Miasma (Moore, 86 days left)
Started by Anastasia, July 19, 2017, 02:05:12 PM
At that, Jaela gestures with Gae Bolg in a wide arc and spellfire launches to strike Moore before leaping off to the rest of Jaela's allies.
My second swift goes for a Chain Dispel that seeks to remove their dimensional anchors.
[23:09] <@Louise> roll 1d20+35 Rei
[23:09] <Rei-chan> Louise rolled : 1d20+35 Rei --> [ 1d20=11 ]{46}
Jaela's bolts of glory shatter the devils back, knocking the Nessians back for a few moments. It hurts them, knocks them back, but doesn't knock them out. The infernal chanting abruptly ceases with a howl of fury, yet the emerald glow around Moore and his allies does not fade.
Seeming success on the counter, failure on the dispel. Moore.
Moore will just hold his action pending the dispel in case they need to use his action for a plane shift or something. Jetina's going to continue trying to carve an opening for them.
Jetina continues to slash at the devils with a holy and righteous fury!
[22:27] <Nephrite> roll 1d20+43+36 (bardic stuff, no smite on this one, valiant fury, bane)
[22:27] <Serith> Nephrite roll for Serith < 93 > [d20=14]
[22:28] <Nephrite> roll 1d20+43+41 (bardic stuff, smite on this one, valiant fury, bane)
[22:28] <Serith> Nephrite roll for Serith < 104 > [d20=20]
[22:28] <Nephrite> roll 1d20+43+41+12 (bardic stuff, smite on this one, valiant fury, bane) crit?
[22:28] <Serith> Nephrite roll for Serith < 109 > [d20=13]
[22:29] <Nephrite> roll 1d20+43+36 (bardic stuff, smite on this one, valiant fury, bane)
[22:29] <Serith> Nephrite roll for Serith < 95 > [d20=16]
[22:29] <Nephrite> roll 1d20+43+31 (bardic stuff, smite on this one, valiant fury, bane)
[22:29] <Serith> Nephrite roll for Serith < 83 > [d20=9]
[22:30] <Nephrite> roll 1d8+18+18+3+4d6+2d6+2d6+5+3 (Bard stuff, holy, bane, evil outsiders, no Smite, and then the extra damage from extra strength)
[22:30] <Serith> Nephrite roll for Serith < 76 > [d8=1][d6=5,3,3,3,1,6,3,4]
[22:35] <Nephrite> roll 2d8+36+36+6+8d6+4d6+4d6+10+40 (crit line)
[22:35] <Serith> Nephrite roll for Serith < 194 > [d8=2,1][d6=5,5,1,2,6,4,3,6,2,4,3,6,4,3,3,6]
[22:36] <Nephrite> roll 2#1d8+18+18+3+4d6+2d6+2d6+5+3+20 (other two hits)
[22:36] <Serith> Nephrite roll for Serith < 96, 97 >
Bursting out of hiding, Afina savages another pit fiend with stabs before she goes really fast and vanishes again!
[16:39] <@Ebiris> roll 1d20+61 5th level arcane strike, silver/good/anarchic/epic
[16:39] <Serith> Ebiris roll for Serith < 67 > [d20=6]
[16:39] <@Ebiris> roll 1d20+56 5th level arcane strike, silver/good/anarchic/epic
[16:39] <Serith> Ebiris roll for Serith < 76 > [d20=20]
[16:39] <@Ebiris> roll 1d20+56 5th level arcane strike, silver/good/anarchic/epic crit?
[16:39] <Serith> Ebiris roll for Serith < 70 > [d20=14]
[16:40] <@Ebiris> roll 1d4+30+6d6+2d6+3d6+3d6+4d6+5d4 and 2 negative levels
[16:40] <Serith> Ebiris roll for Serith < 105 > [d4=3][d6=4,4,1,2,6,2,2,1,5,1,1,5,2,4,6,3,5,2][d4=3,4,2,3,4]
[16:40] <@Ebiris> roll 2d8+60+6d6+2d6+3d6+3d6+4d6+5d4 and 4 negative levels
[16:40] <Serith> Ebiris roll for Serith < 140 > [d8=6,5][d6=2,4,4,1,1,1,6,6,5,5,4,6,6,2,1,2,1,2][d4=2,3,1,1,3]
10th level slot for 5 rounds of time stop
round 1: searing delayed blast fireball
round 2: searing delayed blast fireball
round 3: searing delayed blast fireball
round 4: searing delayed blast fireball
round 5: hide
[16:44] <@Ebiris> roll 4#1d20+33 plus Moore's bonus, delayed blast fireball SR
[16:44] <Serith> Ebiris roll for Serith < 44, 45, 48, 36 >
Each does 162 damage that ignores resistance/immunity. DC 35 ref half.
[16:47] <@Ebiris> roll 1d20+60 hide
[16:47] <Serith> Ebiris roll for Serith < 77 > [d20=17]
While Afina is missing in the wake of that, those explosions certainly prove she was around here somewhere!
Afina: 329/329
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 29), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), death ward (CL 20), sublime revelry (CL 31), good hope (CL 30), control winds (CL 27), interplanar telepathic bond (CL 26), haste (CL 27)
defences: AC 97 (touch 60), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, fear, mind-affecting, critical hits, negative energy, 50% miss chance, freedom of movement
spell slots: 6/9/10/7/7/6/2/8/0/2/3/0/2
> roll 1d20+35
> roll 1d20+35
> roll 1d20+35
> roll 1d20+35
> roll 1d20+35
<Serith> Kotono roll for Serith < 52 > [d20=17]
<Serith> Kotono roll for Serith < 51 > [d20=16]
<Serith> Kotono roll for Serith < 53 > [d20=18]
<Serith> Kotono roll for Serith < 45 > [d20=10]
Stabs. Fire.
It all happens at once. Jetina slashes her Nessian, forcing it back with pure holy power in her blade. She leaps up and slashes its throat open, causing it to fall back as burning blood pours down its chest. An opening! Just in time as fireballs erupt all around, scorching more Nessians ahead of you. The ones fireballed and stabbed repeatedly simply fall, crumbling to heaps of obsidian as...
Going, Moore? As noted before, the dispel on the DA's didn't take.
#231
He'll hold out for Jaela's go-round.
Before I do that -- if Moore hits himself with an Anti-Magic Ray, would that allow him to be the target of a Plane Shift or allow him to go through a Gate?
From IRC since we ended up talking about it there:
> Okay, if it's used against a creature, it stops them from using or being affected by  magical effects like antimagic field. It explicitly doesn't apply to their gear, which they can still use. However, self-targeted stuff would run into the first part, so no plane shifting yourself. A gate spell, natural gate or planar boundary is hazier.
> My ruling is this: Any active spell fails, including a gate spell, unless it's from something that ignores antimagic anyway. Natural gates and planar boundaries come down to situational instances and I'm sidestepping them for now since it's not relevant and they aren't always uniform.
Okay. Then he'll stand his ground for now with Jetina and wait on Jaela's actions.
This may matter, so where precisely did you hide, Afina?
Lets say ninety feet straight up and thirty feet 'North' relative to the entrance of the prismatic tunnel.
The Nessians loom above Jaela, above the walls, absolute darkness coming from all of them ton consume her like an ant before the fury of an inferno.
> roll 1d20+37 Jaela SR 1
<Serith> Kotono roll for Serith < 51 > [d20=14]
> roll 1d20+37 Jaela SR 2
<Serith> Kotono roll for Serith < 50 > [d20=13]
> roll 1d20+37 Jaela SR 3
<Serith> Kotono roll for Serith < 44 > [d20=7]
> roll 1d20+37 Jaela SR 4
<Serith> Kotono roll for Serith < 38 > [d20=1]
> roll 1d20+37 Jaela SR 5
Three Fort saves, Jaela.
[20:54] <@Louise> roll 1d20+59
[20:54] <Serith> Louise roll for Serith < 75 > [d20=16]
[20:54] <Serith> Louise roll for Serith < 74 > [d20=15]
300 damage total to Jaela.
Jaela endures the darkness - it gnaws at her, tears her apart, rips her. A lesser warrior would be consumed, emptied out into a shallow husk, but Jaela stands with her faith. The Triune's power fills her, holding the darkness at bay, only tearing her body and not her spirit. She grits her teeth and endures, as Nessians loom over her and attack, claws looking to shred her apart.
> roll 1d20+57 claw
> roll 1d20+52 claw
<Serith> Kotono roll for Serith < 60 > [d20=3]
<Serith> Kotono roll for Serith < 60 > [d20=8]
> roll 1d20+47 claw
<Serith> Kotono roll for Serith < 59 > [d20=12]
> roll 1d20+42 claw
<Serith> Kotono roll for Serith < 45 > [d20=3]
> roll 1d20+57 claw
> roll 1d20+52 claw
<Serith> Kotono roll for Serith < 69 > [d20=17]
> roll 1d20+47 claw
<Serith> Kotono roll for Serith < 49 > [d20=2]
> roll 1d20+42 claw
<Serith> Kotono roll for Serith < 51 > [d20=9]
> roll 1d20+57 bite
<Serith> Kotono roll for Serith < 71 > [d20=14]
> roll 1d20+57 wing
<Serith> Kotono roll for Serith < 62 > [d20=5]
> roll 1d20+57 wing
> roll 1d20+57 tail
<Serith> Kotono roll for Serith < 58 > [d20=1]
AC?
