[18:09] <@Ebiris> roll 1d20+26 fort
[18:09] <Kobot> Ebiris rolled 1d20+26 fort --> [ 1d20=20 ]{46}
As you eat, your stomach...deals. No queasiness, no pain. It gets easier as you go, if nothing else. Huh, you feel just fine, if full.
"I think that's the most stoic steak-eating expression I've ever seen on anyone," Jaela notes, eating another better sized for her.
Well of course, the mess hall's food is the best no matter what it is! "Mmmph," she grunts, heaving herself into the air and running a hand over her stomach, feeling like her outfit is slightly stretched there now. "Who do you think's a good fit for this mission?" she asks Jaela. "I'm thinking Moonlight and Dana. We should make sure we have people standing by to make Gates from this end as well, if we have 900 sacrifices to evacuate."
"I thought Moonlight went off on some quest for Lathander?" Jaela voices, trusting in Elena to fill them in. "How about subbing Adrian for her? I wanted to invite my brother along, but there will be other opportunities and it'd feel kinda nostalgic."
"Oh, did she? Adrian's a good pick then, yes," Afina agrees with that correction.
#83
Afina casts her usual spells on herself and the following two spells on Jaela/Dana/Adrian
Greater heroism (+4 morale attack/saves, +20 temp hp), epic mage armour (+20 armour AC). Both CL 27.
We'll get an interplanar telepathic bond cast via Vul'lath.
Afina 329+20/329
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 29), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), interplanar telepathic bond (CL 26), sublime revelry (CL 31), death ward (CL 31), good hope (CL 30), recitation (CL 30)
defences: AC 98 (touch 62), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, fear, mind-affecting, critical hits, negative energy, & death effects, halved damage from melee and ranged attacks
spell slots: 6/9/10/10/7/9/6/8/8/8/7/2/3
Vul'lath and Tepen on standby to open portals, so they should be at the end of the courtyard by Aurora's gates and both linked to us telepathically. Adrian wears the other half of Golden Dawn. Also, spells!
Golden Dawn
Rank 1: CR 10 or sparring, fire resistance 10, 100ft range.
Rank 2: CR 13, +2 fortitude saves, 125ft range.
Rank 3: CR 15, searing light at will as an SLA, 150ft range.
Rank 4: CR 18, +2 reflex saves, 200ft range.
Rank 5: CR 20, flame strike at will, 300ft range.
Rank 6: CR 21, +2 will saves, 400ft range.
Rank 7: CR 24, +2d6 goldenfire damage on weapon damage rolls, natural attacks and spells and spell-like abilities with the fire descriptor, 700ft range.
Rank 8: CR 27, immunity to fire, 1000ft range.
Rank 9: CR 29, save bonuses increase to +7, 5000ft range.
Rank 10: CR 32, goldenfire damage rises to +4d6, unlimited range as long as on same plane.
Spells
Spells I cast on everyone: Sublime Revelry CL31, Mass Death Ward CL30, Good Hope CL30.
Spell I cast on everyone, it has a short duration: Recitation CL30.
Halved physical damage, negated 'pain' attacks, immunity to negative energy/death effects/energy drain, +2 morale to attack/damage/saves/ability checks/skill checks, +2 luck to AC/attack/saving throws or +3 if worshiping the same religion
Spells Active: Spell Turning CL26, Contingency CL32, Permanency/Greater Blindsight CL32, Permanency/Mantle of Good CL33, Foresight CL27, Moment of Prescience CL25, Lore of the Gods CL30, Invisibility Purge CL30, Fortunate Fate CL15, Mind Blank CL17, Greater Mage Armor CL7, Planar Tolerance CL7, Heroes Feast CL20, Righteous Halo CL28, Vision of the Omniscient Eye CL30, Greater Heroism CL27, Shield of Warding CL31, Conviction CL31, Crown of Flame CL30, Sign CL30, Divine Insight CL33, Interplanar Telepathic Bond CL26, Sublime Revelry CL31, Mass Death Ward CL30, Good Hope CL30, Epic Mage Armor CL27.
Short Duration Spells: Grace CL30, Recitation CL30.
Okay finally, where are you teleporting to?
Dumping ground for now, I'll do the spoiler blocks tonight.
Deephome. Trusting more travelled people like Adrian and Jaela to know more about where that actually is on Lifasa and good spots for gating in nearby.
"Ready," Adrian says, Gaelach out as Dana walks behind him. "How much resistance are we expecting?"
The four of you are at Aurora's outer gate, ready to go.
To be finished next post with hit points.
Adrian
HP: +20/
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Greater Heroism (CL27), Epic Mage Armor (CL27), Sublime Revelry (CL31), Mass Death Ward (CL30), Good Hope (CL30), Recitation (CL30)
Bonuses: +1 morale attack rolls and will saves, immunity to fear and poison, +4 morale attack/saves, +20 armor bonus, +7 saves, +4d6 goldenfire damage,
Dana
HP: +20/
"I'm expecting it to be heavy," Afina answers. "They know they're being targetted, and Quinn must be feeling particularly vulnerable before he can complete the ritual. Taelfagn's providing direct support in the form of sacrifices, and likely additional forces for defence. We might even see Gathgorian here. Still, remember that our goal is to kill or capture Quinn, and obtain his sigil. That's the main priority above everything else, although ideally we'll be able to secure the area long enough to evacuate the sacrifices."
"Killing Gathgorian or Taelfagn would rate higher, but yes. As for the hostages, we'll come up with the best way to rescue them while taking out Quinn once we see the situation." Jaela tilts her head. "What if we brought one of the ships?"
