The lost fortress (Afina, Jaela; 85 days left)
Started by Anastasia, August 31, 2017, 03:16:29 PM
#31
Think we're good. Beyond the Aurora buffs Afina will cast the following on Jaela/Mei/The Master
Greater heroism (+4 morale attack/saves, +20 temp hp), epic mage armour (+20 armour AC). Both CL 27.
Afina 329+20/329
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 29), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), recitation (CL 30), sublime revelry (CL 31), death ward (CL 30), good hope (CL 30), interplanar telepathic bond (CL 26)
defences: AC 98 (touch 62), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, fear, mind-affecting, critical hits, negative energy, death effects, half damage from melee/ranged attacks
spell slots: 6/9/10/10/7/9/6/8/8/8/7/2/3
Spells I cast on everyone: Recitation CL30 (+2 luck to AC/attack/saving throws; +3 if worshiping the same religion), Sublime Revelry CL31 (take only half damage from melee and ranged attacks and are immune to mind-affecting effects), Mass Death Ward CL30 (immunity to death effects, energy drain and negative energy/negative levels), Good Hope CL30 (+2 morale to attack/damage/saves/ability checks/skill checks). Interplanar Telepathic Bond CL26 via Vul'lath. Hidden Dawn still shared with the Master.
Spells Active: Spell Turning CL26, Contingency CL32, Permanency/Greater Blindsight CL32, Permanency/Mantle of Good CL33, Foresight CL27, Moment of Prescience CL25, Lore of the Gods CL30, Invisibility Purge CL30, Fortunate Fate CL15, Mind Blank CL17, Greater Mage Armor CL7, Planar Tolerance CL7, Heroes Feast CL20, Righteous Halo CL28, Vision of the Omniscient Eye CL30, Greater Heroism CL27 (Afina), Shield of Warding CL31, Conviction CL31, Crown of Flame CL30, Sign CL30, Divine Insight CL33, Interplanar Telepathic Bond CL26 (Vul'lath), Sublime Revelry CL31, Mass Death Ward CL30, Good Hope CL30, Epic Mage Armor CL27 (Afina).
Short Duration Spells: Grace CL30, Recitation CL30.
Twinned Bolt of Glory -> Gae Dioltas.
Resistances and Immunities: Fire Immunity, Cold Resistance 10, Acid Resistance 20, Electricity Resistance 20, Sonic Resistance 20, Damage Reduction 25/Epic and Evil and Cold Iron, Spell Resistance 37 (49 vs Evil spells/permanent Mantle of Good), Immunity to Disease (normal and supernatural/magical), Immunity to Compulsion effects, Immunity to Petrification, Immunity to Sickened/Nauseated, Immunity to fear and poison/Heroes's Feast, Immunity to dazzled and blinded/Vision of the Omniscient Eye, Never surprised or flat-footed/Foresight, physical damage reduced by half/Sublime Revelry.
Golden Bracers (Hidden Dawn):
Flame Strike at will
Immunity to fire
Save bonuses increase to +7
And finally since I'm fuzzy headed today, where precisely are you gating to?
I'll do these properly when tonight or tomorrow, when I'm not so drained. Master and Mei.
Name
HP:
Name
HP:
Immunity to fire
As close as we can get to Syrel given the anti-teleport defences there. Hopefully Velasca gave us something useful there.
We're not worried about the terrain or cover since we're just gonna fly straight in and start wrecking things.
You appear in a cavern. It's as dark as you'd expect, warm but not overwhelmingly hot. It winds on ahead and rather sharply downwards.
It's a classical cave otherwise - stalagmites and stalactites, worn rock and that sort of thing. Nothing too fancy or unusual here.
Hoping Velasca's directions are good, Afina starts flying onwards at a good clip, not having any need to make a light source to see by.
Works. I'm glowing and have a spear out and can interrupt (not flat footed) in case magic's cast on us.
Great. Listen check for Jaela and Spot check for AFina then.
[18:34] <@Ebiris> roll 1d20+70 spot, blindsight 200
[18:34] <Rei-chan> Ebiris rolled : 1d20+70 spot, blindsight 200 --> [ 1d20=6 ]{76}
Afina can see it ahead with her supernaturally acute vision - faint wavers of semi visible magic, radiating around. There's sorcery ahead, likely various abjurations.
