Get Ettan! (Afina and Jaela, 88 days left)
Started by Anastasia, June 23, 2017, 02:08:52 PM
Jaela, if you could list the bonuses from everything, I'd be grateful.
CL on greater heroism, Afina?
Simmer
HP: 383+16/383
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Epic Mage Armor (CL26), Superior Resistance (CL26), Sublime Revelry (CL31), Mass Death Ward (CL30), Good Hope (CL30), Recitation (CL30), Haste (CL27)
Master
HP: 339+20/339
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Epic Mage Armor (CL26), Superior Resistance (CL26), Sublime Revelry (CL31), Mass Death Ward (CL30), Good Hope (CL30), Recitation (CL30), Haste (CL27), Greater Heroism (CL?)
Simmer only:
Flame Strike at will
Immunity to fire
Save bonuses increase to +7
Master only:
Greater Heroism (+4 morale to attack/saves/skills, +20 temp hp,, immunity to fear)
Everyone:
Half damage from physical attacks and immunity to pain, immunity to all death spells, magical death effects, energy drain, and any negative energy effects, +2 morale to attack/saves/ability checks/skills/damage (note that there's damage and ability checks here, unlike with greater heroism), immunity to poison, protection against all mind-affecting spells and effects as well as information gathering by divination spells or effects, heal 150hp if taken below 0hp, telepathic bond between us all and Tepen, +2 luck to AC/attack/saving throws, haste.
Cool, thanks.
Lifasa screams.
An echo in your mind as you step out near Blackhearth, the miserable crack in the ground intact, the edges boiling with lava. It's even hotter here than before, Lifasa's screams echoing in your memories as you stand here.
Simmer
HP: 383+16/383
Master
HP: 339+20/339
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Epic Mage Armor (CL26), Superior Resistance (CL26), Sublime Revelry (CL31), Mass Death Ward (CL30), Good Hope (CL30), Recitation (CL30), Haste (CL27), Greater Heroism (CL27)
Simmer only:
Immunity to fire
Master only:
Everyone:
Jaela looks around for any enemies, glowing enough to draw all eyes to herself and ready to play the part of bait.
Afina and the Master quickly go to ground, peeling away from Jaela and Simmer so they can approach Blackhearth under stealth!
Taking 10 for 60 on hide, 56 on move silently
Taking 10 for Spot 60, then recasting Divine Insight.
Master will take 10 on Hide as well for a total of 67
The Master drops down with you, while you don't see much of any guards outside - at least not yet. The scream of Lifasa bores into your minds, yet both of you feel calm, safe, protected.
It doesn't take that much arcane knowledge to know that your protections are saving you a lot of misery right now.
Simmer
HP: 383+16/383
Master
HP: 339+20/339
Simmer only:
Immunity to fire
Master only:
Everyone:
'Looks empty on the exterior,' Afina says to Jaela via telepathy. 'We'll check out the tunnels, we want to have a bead on Ettan before you begin your diversion.'
So do any of the tunnels look more guarded than others?
Afina 329+20/329
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 29), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), sublime revelry (CL 31), death ward (CL 30), good hope (CL 30), recitation (CL 30), interplanar telepathic bond (CL 26)
defences: AC 96 (touch 60), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, fear, mind-affecting, critical hits
spell slots: 6/9/10/10/7/9/7/8/8/8/7/4/3
For clarity, how are you seeing into the tunnels from the outside? If it's your spell, paste it in here.
I was actually looking for dudes posted around the tunnel entrances, but yeah as we get closer my blindsight has a really long range so seeing dudes further within is easily on the table:
You gain senses unrivaled by any other creature, making you nigh impossible to ambush. You gain all-around vision, which prevents you from being flanked. You see invisible and ethereal creatures normally. Your senses sharpen to razor keenness, granting you blindsight 200ft. Finally, you gain a +25 competence bonus to spot and listen checks.
There's no one on the perimeter - check that. Someone's about 200ft away, by the middle of the crack in the earth. It is standing there, unmoving, but it is a human-like figure.
Is he invisible to normal sight?
I can use the DC 70 epic usage of spot to see through visual illusions if so, taking 10 for 80. Want to get an idea of what this guy looks like.
He is - some spell you  know not, but it crumbles as you focus. A blank faced man, gray and unremarkable. Stone gray, wearing ulitarian clothes well worn. It looks human and is gazing right in the party's direction.
