Down and down and down you go. The steps are cold and clammy, slippery as you walk down. As you do you begin to hear groans of agony and...
Listen checks, all. Or being real, just Afina since she's SUPEREARS.
[19:18] <@Ebiris> roll 1d20+70
[19:19] <Serith> Ebiris roll for Serith < 72 > [d20=2]
Also flying and not walking, as per earlier warning about not touching the ground
It's the faintest sound - grinding from the walls on eithe rside. They're moving! Afina can hear it as...
Chance for one standard action, Afina.
'Look out, wall crushers!' Afina sends to Jaela to warn her, not able to do any more than that.
For Dana and Adrian who are close by she can be more useful at least, a pair of shimmering rainbow walls hugging the actual walls and extending down the passage.
6th level slot sacced as swift for 1 round time stop, casting a prismatic wall on the left during time stop and on the right afterwards. Walls are 108 feet long.
Afina 329/329
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 29), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), interplanar telepathic bond (CL 26), sublime revelry (CL 31), death ward (CL 31), good hope (CL 30), recitation (CL 30), haste (CL 27), control winds (CL 27), spell turning (CL 26)
defences: AC 103 (touch 66), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, fear, mind-affecting, critical hits, negative energy, & death effects, halved damage from melee and ranged attacks, 50% miss chance, freedom of movement
spell slots: 5/9/9/9/7/9/0/6/5/8/6/2/3
1 moment of prescience left
So you're walling to protect everyone but Jaela?
You know that is kind of a dick move. How far away is Jaela, can I see her? I can sacrifice a higher level spell to catch up and then put up walls to protect her during time stop too. If she's within 108 feet I don't even need to go that far!
Jaela, how far ahead were you from the others?
I went at the speed of 140ft, presumably the others are rushing after me at speed 100ft or so? I don't know how long we went for since we killed the last batch of devils as it wasn't described. If it's been a few rounds I'll be in range.
We'll say it's been 3 rounds, so Afina can do the math and see if you're in range or not.
That'd put Jaela 120 feet ahead of us. Just barely out of reach.
Okay, change my action to an 8th level slot for 3 rounds of time stop, and 4 walls placed total.
Afina 329/329
spell slots: 5/9/9/9/7/9/0/7/2/8/6/2/3
Walls of prismatic power spring up, blocking walls that cave in to squish the four of you. Dana whistles, "Damn, the old wall trap. That's a classic from any third rate bard."
"Thanks!" Jaela says quite gratefully. "Alright, new plan. I'll stay in range." This time when she proceeds, it's at a speed the others can manage so that they can deal with anything together.
Down you go, the chorus of the damned and tormented louder.  At the bottom of the stairs is a thick iron door, firmly shut and engraved with images of a nine layer pit. The images move, showing hapless souls condemned deeper and deeper down, forever plummeting.
Jaela disintegrates this door as well!
22:03 <Luisa> roll 1d20
22:03 <Serith> Luisa roll for Serith < 13 > [d20=13]
