Miasma (Moore, 86 days left)
Started by Anastasia, July 19, 2017, 02:05:12 PM
"Smoke? An entire plane of smoke and fires?" Jetina asks, "What sort of place is it?"
"Uh... smoke-y. I know that doesn't help, but it's literally filled with beings of air and fire. It probably smells awful too." Moore answers. "It's on the edge of the plane of Fire and Air, so it combines both. I mean, there might be pleasant places there, but... I really doubt it."
"Then you'll need Raziel's blessings," Jetina says, "I'll come with you so no one stays hurt."
Moore nods. "Great. Do you need any preparations?"
"I'm ready," Jetina says, "I feel like we've done something like this before, though."
"I'm sure we have." Moore answers with a grin.
Everyone gets the heroes feast for the temp HP and immunity to poison and yadda yadda, Moore will cast the following spells:
Planar Tolerance (CL16) for Smoke
Mass Conviction (CL16), +4 morale to saves, 160m
For himself only:
Greater Improvisation (CL27), 270m
Divine Insight (CL18), 180m
Do you want any of them to cast anything?
I will have to familiarize myself with what Jetina can do. I don't think Westwind needs to use any of his wishes right now.
If you have any suggestions feel free to voice them.
Let me know when you're good then.
I don't see anything that she can cast that may not expire. We can save the Energy Immunity for when we're closer or something. So it looks like nothing.
We're good to go.
#40
Edit to mention I am adding Tyche's Touch to all parties, this is 4 castings.
Also I forgot the mission readiness arch has Planar Tolerance already, so Moore doesn't need to cast it at all.
Okay, go ahead and do your spoiler block and one for Jetina.
Moore
Active Spells: mind blank (CL17), fortunate fate (CL15), planar tolerance (CL7) and greater mage armor(CL5), Superior Resistance (CL 24), True Seeing (CL10), Bibliotecha Arcana (CL29), Greater Improvisation (CL27), Divine Insight (CL18)
HP: 336+20
AC: 62, 46 touch, 52 flatfooted 20% miss chance, SR 41, 30 resist all to elements
32/32 Bardic music uses 3/3 Refrain
Spells:
0th - 4/4 (DC 22)
1st - 7/7
2nd - 7/7
3rd - 7/7
4th - 7/7
5th - 6/6
6th - 6/6
7th - 6/6
8th - 5/5
9th - 1/1
Favored Soul:
0th - 5/5
1st - 9/9
2nd - 9/9
3rd - 7/8
4th - 8/8
5th - 8/8
6th - 8/8
7th - 6/6
8th - 4/4
Jetina
Planar Tolerance (CL16), Mass Conviction (CL160), mind blank (CL17), fortunate fate (CL15), planar tolerance (CL7), greater mage armor(CL5)
353/353+tempHP
Init: +5, AC 53, Speed 30/30 (P)
Saves: Fort +41, Ref +33, Will +43
6/9/9/8/8/8/8/7/7/7/6/5
Emergency Healing 3/3
All healing spells (up to 3 targets) remove negative afflictions per panacea spells and also grant fast healing 10 for 24 rounds, also add +23 to the amount healed
Thus everyone is now together. The only question is this: Where on the Choking Path do you aim for, precisely?
Prince Westwind
HP: 490/490
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Mass Conviction (CL16), Tyche's Touch (CL16)
Bonuses: +1 morale attack rolls and will saves, immunity to fear and poison, +4 morale saves, +4 luck to saves, -1 each time.
Finnegan
HP: 356/356
He's going to aim for the "center" of it as best as he can, basically halfway through. Not that any one point of it is going to be much noticeably different from any other point.
