Afina and Jaela's planning session (Afina, Jaela)
Started by Anastasia, May 16, 2017, 02:49:23 PM
Not to be a killjoy or slow y'all down, but I thought you were going to determine randomly, like a dice roll.
Okay, will be a few while setting up a spoiler block for those three. Please hold.
Unless she genuinely has better bracers, Hanna gets the following:
[spoiler]Golden Bracers (Hidden Dawn): Ranks are unlocked by using them in battles of the appropriate CR or higher. Multiple ranks can be unlocked in a particular battle if it meets the CR requirements and is particularly epic.
Rank 1: CR 10 or sparring, fire resistance 10, 100ft range.
Rank 2: CR 13, +2 fortitude saves, 125ft range.
Rank 3: CR 15, searing light at will as an SLA, 150ft range.
Rank 4: CR 18, +2 reflex saves, 200ft range.
Rank 5: CR 20, flame strike at will, 300ft range.
Rank 6: CR 21, +2 will saves, 400ft range.
Rank 7: CR 24, +2d6 goldenfire damage on weapon damage rolls, natural attacks and spells and spell-like abilities with the fire descriptor, 700ft range.
Rank 8: CR 27, immunity to fire, 1000ft range.
Rank 9: CR 29, save bonuses increase to +7, 5000ft range.
Rank 10: CR 32, goldenfire damage rises to +4d6, unlimited range as long as on same plane. <-- Current Rank
Rank 11: CR 35, sunburst at will as an SLA.
Rank 12: CR 40, goldenfire damage rises to +6d6, gain goldenfire spell as a bonus feat.
Fire. Fire and ash. Flaming ash falls from the sky like thick, crusty-solid tears. The smell of sulfur is overwhelming, making each breath you take a sickening ordeal. Ahead over the dead, ash-covered ground is a massive crack in the earth, over 200ft long and ranging from 5ft at the ends to 50ft wide in the center. Dark red light comes up from it, casting everything in the color of fresh globs of blood.
Fortitude save, all. Protection from being sickened stops it, as does a fresh air defense ala Moore or Kascha.
Hanna
HP: 364/364
27
HP: 684/684
Baleruk
HP: 552/552
Immune to it.
Jaela takes the surroundings in, having swapped weapons for Gae Bolg as soon as she crossed her portal.
-MV x2 (gauntlets)
-GMW x2 (gauntlets) Gae Dioltas, Gae Trocaire
-Keen Edge x2 (gauntlets) Gae Bolg, Gae Dioltas
Greater heroism cast as we go through the gate, now I think of it.
[20:06] <Serith> Ebiris roll for Serith < 36 > [d20=7]
[20:06] <@Ebiris> roll 1d20+25 Fenrir fort
[20:06] <Serith> Ebiris roll for Serith < 39 > [d20=14]
[20:06] <@Ebiris> roll 1d20+25 Garm fort
Also Afina is fire subtyped if that helps her deal with ash and sulphur and the like. Also air subtyped which implies she is her own source of fresh air.
Afina: 303+20/303, glaciante's spiteful ward (CL 27 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 25), moment of prescience (CL 25), greater heroism (CL 25)
AC 92, spell resistance 40, blindsense 30, immunity to fire, water, earth, cold, disease, poison, fear
Spell charges: 6/10/10/10/8/9/8/8/7/8/7/2
Fenrir: 370+16/370, heroes feast (CL 20), greater mage armour (CL 7), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7)
AC 43, spell resistance 25, freedom of movement, immunity to electricity, exhaustion, mind affecting, fatigue, fear, poison
Garm: 370+18/370, heroes feast (CL 20), greater mage armour (CL 7), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7)
Attack: +39 (2d6+25) +10d6 skirmish, dimensional anchor
Afina's off the hook then. Baleruk immunes.
> roll 1d20+39 Hanna
<Serith> Kotono roll for Serith < 41 > [d20=2]
> roll 1d20+27 27
<Serith> Kotono roll for Serith < 29 > [d20=2]
The miasma is horrible, but everyone endures. The great crevice glows steadily. As you stand there, you can hear faraway screams, distant echos of agony. Words too faint to hear, surely cries for mercy ever unanswered.
Baleruk spreads his wings and huffs, "Now they will see my majesty!"
27 takes up the rear, looking down into the chasm.
Hanna has her axe out, "We won't be unnoticed long. Let's smash them."
#38
"No finessing this, we go hard and fast," Afina agrees, hasting everyone before she flies towards the pit, her dogs close behind.
CL 25 haste for all
Afina: 303+20/303, glaciante's spiteful ward (CL 27 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 25), moment of prescience (CL 25), greater heroism (CL 25), haste (CL 25), death ward (CL 28)
AC 93, spell resistance 40, blindsense 30, immunity to fire, water, earth, cold, disease, poison, fear, 50% miss chance, freedom of movement
Spell charges: 6/10/10/9/8/9/8/8/7/8/7/2
Fenrir: 370+16/370, heroes feast (CL 20), greater mage armour (CL 7), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), haste (CL 25), death ward (CL 28)
AC 44, spell resistance 25, freedom of movement, immunity to electricity, exhaustion, mind affecting, fatigue, fear, poison
Garm: 370+18/370, heroes feast (CL 20), greater mage armour (CL 7), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), haste (CL 25), death ward (CL 28)
"That's the plan," Jaela agrees, casting Mass Death Ward on all of them before taking the lead!
Spell Turning CL 24, Contingency CL32, Permanency/Greater Blindsight CL32, Permanency/Mantle of Good CL33, Foresight CL25, Moment of Prescience CL23, Lore of the Gods CL28, Invisibility Purge CL28, Fortunate Fate CL15, Mind Blank CL17, Greater Mage Armor CL7, Planar Tolerance CL7, Heroes Feast CL20, Righteous Halo CL28, Vision of the Omniscient Eye CL28, Greater Heroism CL28, Sign CL28, Mass Death Ward CL28, Haste CL25.
-MV x2 (gauntlets)
The party goes up and flies over the pit. Baleruk is higher up, flying ahead with his superior draconic speed. The others follow slower as...below...!!!
Thousands. Thousands being tormented. Chained to the walls, crucified, burning alive, being mutilated....it goes down hundreds of feet, countless little ledges or cages built into the wall where the innocent are tormented. As you fly over the cries suddenly become louder, so many.
Baleruk roars, "MISERABLE WRETCHES, REJOICE! TODAY YOU SHALL BE BLESSED WITH A RAINBOW COMING FORTH OVER YOUR PATHETIC EXCUSES FOR LIVES!"
You all are mind blanked, which protects you against the sheer psychological horror of what you're seeing.
Unfortunately all those prisoners means Afina can't be as indiscriminate as she'd like with her magic. Before doing anything to free them though, she looks for guardians or defences that might get in the way of such actions. Or torturers that just need to die.
Blanketing the area with protections against dimensional travel would make it harder to get these people out, and Jaela decides that she needs to first eliminate all the monsters below. Thankfully, she has a spell that can take out the vile while passing by the righteous....
Same as Afina, although with a focus on where I could do the most damage with a 40ft radius burst.
Okay, cool. Spot checks the both of you. More on reactions to Baleruk and all of this after that.
