Get Ettan! (Afina and Jaela, 88 days left)
Started by Anastasia, June 23, 2017, 02:08:52 PM
"We should hit Quinn," Jaela responds, wanting to do something with all the adrenaline of the aborted life and death battle. "Break all those profaned relics, level the cathedral. What do you say?"
"That's acceptable," Afina agrees. "Just a simple raid to destroy the place, I doubt we'll be lucky enough to catch Quinn there to effect a capture."
"I'm for it," Simmer says, "Once I finish healing."
A pair of Heal spells top off Simmer and Jaela herself. "Let's break everything there," Jaela says, allowing someone else to open the gate for the four of them. "Tepen, ask Balyss for any insights on our destination or Quinn, will you?"
Afina leads the way out and then opens a gate to the vicinity of the Broken Cathedral!
Afina 329+20/329
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 29), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), sublime revelry (CL 31), death ward (CL 30), good hope (CL 30), recitation (CL 30), interplanar telepathic bond (CL 26)
defences: AC 96 (touch 60), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, fear, mind-affecting, critical hits
spell slots: 6/9/10/10/7/9/7/8/8/6/7/4/3
"I'll have that to you as soon as possible," Tepen advises.
Any other prep before leaving again or just going on right off?
Let's go burn defiled artifacts to the ground!
Rubble and ruin. You appear within a vast junkyard of broken stone, twisted metal and ruined wood. All around you is ruin, appearing in a little, tucked away dead end. A path through the mess leads ahead.
In the sky above, Lifasa burns red.
As before, Jaela allows Afina and the Master to take the lead while she intends to follow behind with Simmer and draw all attention.
Adopting a stealthy mindset, Afina flutters over the mounds of garbage and along beside the path ahead so she can see what opposition they'll be facing before they get to wreaking havoc.
Taking 10 for 70 on hide and 66 on move silently
Afina 329+20/329
Toss a Spot and Listen check duo on as well, Afina.
The Master will be taking 10 on the relevant checks.
The four of you creep on - and you haven't gone far when you see the path wind around to the left. You also hear footsteps coming from that direction, heavy footsteps.
Can I determine the creature via my 200 foot range blindsight?
Yes. Three of them, large creatures. Barbed devils, if you don't miss your guess.
