 4d6=17 ]{132}
[18:56] <Rei-chan> Annerose rolled : 2d8+60+11d6+4d6 last is goldenfire and 1 negative level --> [ 2d8=12 11d6=26 4d6=15 ]{113}
[18:56] <Rei-chan> Annerose rolled : 2d8+60+11d6+4d6 last is goldenfire and 1 negative level --> [ 2d8=5 11d6=41 4d6=19 ]{125}
[18:56] <Rei-chan> Annerose rolled : 2d8+60+11d6+4d6 last is goldenfire and 1 negative level --> [ 2d8=6 11d6=39 4d6=14 ]{119}
EDIT: Taking 10 on K:A for 60 to tell me what he's doing. Will use my swift action after resolution.
Init is Jaela (32) > Paeliryon (25) > 27 (14)
The pit fiend was gathering up power, but boy that just became irrelevant since he got a case of the deads.
Your spear is there. The pit fiend is impaled five times in a second, ghostly afterimages of your spear sticking out of his now blood-gushing wounds. He staggers forward, "Impo-" and can't even finish it. His body turns to solid stone and then erupts, sizzling lava splashing all around.
Swift?
"Are you sure you won't surrender?" Jaela's voice asks from everywhere inside the fog. "If you are taken prisoner and spill all you know about your superiors, you'll get to live in shame."
Quickened Divine Favor.
"Fuck you!" The devil snarls, defending herself.
Defending herself and holding. 27's in the same holding pattern. Go.
"No thank you," Jaela politely takes the bait, stabbing her!
[19:29] <@Annerose> roll 1d20+65
[19:29] <Rei-chan> Annerose rolled : 1d20+65 --> [ 1d20=11 ]{76}
[19:30] <Rei-chan> Annerose rolled : 1d20+65 --> [ 1d20=16 ]{81}
[19:30] <@Annerose> roll 1d20+60
[19:30] <Rei-chan> Annerose rolled : 1d20+60 --> [ 1d20=4 ]{64}
[19:30] <@Annerose> roll 1d20+55
[19:30] <Rei-chan> Annerose rolled : 1d20+55 --> [ 1d20=17 ]{72}
[19:30] <@Annerose> roll 1d20+50
[19:30] <Rei-chan> Annerose rolled : 1d20+50 --> [ 1d20=11 ]{61}
[19:30] <@Annerose> roll 2d8+60+11d6+4d6 last is goldenfire and 1 negative level
[19:30] <Rei-chan> Annerose rolled : 2d8+60+11d6+4d6 last is goldenfire and 1 negative level --> [ 2d8=11 11d6=29 4d6=12 ]{112}
[19:30] <Rei-chan> Annerose rolled : 2d8+60+11d6+4d6 last is goldenfire and 1 negative level --> [ 2d8=9 11d6=37 4d6=16 ]{122}
[19:30] <Rei-chan> Annerose rolled : 2d8+60+11d6+4d6 last is goldenfire and 1 negative level --> [ 2d8=13 11d6=39 4d6=17 ]{129}
[19:30] <Rei-chan> Annerose rolled : 2d8+60+11d6+4d6 last is goldenfire and 1 negative level --> [ 2d8=7 11d6=33 4d6=19 ]{119}
[19:30] <Rei-chan> Annerose rolled : 2d8+60+11d6+4d6 last is goldenfire and 1 negative level --> [ 2d8=11 11d6=45 4d6=10 ]{126}
I forgot +3 damage to each attack, so please add that if relevant. If she survives this, I'll cast a quickened True Strike after.
Again, again and again. Three stabs into her back, the third going through the devil's heart.  She crumbles to sulfuric gasses, leaving nothing behind save for memories and hate.
Free act.
