Salvation (Everyone)
Started by Anastasia, January 03, 2018, 12:56:45 PM
Jaela has no trouble listening to Afina's warning, Gae Dearg warding off any would-be ethereal attackers from below!
Adrian takes to the air along with Balyss, Sylvie gliding along as...
Okay, give me relative positioning relative to each other here, y'all.
What's that mean exactly?
Afina's like ten feet ahead of everyone else, flying up against the ceiling. Jaela's ten feet behind her with everyone else basically bunched up behind her?
Where you are relative to everyone, Yuth.
Adrian will guard the rear and keep a bit of distance, while Balyss will stay in the middle and Sylvie will stay to the left side.
I was referring the epic skill usage but ok. Tryll & Calleigh are hugging walls, prepared to either blast or dodge into solid rock.
Oh.
From the epic skills writeup I did, relevant part bolded.
Requirements
To use epic skill usages, a character must have 24 or more ranks in the skill. A character who does not have those ranks may be able to achieve the DC of various epic skill usages, but they lack the training and insight to achieve those tasks, regardless of the check. This is meant to keep these usages in epic; while most won't break a higher level game, it's easier to keep them limited to epic than considering non-epic characters who can manage the DCs.
In particular, this was a chance to use the DC 50 epic skill usage to hear ethereal or ghostly creatures, who are normally silent and incapable of being heard moving.
Another post shortly.
Moore will fly up near the ceiling as well, about 25 ft behind Afina!
The party spreads out, and moments later? It is a ghostly black maw, massively large, large enough to swallow several Hannas at once and have room for a few Jaelas on the side. It rips up from the ground and comes out at...
> roll 1d4 1 front 2 mid 3 back 4 miss
<Kobot> Kotono rolled 1d4 1 front 2 mid 3 back 4 miss --> [ 1d4=4 ]{4}
Just behind Adrian, narrowly missing the party! It writhes up and up and up and up, a vast thing going through the ceiling and...
Standard action to react, each of you.
Afina tries to make her action count by going fast!
[17:48] <@Ebiris> roll 1d100 spell failure, 6th level time stop
[17:48] <Kobot> Ebiris rolled 1d100 spell failure, 6th level time stop --> [ 1d100=25 ]{25}
Unfortunately that fails. Sagging slightly she settles for flinging fire at it.
[17:50] <@Ebiris> roll 1d100 spell failure, orb of fire
[17:50] <Kobot> Ebiris rolled 1d100 spell failure, orb of fire --> [ 1d100=74 ]{74}
[17:52] <@Ebiris> roll 1d20+66 ranged touch
[17:52] <Kobot> Ebiris rolled 1d20+66 ranged touch --> [ 1d20=14 ]{80}
[17:52] <@Ebiris> roll 2#1d100 miss chance
[17:52] <Kobot> Ebiris rolled 2#1d100 miss chance --> [ 1d100=77 ]{77}, [ 1d100=42 ]{42}
[17:52] <@Ebiris> roll 26d6 fire damage, ignores resistance/immunity
[17:52] <Kobot> Ebiris rolled 26d6 fire damage, ignores resistance/immunity --> [ 26d6=84 ]{84}
Sadly even though undead aren't immune to dazing, they are immune to anything that requires a fort save and doesn't affect objects.
Afina 383+20/383
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), interplanar telepathic bond (CL 26), strength of dragon princess (CL 28), mind of dragon princess (CL 28), agility of dragon princess (CL 28), endurance of dragon princess (CL 28), beauty of dragon princess (CL 28), magic tattoo (CL 24), magic tattoo (CL 24), magic tattoo (CL 24), energy immunity (sonic) (CL 26), energy immunity (acid) (CL 26), sublime revelry (CL 27), tyche's touch (CL 17), death ward (CL 35), recitation (CL 35), haste (CL 27)
defences: AC 103 (touch 65), spell resistance 42, immunity to fire, water, earth, cold, sonic, acid, disease, poison, fear, mind-affecting, critical hits, negative energy, and death effects, 50% miss chance, freedom of movement, 25% spell failure
spell slots: 5/9/10/3/3/0/8/4/6/1/1/4/2
Moore is a bad person who doesn't have dimensional anchor :(
Gae Dearg is aimed at the creature, and twin bursts of brightest light shoot out at it!
Twinned Bolt of Glory!
[19:52] <@UnacceptableMustard> roll 1d20+34+27
[19:52] <Kobot> UnacceptableMustard rolled 1d20+34+27 --> [ 1d20=19 ]{80}
ranged touch
[19:53] <@UnacceptableMustard> roll 1d100
[19:54] <Kobot> UnacceptableMustard rolled 1d100 --> [ 1d100=69 ]{69}
incorporealness
[19:54] <@UnacceptableMustard> roll 1d20+37 CL
[19:54] <Kobot> UnacceptableMustard rolled 1d20+37 CL --> [ 1d20=9 ]{46}
SR
[19:55] <@UnacceptableMustard> roll 15d12
[19:55] <Kobot> UnacceptableMustard rolled 15d12 --> [ 15d12=57 ]{57}
Twinned, so damage is 114.
Init: +22 (Sign, Grace), CHA +2, CL37
HP: 520+20/520 (+54/54 from EotDP)
AC: 89 =76base+2Foresight+3Recitation+5ShieldOfWarding+1Grace+2AotDP, 20% miss chance
Touch AC: 83 =70base+2+3+5+1+2
Full Attack (Gae Buidhe +7, haste, HW, K:D +5): +51/+51/+46/+41/+36, 1d8+38+3d12 goldenfire
Full Attack (Gae Bolg, GMW, Haste, HW, K:D +5, vs devils only): +53/+53/+48/+43/+38, 4d8+40+11d6 and 1 negative level
Combat: Moore +17 morale attack/damage, Moore +3 attack, Recitation +3 luck/attack, Celestial Valor +4 sacred attack/damage, Divine Might +17 damage: +27 attack, +38 damage
[not used: CMT +2 competence/attack, SotDP +2 attack/+3 damage, Divine Favor +3 luck/damage, Greater Heroism +4 morale/attack, Good Hope +2 morale/damage]
Gae Buidhe: The wielder acts outside of fate and destiny, they are immune to divinations (with the exception of detect good, which always reveals an overwhelming aura of good). Luck and insight bonuses to attack rolls, weapon damage rolls and DCs do not apply against attacks on the wielder, while the same bonuses to armor class and saving throws do not apply against attacks the wielder makes. Additional abilities that explicitly manipulate destiny or use it as a tool also fail (the DM's discretion is used to determine abilities that qualify for this).
Spells Active: Contingency CL36, Permanency/Greater Blindsight CL36, Permanency/Mantle of Good CL37, Shield of Warding CL31, Conviction CL31, Sublime Revelry CL31, Foresight CL31, Moment of Prescience CL29, Invisibility Purge CL34, Righteous Halo CL34, Greater Heroism CL34, Fortunate Fate CL34, Good Hope CL34, Heroes Feast CL20, Mass Death Ward CL35, Vision of the Omniscient Eye CL35, Crown of Flame CL35, Sign CL35, Divine Insight CL35, Lore of the Gods CL35, Mind Blank CL17.
Short Duration Spells: Grace CL34, Celestial Valor CL32, Recitation CL34, Greater Displacement CL29.
Surru Spells: Strength of the Dragon Princess CL 28, Mind of the Dragon Princess CL 28, Agility of the Dragon Princess CL 28, Endurance of the Dragon Princess CL 28, Beauty of the Dragon Princess CL 28, Create Magic Tattoo (+1 CL) CL 24.
Resistances and Immunities: Fire Immunity, Cold Resistance 10, Acid Resistance 20, Electricity Resistance 20, Sonic Resistance 20, Damage Reduction 25/Epic and Evil and Cold Iron, Spell Resistance 37 (49 vs Evil spells/permanent Mantle of Good), Immunity to Disease (normal and supernatural/magical), Immunity to Compulsion effects, Immunity to Petrification, Immunity to Sickened/Nauseated, Immunity to fear and poison/Heroes's Feast, Immunity to dazzled and blinded/Vision of the Omniscient Eye, Never surprised or flat-footed/Foresight, physical damage reduced by half/Sublime Revelry.
Old: Cold Immunity, Acid Immunity, Electricity Immunity, Sonic Immunity; You are immune to poison, sleep, paralysis, and stunning, and are not subject to extra damage from critical hits or flanking/Elemental Body.
Original:
Spells Left (1-9): 10/9/9/7/9/9/8/7/8
Spells Left (10-12): 8/6/4
Current:
Spells Left (1-9): 4/3/4/3/6/6/8/3/6
Spells Left (10-12): 6/0/4
Saves: conviction +5, recitation +3, hidden dawn +7, celestial valor +4 : +19; eotdp fort +2 (2); shield of warding ref +5, foresight ref +2, haste ref +1, grace ref +1, aotdp ref +2 (11).
Saves: Fort +73, Ref +74, Will +71
Gae Bolg: GMW, Keen Edge
Gae Trocaire: GMW, Keen Edge
Gae Buidhe: Keen Edge
Turning Left: 17/20
-Smites x1
-Mountainous Fire summons
-Channeled twinned Bolt of Glory into Gae Buidhe
-Bead of Karma
-True Strike x2
-Time Stop x1
-Spell Turning x1
-Foresight x1
-Moment of Prescience x1
Taking ten for K:A 60 (64), K:N 39 (44), K:R 64 (69), K:P 64 (69), Spellcraft 54 (69)
Hidden Dawn used with Sylvie
Golden Bracers (Hidden Dawn):
Flame Strike at will as an SLA
Sunburst at will as an SLA
Immunity to fire
Save bonuses increase to +7
Goldenfire damage on weapon damage rolls, natural attacks and spells and spell-like abilities with the fire descriptor rises to +6d6, unlimited range as long as on same plane.
Goldenfire Spell [Epic, Exalted]
Prerequisite: Searing Spell, con 25, must worship Lathander or another of the House of Nature
Benefit: A goldenfire spell ignores the immunity and resistance to fire of creatures affected by the spell. Evil creatures take 50% more damage from a goldenfire spell and suffer a -7 penalty to the saving throw, if applicable. The spell gains the good descriptor if it does not already have it. Any spell modified with goldenfire gains a sacrifice component of 1 point of Constitution damage. A goldenfire spell uses up a spell slot 3 levels higher than the spells's actual level.
A bar of light briefly connects Tryll's misty form and that of the maw!
Oh boy oh boy
Twinned Empowered Maximized Celestial Conduit
Cost: 32-3
DC: 40 Ref halves
Effect: 120ft line
Damage: 2(1.5(9+21d6))=540 damage to normal living creatures
2(1.5(9+21d6+60))=720 damage to undead
2(1.5(5+21d6))=468 damage to constructs and inanimate objects
HP: 691+54=745
Spells Active: Mind Blank (CL 15), Fortunate Fate (CL 13), Planar Tolerance (CL 7), Greater Mage Armor (CL 5), True Seeing (CL 32), Inertial Armor (CL 32), Strength of the Dragon Princess (CL 28), Mind of the Dragon Princess (CL 28), Agility of the Dragon Princess (CL 28), Endurance of the Dragon Princess (CL 28), Beauty of the Dragon Princess (CL 28), Create Magic Tattoo (CL 24), Tyche's Touch (CL 17), Recitation (CL 35)
Bonuses: +18 armor to AC (applies to incorporeal touch), Dragon Princess Bonuses, +4 sacred to saves, +2 luck to AC/saves/attack, +1 CL
Resources Used: 217/789, 2 charges of Paragon's Fortune.
HP: 345+54=399
Resources Used: 0/45, Hope, 68/800 Astral Legion Psicrown, 38/50 Wand of Cure Critical, 49/50 Dorje of Entangling Ectoplasm
Waiting on a second post Jaela said was incoming.
