Gar-Malleos
"Too much risk of us being defeated in detail if we do that," Afina says, disliking the idea of splitting up.
Seriously, do Jaela and Surru have any epic dispels left? I think running out was a concern back during the last fight, and if they don't have any we may as well start carving our way out because we won't be able to dispel the dimensional lock anyway.
Out of them, and almost out of chain dispels. I'm fairly light on high level spells at present.
Incidentally, Dune, could you show NPC damage? I want to see if I need to use a quickened heal here.
"I think, then, the best idea is to simply go up to get out of here. They have to assume we're still down here in a protracted battle with that dragon, I'd guess." Moore says. "Either that or go back the way we came, but that has to have been reinforced by now."
They're at full. Going up then, y'all?
Init: +17/+21 with Sign
HP: 52+490/490
*AC: 83 =75base+2Foresight+3Recitation+1Grace+2cha of the dragon princess, 20% miss chance
*AC: 103 =75base+2Foresight+3Recitation+5ShieldOfWarding+1Grace+2cha of the dragon princess+5surru's dragonskin/NA+6epic MA/armor+4sacred, 20% miss chance
*Touch AC: 86 =69base+2+3+5+1+2+4
*Full Attack (Gae Bolg, GMW, HW, DP +3, haste, K:D +5, *Greater Heroism +4 morale/attack, *Good Hope +2 morale/damage, Recitation +3 luck/attack, *CMT +2 competence/attack, Moore +8 competence/attack, Moore +6 untyped/attack, Moore +16 morale/attack, Moore +16 morale/damage, Moore +4 untyped/damage, SotDP +2 attack/+3 damage, CV +4 sacred attack/damage, Divine Might +16 damage, Divine Favor +3 luck/damage):
53/+53/+48/+43/+38, or +59 AoO, 4d8+40+11d6+4d6 last is goldenfire and 1 negative level, silver+good+anarchic+epic
*+44 overall boosts to attack, +53 overall boosts to damage
*Spells Active: Spell Turning CL26, Contingency CL32, Permanency/Greater Blindsight CL32, Permanency/Mantle of Good CL33, Foresight CL27, Moment of Prescience CL25, Lore of the Gods CL30, Invisibility Purge CL30, Fortunate Fate CL15, Mind Blank CL17, Greater Mage Armor CL7, Planar Tolerance CL7, Heroes Feast CL20, Righteous Halo CL28, Vision of the Omniscient Eye CL30, Greater Heroism CL27, Shield of Warding CL31, Conviction CL31, Crown of Flame CL30, Sign CL30, Divine Insight CL33, Interplanar Telepathic Bond CL26, Sublime Revelry CL31, Mass Death Ward CL30, Good Hope CL30, Epic Mage Armor CL24.
*Short Duration Spells: Grace CL30, Moonlight Revelation CL30, Recitation CL30, Haste CL27, Divine Favor CL30, Celestial Valor CL31.
Spells Active: Spell Turning CL30, Fortunate Fate CL30, Shield of Warding CL31, Conviction CL31, Moment of Prescience CL25, Righteous Halo CL28, Greater Heroism CL30, Vision of the Omniscient Eye CL30, Foresight CL27
Short Duration Spells: Haste CL30
*Resistances and Immunities: Fire Immunity, Cold Immunity, Acid Immunity, Electricity Immunity, Sonic Immunity, Damage Reduction 25/Epic and Evil and Cold Iron, Spell Resistance 37 (49 vs Evil spells/permanent Mantle of Good), Immunity to Disease (normal and supernatural/magical), Immunity to Compulsion effects, Immunity to Petrification, Immunity to Sickened/Nauseated, Immunity to fear and poison/Heroes's Feast, Immunity to dazzled and blinded/Vision of the Omniscient Eye, Never surprised or flat-footed/Foresight, physical damage reduced by half/Sublime Revelry, Immune to poison, sleep, paralysis, and stunning, and are not subject to extra damage from critical hits or flanking/Elemental Immunity (Fire).
Spells Left (1-9): 6/9/3/5/8/5/7/1/0
Spells Left (10-12): 4/0/0
DC: 24 + spell level
Saves: conviction +5, shield of warding ref +5, recitation +3, foresight ref +2, haste ref +1, hidden dawn +7, grace ref +1, dex of the dragon princess +2, con of the dragon princess +2
*Saves: Fort +72, Ref +73, Will +70
Gae Bolg: GMW, Keen Edge
Gae Trocaire: GMW, Keen Edge
Turning Left: 12/17
-Smite x5
Taking ten for K:A 62, K:N 41, K:R 65, K:P 65, Spellcraft 54
-Consecrate
-True Strike x3
-Flame Strike x4 (all)
-Foresight x2 (all)
-Moment of Prescience x2
-Twinned Horrid Wilting
-Twinned Quickened Horrid Wilting
Hidden Dawn used with Canderella
Golden Bracers (Hidden Dawn):
Flame Strike at will
Immunity to fire
Save bonuses increase to +7
"Up it is, then," Afina promptly fires a disintegrate at the ceiling above them.
[18:37] <@Ebiris> roll 1d20 1 check
[18:37] <Kobot> Ebiris rolled 1d20 1 check --> [ 1d20=10 ]{10}
Afina 242+20/329
active spells: haste (CL 27), scalding touch (CL 31), many moments of prescience (CL 31), epic mage armour (CL 29), greater heroism (CL 29), planar bubble (CL 30), shield (CL 30), spell-turning (CL 30), stupendous dragonskin (CL 30), magic tattoo (CL 26), magic tattoo (CL 26)
defences: AC 99 (touch 73), spell resistance 42, immunity to fire, water, earth, cold, disease, poison, critical hits, freedom of movement, 50% miss chance
perceptions: low-light vision, blindsight 200, all around vision, see invisible/ethereal, darkvision 60, spot +70, listen +70
spell slots: 6/9/8/9/1/6/0/3/1/4/3/0/1
Jaela charges into the newly-made hole, either to widen it or to crush the devils revealed past it!
Quickened Heal on myself to bring me back to max.
HP: 20+490/490
Spells Left (1-9): 6/9/3/5/8/4/7/1/0
Turning Left: 12/17
-Smite x5
-Consecrate
-True Strike x3
-Foresight x2 (all)
Immunity to fire
Past the cube of stone disintegrated is more stone, Jaela plowing into it.
1 check.
[20:42] <@Lisa> roll 1d20
[20:42] <Kobot> Lisa rolled 1d20 --> [ 1d20=5 ]{5}
1 avoided!
> roll 1d100
<Kobot> Kotono rolled 1d100 --> [ 1d100=53 ]{53}
You break up into a flame-scorched room, a stone door leading in one direction and a connecting hallway without a door on the other.
"Keep going up?" Moore asks.
Flying up after Jaela widens the hole, Afina throws another disintegrate upwards!
[18:49] <@Ebiris> roll 1d20 1 check
[18:49] <Kobot> Ebiris rolled 1d20 1 check --> [ 1d20=7 ]{7}
Afina 242+20/329
spell slots: 6/9/8/9/1/6/0/2/1/4/3/0/1
Jaela repeats her earlier feat!
[20:50] <@Lisa> roll 1d20
[20:50] <Kobot> Lisa rolled 1d20 --> [ 1d20=14 ]{14}
As Afina fires her disintegrate, the door to the right shuddering under a blow, "NO ESCAPE!" A horrible voice bellows, the door cracking from the blow.
