Miasma (Moore, 86 days left)
Started by Anastasia, July 19, 2017, 02:05:12 PM
Moore merely smiles. "Have no fear, everyone. We did not come here this day to die." He raises his voice -- a wonderful, inspiring thing as power flows out of him. "For Lifasa's future!"
He's using an immediate action to activate his Regalia to increase the bonus of Inspire Courage by 2.
He is using a move action to sing Destined Strike, this adds +4 to attack and weapon damage rolls, adds the Improved Crit Feat to everyone and gives them +12 on any crit confirmations.
"Prince Westwind, I see an opening, go!" Moore shouts.
Regalia of the Hero bonus to give Prince Westwind a move action to be taken now so he can position himself to smear them into paste.
En totale, the bonuses to attack are: +18 (16+2 from the item) Morale, +4 untyped, +2 more untyped from his harp for a total of +24 to attack.
They have +22 to damage, Improved Crit as if they had the feat, and any crit gets a +12 to the threat confirmation roll.
Jetina will follow this post.
#106
Jetina says a prayer to Raziel as she commands everyone to fight with a renewed fury!
Mass Valiant Fury, everyone gains +6 morale to Strength and to Constitution. The wills save gets no bonus since everyone's already under a +4 morale to saves. they also gain one extra attack like the Haste spell.
I will increase Jetina and Moore's HP to reflect the extra constitution.
This will last 26 rounds.
Moore
Active Spells: mind blank (CL17), fortunate fate (CL15), planar tolerance (CL7) and greater mage armor(CL5), Superior Resistance (CL 24), True Seeing (CL10), Bibliotecha Arcana (CL29), Greater Improvisation (CL27), Divine Insight (CL18)
HP: 336+81(not temp)+20
AC: 62, 46 touch, 52 flatfooted 20% miss chance, SR 41, 30 resist all to elements
30/32 Bardic music uses 2/3 Refrain
Spells:
0th - 4/4 (DC 22)
1st - 7/7
2nd - 7/7
3rd - 7/7
4th - 7/7
5th - 6/6
6th - 6/6
7th - 6/6
8th - 5/5
9th - 1/1
Favored Soul:
0th - 5/5
1st - 9/9
2nd - 9/9
3rd - 7/8
4th - 8/8
5th - 8/8
6th - 8/8
7th - 6/6
8th - 4/4
Jetina
Planar Tolerance (CL16), Mass Conviction (CL160), mind blank (CL17), fortunate fate (CL15), planar tolerance (CL7), greater mage armor(CL5)
353/353+13
+78
Init: +5, AC 53, Speed 30/30 (P)
Saves: Fort +41, Ref +33, Will +43
6/9/9/8/8/8/8/7/7/7/5/5
Emergency Healing 3/3
All healing spells (up to 3 targets) remove negative afflictions per panacea spells and also grant fast healing 10 for 24 rounds, also add +23 to the amount healed
"Are we going to fight these odds?" Finnegan shouts of the din of battle, as the Nessians approach from every angle.
His actions depend on the answer here.
+24 attack from Moore. +22 damage, improved crit and +12 crit confirms.
Prince Westwind
HP: 490/490
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Mass Conviction (CL16), Tyche's Touch (CL16), Mass Valiant Fury (CL26)
Bonuses: +1 morale attack rolls and will saves, immunity to fear and poison, +4 morale saves, +4 luck to saves, -1 each time, +6 morale strength+con, 1 extra attack like haste.
Finnegan
HP: 356/356
"If we need to bring in allies, we can." Moore responds. "I will let Tepen know what's going on."
Finnegan is a blur after that, charging the closest Nessian as he steps through his infernal portal, greeting him spear-first.
> roll 1d20+55 (+24 bard, +3 mass valiant fury, -20 PA going for a bit of a home run here)
<Rei-chan> Kotono rolled : 1d20+55 (+24 bard, +3 mass valiant fury, -20 PA going for a bit of a home run here) --> [ 1d20=17 ]{72}
> roll 2d8+202+3d6+1d6 and 1 negative level
<Rei-chan> Kotono rolled : 2d8+202+3d6+1d6 and 1 negative level --> [ 2d8=11 3d6=9 1d6=1 ]{223}
The spear strikes into the Nessian's middle, impaling it as it glows with holy power. Yet the fiend is only bloodied, far from bowing from a single blow. As it roars defiance at him, Westwind is right behind him and...
> roll 1d20+53 (+24 bard, +3 mass valiant fury, -26 PA)
<Rei-chan> Kotono rolled : 1d20+53 (+24 bard, +3 mass valiant fury, -26 PA) --> [ 1d20=8 ]{61}
> roll 1d20+82 (+24 bard, +3 mass valiant fury, -26 PA) trip
<Rei-chan> Kotono rolled : 1d20+82 (+24 bard, +3 mass valiant fury, -26 PA) trip --> [ 1d20=11 ]{93}
> roll 1d20+53 (+24 bard, +3 mass valiant fury, -26 PA) free trip attack
<Rei-chan> Kotono rolled : 1d20+53 (+24 bard, +3 mass valiant fury, -26 PA) free trip attack --> [ 1d20=17 ]{70}
> roll 2d8+116
> roll 2d8+116
<Rei-chan> Kotono rolled : 2d8+116 --> [ 2d8=6 ]{122}
<Rei-chan> Kotono rolled : 2d8+116 --> [ 2d8=5 ]{121}
The scythe of Westwind slices through the Nessian twice, a blast of wind knocking him down as he's bloodied. The fiend can barely begin to rise before a gust knocks him tumbling back through his portal - but so many more are coming! There is but a moment before everything around you explodes into a hellscape of all the elements.
> roll 1d20+37 SR checks
<Rei-chan> Kotono rolled : 1d20+37 SR checks --> [ 1d20=8 ]{45}
Ref saves unless you have SR 46+ or a way to stop or counter this.
Nothing of the sort.
[13:27] <Nephrite> roll 1d20+54 evasion (+4 tyche, conviction) moore
[13:27] <Rei-chan> Nephrite rolled : 1d20+54 evasion (+4 tyche, conviction) moore --> [ 1d20=4 ]{58}
[13:27] <Nephrite> roll 1d20+41 jetina
[13:27] <Rei-chan> Nephrite rolled : 1d20+41 jetina --> [ 1d20=10 ]{51}
Init is Moore (48) > Jetina (37) > Finnegan (36) > Westwind (32) > Nessians (22)
> roll 1d20+44 Finnegan
<Rei-chan> Kotono rolled : 1d20+44 Finnegan --> [ 1d20=15 ]{59}
> roll 1d20+37 evasion Westwind
<Rei-chan> Kotono rolled : 1d20+37 evasion Westwind --> [ 1d20=7 ]{44}
> roll 20d6 fire damage
<Rei-chan> Kotono rolled : 20d6 fire damage --> [ 20d6=83 ]{83}
> roll 20d6 cold damage
<Rei-chan> Kotono rolled : 20d6 cold damage --> [ 20d6=57 ]{57}
> roll 20d6 acid
<Rei-chan> Kotono rolled : 20d6 acid --> [ 20d6=79 ]{79}
> roll 20d6 electricity
<Rei-chan> Kotono rolled : 20d6 electricity --> [ 20d6=87 ]{87}
> roll 20d6 sonic
<Rei-chan> Kotono rolled : 20d6 sonic --> [ 20d6=80 ]{80}
All of you made the save, so this is halved for all of you. Go ahead and adjust Jetina and Moore's HP real quick, lemme see where that leaves you two.
Prince Westwind
HP: 490/490
Finnegan
HP: 356/356
Bonuses: +1 morale attack rolls and will saves, immunity to fear and poison, +4 morale saves, +3 luck to saves, -1 each time, +6 morale strength+con, 1 extra attack like haste.
[/quote]
Since Moore made the save he took no damage from it.
I don't think Jetina has any energy reductions (It seems like she should? I dunno)
This leaves her with 251/353(+78 from the extra con)
Inferno. Blizzard. Screams. Thunderbolt. Melting. The elements are a fury around Moore, yet he dodges. Lost in his song, untouched by any.
After the great blast clears, the miasma is momentarily burnt away. The Nessians are all around, more portals opening farther away, as those that come through position and chant, thin beams flying at all the party.
> roll 1d20+46 Moore touch AC
<Rei-chan> Kotono rolled : 1d20+46 Moore touch AC --> [ 1d20=15 ]{61}
> roll 1d20+46 Jetina touch AC
<Rei-chan> Kotono rolled : 1d20+46 Jetina touch AC --> [ 1d20=6 ]{52}
> roll 1d20+46 Finnegan touch AC
<Rei-chan> Kotono rolled : 1d20+46 Finnegan touch AC --> [ 1d20=20 ]{66}
> roll 1d20+46 Westwind touch AC, Finnegan's crit doesn't matter since it's non damaging
<Rei-chan> Kotono rolled : 1d20+46 Westwind touch AC, Finnegan's crit doesn't matter since it's non damaging --> [ 1d20=8 ]{54}
> roll 1d20+37
<Rei-chan> Kotono rolled : 1d20+37 --> [ 1d20=20 ]{57}
Last roll is caster level, so SR isn't going to matter here. Does that hit everyone or do any of you have enough touch AC to avoid that?
Prince Westwind
HP: 490/490
Finnegan
HP: 198/434 (356 normally)
I assume Spellcrafting to identify it, adn the DC's automatic for you all. It's a dimensional anchor effect on all four of you.
Go Moore, you're up.
'Tepen, we need support. Now. Devils.' Moore sends to Tepen!
I have two questions: One, can I expect that Tepen would be able to reply on my turn and two, I realize dimensional anchor blocks travel by Gate, but does it stop me from just opening a gate so people on the other side could come through?
It would not stop that, no. It merely stops you from going through one.
Tepen could, it'll depend what he's doing at that instant. It may take him a little longer.
Any other questions?
Nope. I will just take the actions now and resolve on my next turn.
They'll be fine -- he has a plan, after all. He casts a quick spell for himself, while continuing to bolster his allies! "DON'T GIVE UP!"
Casting Sonorous Hum -- next spell that requires concentration to maintain is done so automatically.
[14:25] <Nephrite> roll 18d4 nonlethal
[14:25] <Rei-chan> Nephrite rolled : 18d4 nonlethal --> [ 18d4=46 ]{46}
Jetina, Finnegan and Westwind all gain +12 morale bonus to saves (this overrides the one from their current buff) and also +12 dodge to AC.
Doing Jetina in the next post.
Raziel won't let them lose! Jetina calls out as light shines and restores everyone.
Mass Heal, this tops off everyone, and gives them fast healing 10. No one is afflicted with anything panacea can heal so that's no biggie.
