Brightwater investing (Moore, 89 days left)
Started by Anastasia, June 14, 2017, 11:17:46 AM
"29,000 gold, give or take," Filbrez says, "I'd have to check the paperwork. That's earmarked for improving stocks as possible, as improving market side and quality is important. Though you're welcome to divert it as you please, though note that taxes do happen, which can impact this."
Moore shakes his head. "No, I trust you to take care of it. I don't think we need to use the funds right now. Just let me know if you want me to drum up further business or help Moonlight create more." He says with a smile. "Thanks. And if you need help managing this, let me know."
Next on the agenda is to go to Elysium to return Shalm, the rapier we got from the slaad dungeon. Moore would probably ask around or do some research if there's any particular place in Elysium proper that he could go to return it or get an audience with anyone.
Take 10 for 61 on K:P if needed, and 46 on K:L (Elysium) if that is more appropriate.
Okay, adjust your todo list for what you cleared. Also, have you make checks on this before? If so, what were the results?
I had not looked into doing it prior to now.
Returning it to a power of neutral good (an archangel) or a deity of neutral good (or their followers as representatives) would be simplest and best.
Then Moore will take a gate from Aurora to Elysium to the House of Nature with the intent of finding one of Chauntea's group, as she seems the one most closely associated with neutral good that I can find listed. If there's one that you think would reasonably fit better that Aurora would know then that is fine also. I didn't think Eldath would work because what in the world is she or one of her followers going to want with a weapon???
Okay then.
You appear in sunlight. Warm sunlight streams down as you stand in a field of grain, waving lightly in the breeze that blows through and cools you from the sun's warmth. You can't see much besides wheat under the circumstances.
Well, that's an easy enough thing to fix...
He flies up and out of the wheat to take a look around. After that, though, he'll take a few minutes to cast Lay of the Land since he's not familiar at all with this particular plane, so some direction would be great!
Hopefully if there's a temple or something otherwise important around it'll tell him about it!
It's a great field of wheat. Farmers are working it, harvesting it here and there. Groups that work steadily, though none are immediately that close to you. In the distance you can see farmhouses.
Lay of the land after if this doesn't change your action.
C&P'ed from the Spell Compendium: You instantly gain an overview of the area around you. Lay of the land gives basic information relevant to major landmarks, such as rivers, lakes, and settlements (of at least hamlet size). It indicates the direction and distance to each from the current location. You have a good understanding of the terrain up to 50 miles from your current location.
It's mostly fields, streams and farmsteads. There's one exception - a little town about 30 miles southeast, which includes a chapel.
30 miles is a bit away... He really doesn't have the time to just fly there, so he'll improvise!
Limited wish for standard teleport to outside the chapel, or as close as he can get with that spell.
[14:39] <Nephrite> roll 1d100
[14:39] <Rei-chan> Nephrite rolled : 1d100 --> [ 1d100=5 ]{5}
