Gar-Malleos
all actions performed
This lava is really getting annoying... Moore gestures to try and block it off for a while, it'll at least buy them some relief, if nothing else!
Wall of Stone, he has 80 ft to work with and each wall is 4 inches thick. His idea is to just block off as much of the lava as possible with it.
He is using his move action to maintain Inspire Competence. Inspire Courage is at 9 rounds left.
Surru stats: 369/369[423/423]+13
Active Spells: mind blank (CL17), fortunate fate (CL15), planar tolerance (CL7) and greater mage armor(CL5), Superior Resistance (CL 27), True Seeing (CL10), Bibliotecha Arcana (CL27). Sublime Revelry CL31, Mass Death Ward CL30, Good Hope CL30, agility of dragon princess (CL 28), Surraruthru's Stupendous Dragonskin, CL 28, endurance of dragon princess (CL 28), beauty of dragon princess (CL 28), magic tattoo (CL 28), magic tattoo (CL 28), energy immunity (acid) (CL 28), energy immunity (sonic) (CL 28), energy immunity (elec) (CL 28), Foresight (CL27)
HP: 363(31)(385/415)
AC: 62 (86), 46 (53) touch, 52 (59) flatfooted 20% miss chance, SR 41, 30 resist all to elements
28/32 Bardic music uses 3/3 Refrain
Fort +36 (40), Ref +40 (46), Will +41 (43) (+6 due to Superior Resistance)
+14 to initiative for everyone
Spells:
0th - 4/4 (DC 22)
1st - 7/7
2nd - 7/7
3rd - 7/7
4th - 7/7
5th - 6/6
6th - 6/6
7th - 6/6
8th - 5/5
9th - 1/1
Favored Soul:
0th - 5/5
1st - 9/9
2nd - 9/9
3rd - 8/8
4th - 8/8
5th - 8/8
6th - 8/8
7th - 6/6
8th - 4/4
+1 Luck Bonus on Attack Rolls
Additionally, the below are pre-loaded into the Tapestry for activation as Quiescent Weaving:
Resist Energy, CL 26, Duration 260 Minutes. (4 castings)
Subject gains energy resistance to: Acid, Electricity, Fire, Sonic of 30 points.
[/spoiler]
Init is Afina (64) > Moore (50) > Jaela (40) > Surraruthru (38) >  Mei (31) > ???? (27) > Canderella (24) > ???? 1 (22) > Lava (20)
Cool. Jaela, you're up.
Having the utmost trust in Afina and Mei's ability to annihilate the remaining opposition, Jaela presses on!
Ahead are two passages. The way goes sharply down, heat rising up from there. No guards there yet.
A bit and to the right is a little cleft in the wall, a passage there as well. A rather narrow one all told.
'Heading down!' Jaela mentally relays, trusting in her protections and braving the heat.
What magic seeing and visual augmentations do you have up, including true seeing if you have it?
Blindsight 60ft, Invisibility Purge 140ft
90ft ahead of you, the lava is rising up. Ahead is a chamber with dozens of little slits in thew all, arrows or wands pointing out of it. The lava is solidifying, as a vast iron gate blocks the way ahead, closed firmly shut.
Jaela rams that iron gate, even as her power lashes out at all those she can sense behind those murder holes ready to kill her!
20:59 <Luisa> roll 1d20+51+16+6+8-26+3 diving charge at iron gate!
20:59 <Rei-chan> Luisa rolled : 1d20+51+16+6+8-26+3 diving charge at iron gate! --> [ 1d20=10 ]{68}
20:59 <Luisa> roll 16d8+184+208+80+4d6
20:59 <Rei-chan> Luisa rolled : 16d8+184+208+80+4d6 --> [ 16d8=78 4d6=13 ]{563}
21:01 <Luisa> roll 1d20+30+14+2 SR for burnings
21:01 <Rei-chan> Luisa rolled : 1d20+30+14+2 SR for burnings --> [ 1d20=13 ]{59}
21:01 <Luisa> roll 2d6+4d6 goldenfire
21:01 <Rei-chan> Luisa rolled : 2d6+4d6 goldenfire --> [ 2d6=9 4d6=13 ]{22}
21:10 <Luisa> roll 1d20+30+14+2 SR for wiltings
21:10 <Rei-chan> Luisa rolled : 1d20+30+14+2 SR for wiltings --> [ 1d20=12 ]{58}
21:10 <Luisa> roll 20d6
21:10 <Rei-chan> Luisa rolled : 20d6 --> [ 20d6=60 ]{60}
Twinned, so 120 damage. Fort DC 34 half, undead and evil outsiders save at -4.
21:10 <Luisa> roll 20d6 holy acid rain for the nessian(s)
21:11 <Rei-chan> Luisa rolled : 20d6 holy acid rain for the nessian(s) --> [ 20d6=72 ]{72}
Ref DC 36 half, Nessians save at -8.
Ending the turn with Gae Bolg in Gambit. Will counterspell twice with Chain Dispel (+35 roll).
Init: +18/+22 with Sign
HP: 490+52/490
AC: 83 =75base+2Foresight+3Recitation+1Grace+2cha of the dragon princess, 20% miss chance
AC: 99 =75base+2Foresight+3Recitation+5ShieldOfWarding+1Grace+2cha of the dragon princess+5surru's dragonskin/NA+6epic MA/armor, 20% miss chance
Touch AC: 80 =69base+2+3+5+1
Full Attack (Gae Bolg, GMW, HW, DP +3, haste, K:D +5, *Greater Heroism +4 morale/attack, *Good Hope +2 morale/damage, Recitation +3 luck/attack, *CMT +2 competence/attack, Moore +8 competence/attack, Moore +6 untyped/attack, Moore +16 morale/attack, Moore +16 morale/damage, Moore +4 untyped/damage, SotDP +2 attack/+3 damage, Divine Might +16 damage): +64/+64/+59/+54/+49 or +70 AoO, 4d8+59+11d6+4d6 last is goldenfire and 1 negative level, silver+good+anarchic+epic
[not used: CV +4 sacred attack/damage, Divine Favor +3 luck/damage]
Spells Active: Spell Turning CL26, Contingency CL32, Permanency/Greater Blindsight CL32, Permanency/Mantle of Good CL33, Foresight CL27, Moment of Prescience CL25, Lore of the Gods CL30, Invisibility Purge CL30, Fortunate Fate CL15, Mind Blank CL17, Greater Mage Armor CL7, Planar Tolerance CL7, Heroes Feast CL20, Righteous Halo CL28, Vision of the Omniscient Eye CL30, Greater Heroism CL27, Shield of Warding CL31, Conviction CL31, Crown of Flame CL30, Sign CL30, Divine Insight CL33, Interplanar Telepathic Bond CL26, Sublime Revelry CL31, Mass Death Ward CL30, Good Hope CL30, Epic Mage Armor CL24.
Short Duration Spells: Grace CL30, *Moonlight Revelation CL30, Recitation CL30, Haste CL27.
Resistances and Immunities: Fire Immunity, Cold Immunity, Acid Immunity, Electricity Immunity, Sonic Immunity, Damage Reduction 25/Epic and Evil and Cold Iron, Spell Resistance 37 (49 vs Evil spells/permanent Mantle of Good), Immunity to Disease (normal and supernatural/magical), Immunity to Compulsion effects, Immunity to Petrification, Immunity to Sickened/Nauseated, Immunity to fear and poison/Heroes's Feast, Immunity to dazzled and blinded/Vision of the Omniscient Eye, Never surprised or flat-footed/Foresight, physical damage reduced by half/Sublime Revelry, Immune to poison, sleep, paralysis, and stunning, and are not subject to extra damage from critical hits or flanking/Elemental Immunity (Fire).
Spells Left (1-9): 7/9/4/5/8/8/8/6/7
Spells Left (10-12): 7/2/4
DC: 26 + spell level
Saves: conviction +5, shield of warding ref +5, recitation +3, foresight ref +2, haste ref +1, hidden dawn +7, grace ref +1, dex of the dragon princess +2, con of the dragon princess +2
Saves: Fort +68, Ref +69, Will +66
Gae Bolg: GMW, Keen Edge
Gae Trocaire: GMW, Keen Edge
Turning Left: 18/19
Taking ten for K:A 62, K:N 41, K:R 65, K:P 65, Spellcraft 54
-Flame Strike x2
-Twinned Quickened Horrid Wilting
Hidden Dawn used with Canderella
Golden Bracers (Hidden Dawn):
Flame Strike at will
Immunity to fire
Save bonuses increase to +7
Fort save real quick, -10 penalty.
21:25 <Luisa> roll 1d20+68-10
21:25 <Rei-chan> Luisa rolled : 1d20+68-10 --> [ 1d20=20 ]{78}
Glorious Solar bullshit~
You slam through the gate, punching right through as it melts with holy flame. At the same time your body screams, an echo of the assault rippling through you. It ripples through the iron gate, causing it to crack and fall apart further as pain explodes through your body.
281 damage. Doesn't beat your regen to nonlethal.
> roll 1d20+24 wilting 1
> roll 1d20+24 wilting 3
<Rei-chan> Kotono rolled : 1d20+24 wilting 1 --> [ 1d20=16 ]{40}
<Rei-chan> Kotono rolled : 1d20+24 wilting 3 --> [ 1d20=6 ]{30}
> roll 1d20+49 (+6 ???, +1 ???, +3 ???, +3 ???) Nessian 1
<Rei-chan> Kotono rolled : 1d20+49 (+6 ???, +1 ???, +3 ???, +3 ???) Nessian 1 --> [ 1d20=16 ]{65}
> roll 1d20+52 (+6 ???, +3 ???, +3 ???) Nessian 2
<Rei-chan> Kotono rolled : 1d20+52 (+6 ???, +3 ???, +3 ???) Nessian 2 --> [ 1d20=6 ]{58}
> OOC: -8 from those.
Rain falls. Water is sucked away. The world is odd to Jaela in her momentary flash of pain, but her spells suppress it. Two passages connect to either of your sides, narrow halls that feed into the bolt-holes. Erinyes man them, screaming as you wound and desiccate them. Ahead is a stairway going down as stone walls go up back by Moore, giving them some shielding from the lava.
Surru.
#163
Surru will hold in order to counter any spells the Nessians decide to cast since Jaela isn't here to do it.
Maybe the correct term is ready an action? Either way he's ready!!!
HP: (229) 490/490
Turning Left: 18/19
-Flame Strike x2
Immunity to fire
