'Probably, you can choose our best spot to go in by and I'll follow,' Afina agrees.
Jaela takes a quick look, before she's off with Gae Dioltas leading the way!
K:A&E 10 for 32, then a charge!
[21:28] <@Jessica> roll 1d20+51+7-26 charge, 26pa, divine might
[21:28] <Rei-chan> Jessica rolled : 1d20+51+7-26 charge, 26pa, divine might --> [ 1d20=2 ]{34}
[21:30] <@Jessica> roll 16d8+184+208+4d6
[21:30] <Rei-chan> Jessica rolled : 16d8+184+208+4d6 --> [ 16d8=79 4d6=17 ]{488}
Ion this case Jaela can see no advantage, so she just charges straight down. She slams into the roof and breaks through, stone shattering below.
In this room she can see bookshelves and over a dozen silken robed, humanish devils, cries of surprise from all of them as...
Init, all.
[19:55] <@Ebiris> roll 1d20+30
[19:55] <Rei-chan> Ebiris rolled : 1d20+30 --> [ 1d20=3 ]{33}
[21:56] <@Jessica> roll 1d20+18
[21:56] <Rei-chan> Jessica rolled : 1d20+18 --> [ 1d20=15 ]{33}
> roll 1d20+13 did you all remember Adrian's +4 aura to init?
<Rei-chan> Kotono rolled : 1d20+13 did you all remember Adrian's +4 aura to init? --> [ 1d20=2 ]{15}
> roll 1d20+9 Dana
<Rei-chan> Kotono rolled : 1d20+9 Dana --> [ 1d20=12 ]{21}
> roll 1d20+8 devils
<Rei-chan> Kotono rolled : 1d20+8 devils --> [ 1d20=4 ]{12}
Init is Afina = Jaela (33) > Dana (21) > Adrian (15) > Devils (12)
Go.
These don't look anything impressive, so Afina saves her spells and discharges a lightning bolt into one of the devils with a crackling boom, radiant lances of blue-white electricity splitting off from that unlucky devil to hit the rest!
[20:18] <@Ebiris> roll 1d20+27 chain lightning SR
[20:18] <Rei-chan> Ebiris rolled : 1d20+27 chain lightning SR --> [ 1d20=17 ]{44}
[20:18] <@Ebiris> roll 20d6 DC 31 ref half
[20:18] <Rei-chan> Ebiris rolled : 20d6 DC 31 ref half --> [ 20d6=64 ]{64}
Unlucky devil takes 64 (DC 31 ref half), all the rest take 32 (DC 31 ref half)
Afina 329+20/329
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 29), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), interplanar telepathic bond (CL 26), sublime revelry (CL 31), death ward (CL 31), good hope (CL 30), recitation (CL 30), haste (CL 27), control winds (CL 27)
defences: AC 99 (touch 62), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, fear, mind-affecting, critical hits, negative energy, & death effects, halved damage from melee and ranged attacks, 50% miss chance, freedom of movement
spell slots: 6/9/10/10/7/9/6/8/8/8/7/2/3
Actually no, so good reminder there.
Jaela is a whirlwind attacking the devils as she breaches the roof!
[22:18] <@Jessica> roll 1d20+53+7
[22:18] <Rei-chan> Jessica rolled : 1d20+53+7 --> [ 1d20=17 ]{77}
[22:18] <Rei-chan> Jessica rolled : 1d20+53+7 --> [ 1d20=4 ]{64}
[22:18] <@Jessica> roll 1d20+48+7
[22:18] <Rei-chan> Jessica rolled : 1d20+48+7 --> [ 1d20=18 ]{73}
[22:18] <@Jessica> roll 1d20+43+7
[22:18] <Rei-chan> Jessica rolled : 1d20+43+7 --> [ 1d20=17 ]{67}
[22:18] <@Jessica> roll 1d20+38+7
[22:18] <Rei-chan> Jessica rolled : 1d20+38+7 --> [ 1d20=16 ]{61}
[22:19] <@Jessica> roll 5#4d8+40+14+2+11d6+4d6
[22:19] <Rei-chan> Jessica rolled : 5#4d8+40+14+2+11d6+4d6 --> [ 4d8=19 11d6=34 4d6=16 ]{125}, [ 4d8=17 11d6=32 4d6=16 ]{121}, [ 4d8=15 11d6=29 4d6=9 ]{109}, [ 4d8=16 11d6=40 4d6=15 ]{127}, [ 4d8=22 11d6=50 4d6=12 ]{140}
Meanwhile, Adrian plunges down through the hole, Gaelach slicing out as he lands in a three point stance, an almost absent minded swing of his blade.
> roll 1d20+35 (+2 healer's vision, +2 charge, +4 morale, +2 luck, -26 PA)
<Rei-chan> Kotono rolled : 1d20+35 (+2 healer's vision, +2 charge, +4 morale, +2 luck, -26 PA) --> [ 1d20=3 ]{38}
> roll 2d6+96+9d6+4d6
<Rei-chan> Kotono rolled : 2d6+96+9d6+4d6 --> [ 2d6=7 9d6=37 4d6=16 ]{156}
Dana's just a hair behind him, but goes for a simple landing, shield up and defending.
Like this lightning rips into the devils. They shudder and convulse as it arcs between them, Jaela there to tear them apart. Each of her blows impales a devil and burns it into ash, a flurry of them. Yet only one survives between all of this, lunging at Jaela - until Adrian's swing neatly cuts it in half, its upper half falling at Jaela's feet before crumbling into volcanic ash.
That's one way to make an entrance. Free act.
Adrian
HP: 385+20/385
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Greater Heroism (CL27), Epic Mage Armor (CL27), Sublime Revelry (CL31), Mass Death Ward (CL30), Good Hope (CL30), Recitation (CL30)
Bonuses: +1 morale attack rolls and will saves, immunity to fear and poison, +4 morale attack/saves, +20 armor bonus, +7 saves, +4d6 goldenfire damage,
Dana
HP: +20/
Jaela makes another entrance for them in the floor!
[22:42] <@Jessica> roll 1d20+51+7-26 charge, 26pa, divine might
[22:42] <Rei-chan> Jessica rolled : 1d20+51+7-26 charge, 26pa, divine might --> [ 1d20=13 ]{45}
[22:42] <@Jessica> roll 16d8+184+208+8+4d6
[22:42] <Rei-chan> Jessica rolled : 16d8+184+208+8+4d6 --> [ 16d8=77 4d6=13 ]{490}
The floor beneath shatters, the hole beneath bisected by a wall. There's little gaps on either side, giving you tiny glimpses of rooms below, but not much.
Jaela immediately works at opening up the gap on the left, intending to head down that way.
Afina follows up with a disintegration ray aimed at that wall to properly clear the way into both rooms below, keeping their momentum up!
[18:07] <@Ebiris> roll 1d20 1 check
[18:07] <Rei-chan> Ebiris rolled : 1d20  check --> [ 1d20=13 ]{13}
Afina 329+20/329
spell slots: 6/9/10/10/7/9/5/8/8/8/7/2/3
Easy enough. The partitioning wall dissolves as Jaela expands the room open.
To the left is a storage room, a bit dusty and unremarkable. Old boxes and barrels are there, no sign of devils. To the right is a room with a desk, table, chairs and several cabinets. A single human in old, worn clothes is there, wiping a cloth over one of the cabinets. He turns up to stare in shock.
As you do...
Listen checks.
#149
[18:18] <@Ebiris> roll 1d20+70
[18:18] <Rei-chan> Ebiris rolled : 1d20+70 --> [ 1d20=9 ]{79}
83 with Adrian's aura
