"Our arrogance is our power."
Gar-Malleos
The enervation hits dead on, withering the surviving humanoid as...
Success. It's now Mei and Moore. Go Moore.
i am on my way home so give me 25m
Alright, I'll have Mei go in the meantime.
Mei meanwhile stays back and sends a single blast at the drained humanoid.
Can't fail the SR check, so going to the attack roll.
> roll 1d20 1 check
<Rei-chan> Kotono rolled : 1d20  check --> [ 1d20=20 ]{20}
> roll 1d20 1 check crit?
<Rei-chan> Kotono rolled : 1d20  check crit? --> [ 1d20=13 ]{13}
> roll 30d6+14+5d6+2d6
<Rei-chan> Kotono rolled : 30d6+14+5d6+2d6 --> [ 30d6=107 5d6=19 2d6=10 ]{150}
This goes right through the humanoid's stomach, armor punched cleanly through. He hits the ground in a heap, bleeding and groaning as...
Init is Afina (54) > Jaela (48) > Surru (43) > Mei (39) > Moore (35) > Canderella (30) > Cornugons (23) > Lava (0)
Moore.
For now, since only some enemies are left, Moore will block off the lava as best he can with a Wall of Stone!
90 ft of area to work with, so he'll block off whatever he can.
Stone protects all of you as Canderella holds her ground, merely gesturing at the remnant as lightning strikes again, this time a burst of chain lightning into them.
SR not needed due to boosts, autopass.
> roll 20d6
<Rei-chan> Kotono rolled : 20d6 --> [ 20d6=65 ]{65}
> roll 1d20+24 cornugons
<Rei-chan> Kotono rolled : 1d20+24 cornugons --> [ 1d20=4 ]{28}
Some of the cornugons go down and others endure, the hoard being pushed backa s lightning strikes from the ceiling. Lava is held back as this time the cornugons charge, going right into the teeth of all of you, spreading out with precision, swarming.
> roll 1d20+53 (+2 ???, +5 ???, +1 ???) vs Afina
<Rei-chan> Kotono rolled : 1d20+53 (+2 ???, +5 ???, +1 ???) vs Afina --> [ 1d20=10 ]{63}
> roll 1d20+53 (+2 ???, +5 ???, +1 ???) vs Jaela
<Rei-chan> Kotono rolled : 1d20+53 (+2 ???, +5 ???, +1 ???) vs Jaela --> [ 1d20=15 ]{68}
> roll 1d20+53 (+2 ???, +5 ???, +1 ???) vs Moore
<Rei-chan> Kotono rolled : 1d20+53 (+2 ???, +5 ???, +1 ???) vs Moore --> [ 1d20=6 ]{59}
> roll 1d20+53 (+2 ???, +5 ???, +1 ???) vs Surraruthru
<Rei-chan> Kotono rolled : 1d20+53 (+2 ???, +5 ???, +1 ???) vs Surraruthru --> [ 1d20=20 ]{73}
> roll 1d20+53 (+2 ???, +5 ???, +1 ???) vs Surraruthru crit?
<Rei-chan> Kotono rolled : 1d20+53 (+2 ???, +5 ???, +1 ???) vs Surraruthru crit? --> [ 1d20=15 ]{68}
> roll 1d20+53 (+2 ???, +5 ???, +1 ???) vs Canderella
<Rei-chan> Kotono rolled : 1d20+53 (+2 ???, +5 ???, +1 ???) vs Canderella --> [ 1d20=12 ]{65}
> roll 1d20+53 (+2 ???, +5 ???, +1 ???) vs Mei
<Rei-chan> Kotono rolled : 1d20+53 (+2 ???, +5 ???, +1 ???) vs Mei --> [ 1d20=6 ]{59}
ACs, all?
Canderella
HP: 290/383
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (CL28), Surraruthru's Stupendous Dragonskin (CL28) Everything But Wisdom of the Dragon Princess (CL28), Create Magic Tattoox2 (CL28), Energy Immunityx4 (CL28), Sublime Revelry (CL31), Mass Death Ward (CL30), Recitation (CL30), Haste (CL27)
Bonuses: +1 morale attack rolls and will saves, immunity to fear and poison, elemental traits, immunity to elemental damage, +10 armor bonus to AC and damage reduction 10/magic, +4 insight to all stats but Wisdom, +1 luck attack rolls, +2 competence attack rolls, halved damage from melee attacks, immunity to pain, immunity to negative energy and energy drain, +2 luck AC/attacks/saving throws, +1 attack rolls haste, +1 attacks, movement speed bonus, +1 reflex saves haste.
Resources Used: 2 9th, 2 10th, 2 11th level spells
Mei
HP: 422/502
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (CL28), Surraruthru's Stupendous Dragonskin (CL28) Everything But Wisdom of the Dragon Princess (CL28), Create Magic Tattoox2 (CL28), Energy Immunityx4 (CL28), Sublime Revelry (CL31), Mass Death Ward (CL30), Recitation (CL30), Heavenly Grace (CL26), Haste (CL27)
Heavenly Grace
Epic; 9th
You are protected by the forces of righteousness and safe from death. You are immune to negative energy, energy drain, ability damage and ability drain for 24 hours. Creatures who use these against you suffer 7d6 points of damage each time they do.
Celestial Valor CL31:  +8 sacred bonus to saving throws against fear and calm emotions/crushing despair/similar emotional effects, a +4 sacred bonus to attack rolls, weapon damage rolls, armor class and saving throws, and any weapon they use counts as a holy weapon for the duration, granting 2d6 extra damage against evil targets (doesn't stack if the weapon already has the holy special property).
+16 morale bonus on saving throws against charm and fear effects and a +16 morale bonus on attack and weapon damage rolls for everyone, Afina gets +18 to these bonuses instead.
Everyone also gets +2 to attack rolls and +2 to CL just for being cool and listening.
111, also Afina is way further down the tunnel away from everyone else past the dead pit fiend
Afina 383+52/383
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 29), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), interplanar telepathic bond (CL 26), sublime revelry (CL 31), death ward (CL 31), good hope (CL 30), recitation (CL 30), shield (CL 27), agility of dragon princess (CL 28), endurance of dragon princess (CL 28), beauty of dragon princess (CL 28), magic tattoo (CL 28), magic tattoo (CL 28), energy immunity (acid) (CL 28), energy immunity (sonic) (CL 28), energy immunity (elec) (CL 28), haste (CL 27), planar bubble (CL 27), shadow form (CL 27), celestial valour (CL 31)
defences: AC 111 (touch 71), spell resistance 42, immunity to fire, water, earth, cold, acid, sonic, electricity, disease, poison, fear, mind-affecting, critical hits, negative energy, & death effects, halved damage from melee and ranged attacks, freedom of movement, 50% miss chance
spell slots: 6/9/8/9/5/8/7/6/3/7/7/4/3
Attack: +91 (1d4+52 + various)
> roll 1d9 Surru mirror image
<Rei-chan> Kotono rolled : 1d9 Surru mirror image --> [ 1d9=7 ]{7}
Everyone misses then, I know a 68 doesn't tag Jaela.
Yet amid the flurry not one touches you as...
Afina, go.
AC 103, 20% miss chance.
Init: +18/+22 with Sign
HP: 52+490/490
AC: 83 =75base+2Foresight+3Recitation+1Grace+2cha of the dragon princess, 20% miss chance
AC: 103 =75base+2Foresight+3Recitation+5ShieldOfWarding+1Grace+2cha of the dragon princess+5surru's dragonskin/NA+6epic MA/armor+4sacred, 20% miss chance
Touch AC: 86 =69base+2+3+5+1+2+4
Full Attack (Gae Bolg, GMW, HW, DP +3, haste, K:D +5, *Greater Heroism +4 morale/attack, *Good Hope +2 morale/damage, Recitation +3 luck/attack, *CMT +2 competence/attack, Moore +8 competence/attack, Moore +6 untyped/attack, Moore +16 morale/attack, Moore +16 morale/damage, Moore +4 untyped/damage, SotDP +2 attack/+3 damage, CV +4 sacred attack/damage, Divine Might +16 damage):
53/+53/+48/+43/+38, or +59 AoO, 4d8+40+11d6+4d6 last is goldenfire and 1 negative level, silver+good+anarchic+epic
+39 overall boosts to attack, +43 overall boosts to damage
[not used: Divine Favor +3 luck/damage]
Spells Active: Spell Turning CL26, Contingency CL32, Permanency/Greater Blindsight CL32, Permanency/Mantle of Good CL33, Foresight CL27, Moment of Prescience CL25, Lore of the Gods CL30, Invisibility Purge CL30, Fortunate Fate CL15, Mind Blank CL17, Greater Mage Armor CL7, Planar Tolerance CL7, Heroes Feast CL20, Righteous Halo CL28, Vision of the Omniscient Eye CL30, Greater Heroism CL27, Shield of Warding CL31, Conviction CL31, Crown of Flame CL30, Sign CL30, Divine Insight CL33, Interplanar Telepathic Bond CL26, Sublime Revelry CL31, Mass Death Ward CL30, Good Hope CL30, Epic Mage Armor CL24, Celestial Valor CL31.
Short Duration Spells: Grace CL30, *Moonlight Revelation CL30, Recitation CL30, Haste CL27.
Resistances and Immunities: Fire Immunity, Cold Immunity, Acid Immunity, Electricity Immunity, Sonic Immunity, Damage Reduction 25/Epic and Evil and Cold Iron, Spell Resistance 37 (49 vs Evil spells/permanent Mantle of Good), Immunity to Disease (normal and supernatural/magical), Immunity to Compulsion effects, Immunity to Petrification, Immunity to Sickened/Nauseated, Immunity to fear and poison/Heroes's Feast, Immunity to dazzled and blinded/Vision of the Omniscient Eye, Never surprised or flat-footed/Foresight, physical damage reduced by half/Sublime Revelry, Immune to poison, sleep, paralysis, and stunning, and are not subject to extra damage from critical hits or flanking/Elemental Immunity (Fire).
Spells Left (1-9): 7/9/4/5/8/6/7/4/3
Spells Left (10-12): 6/2/4
DC: 26 + spell level
Saves: conviction +5, shield of warding ref +5, recitation +3, foresight ref +2, haste ref +1, hidden dawn +7, grace ref +1, dex of the dragon princess +2, con of the dragon princess +2
Saves: Fort +72, Ref +73, Will +70
Gae Bolg: GMW, Keen Edge
Gae Trocaire: GMW, Keen Edge
Turning Left: 16/19
-Smite x3
Taking ten for K:A 62, K:N 41, K:R 65, K:P 65, Spellcraft 54
-Consecrate
-Flame Strike x4 (all)
-Twinned Horrid Wilting
-Twinned Quickened Horrid Wilting
Hidden Dawn used with Canderella
Golden Bracers (Hidden Dawn):
Flame Strike at will
Immunity to fire
Save bonuses increase to +7
With the cornugons in melee like that, Afina can't really fireball them so she settles for lightning instead!
[18:36] <@Ebiris> roll 1d20+27+16 chain lightning sla
[18:36] <Rei-chan> Ebiris rolled : 1d20+27+16 chain lightning sla --> [ 1d20=6 ]{49}
[18:37] <@Ebiris> roll 20d6 primary target
[18:37] <Rei-chan> Ebiris rolled : 20d6 primary target --> [ 20d6=60 ]{60}
DC 31 ref half, 30 damage to secondary targets with the same save.
<Rei-chan> Kotono rolled : 1d20+24 cornugons --> [ 1d20=9 ]{33}
Lightning arc through the cornugons, a few more falling to dust and ash, yet others remaining in the melee. They're battered and broken, the gear of the defeated littering the ground as..
Jaela.
Jaela decides to murder a few cornugons that foolishly remain in melee.
[21:31] <@Lisa> roll 1d20+53+39
[21:31] <Rei-chan> Lisa rolled : 1d20+53+39 --> [ 1d20=8 ]{100}
[21:31] <Rei-chan> Lisa rolled : 1d20+53+39 --> [ 1d20=15 ]{107}
[21:31] <@Lisa> roll 1d20+48+39
[21:31] <Rei-chan> Lisa rolled : 1d20+48+39 --> [ 1d20=17 ]{104}
[21:31] <@Lisa> roll 1d20+43+39
[21:31] <Rei-chan> Lisa rolled : 1d20+43+39 --> [ 1d20=3 ]{85}
[21:31] <@Lisa> roll 1d20+38+39
[21:31] <Rei-chan> Lisa rolled : 1d20+38+39 --> [ 1d20=17 ]{94}
[21:32] <@Lisa> roll 4d8+40+11d6+d46+43
[21:32] <Rei-chan> Lisa rolled : 4d8+40+11d6+d46+43 --> [ 4d8=18 11d6=39 1d46=25 ]{165}
[21:32] <Rei-chan> Lisa rolled : 4d8+40+11d6+d46+43 --> [ 4d8=6 11d6=44 1d46=39 ]{172}
[21:32] <Rei-chan> Lisa rolled : 4d8+40+11d6+d46+43 --> [ 4d8=23 11d6=34 1d46=2 ]{142}
[21:32] <Rei-chan> Lisa rolled : 4d8+40+11d6+d46+43 --> [ 4d8=19 11d6=42 1d46=8 ]{152}
[21:32] <Rei-chan> Lisa rolled : 4d8+40+11d6+d46+43 --> [ 4d8=13 11d6=35 1d46=23 ]{154}
HP: 52+490/490
Turning Left: 16/19
-Smite x3
-Consecrate
Immunity to fire
Jaela is simply a force. She walks amid the cornugons and from where they are struck, they die. The remnant is wiped out in seconds, the way ahead cleared. Victory!
Free act.
Jaela follows the pull of the Path!
