Gar Malleos II (Tryll, Surraruthru)
Started by Anastasia, January 08, 2018, 10:22:29 PM
Again the hooded pit fiend holds up that vile rod, unreal power coming from it to strike down Surraruthru and Balyss.
Ref.
> roll 1d20+40 Ref
<Serith> Iddy roll for Serith < 48 > [d20=8]
+4 via Celestial Valor. Total of 52.
> roll 1d20+41 Balyss Ref
<Serith> Kotono roll for Serith < 45 > [d20=4]
Balyss has evasion and takes none, Surru takes half for 150 damage.
But before that, going to try and counter, either of you?
Sure, I'll try with a Greater Dispel.
> roll 1d20+41 GMD
<Serith> Iddy roll for Serith < 55 > [d20=14]
Additionally, if I used a Reaving Dispel instead, what would the chances of moving the link to myself or someone else be? It's capped at +20, IIRC.
You honestly don't think it can be, Surru.
This time Surraruthru throws his magic out, managing to block and dispel the overwhelming blast. No pain this time...until Harkin lowers his hammer down in a smash again and green light engulfs Simmer.
> roll 1d20+73 Harkin
<Rei-chan> Kotono rolled : 1d20+73 Harkin --> [ 1d20=16 ]{89}
300 damage. Pain.
Simmer is hit dead on and sent flying back, screaming amid the agony and...
Init is Jaela (35) > Ettan (31) > Harkin (30) > Calleigh (27) > Simmer (23) > Surraruthru = Tryll (20) > Balyss (12)
Calleigh.
Simmer
HP: 135/435
Balyss
HP: 416/416
Elemental Body (fire) (CL28), Surraruthru's Stupendous Dragonskin (CL28), Strength of the Dragon Princess (CL28), Mind of the Dragon Princess (CL28), Agility of the Dragon Princess (CL28), Endurance of the Dragon Princess (CL28), Beauty of the Dragon Princess (CL28), Create Magic Tattoo (+1 luck ATK) (CL24), Create Magic Tattoo (+2 comp ATK) (CL24). Create Magic Tattoo (+1 CL/ML) (CL24), Energy Immunity (all elements) (CL26)
Calleigh pulls a wand and blasts Simmer with positive energy! Then she hides in the wall again and moves closer to the center of the group!
Cure Critical[blockquote]Rolled 4d8+10 : 1, 6, 6, 6 + 10, total 29[/blockquote]
HP: 691+54=745
Spells Active: Mind Blank (CL15), Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (fire) (CL28), Surraruthru's Stupendous Dragonskin (CL28), Strength of the Dragon Princess (CL28), Mind of the Dragon Princess (CL28), Agility of the Dragon Princess (CL28), Endurance of the Dragon Princess (CL28), Beauty of the Dragon Princess (CL28), Create Magic Tattoo (+1 luck ATK) (CL24), Create Magic Tattoo (+2 comp ATK) (CL24). Create Magic Tattoo (+1 CL/ML) (CL24), Energy Immunity (all elements) (CL26), True Seeing (CL30), Inertial Armor (CL30)
Bonuses: +4 insight to STR/Dex/CON/Int/CHA, +1 luck to ATK, +2 comp to ATK, +1 CL/ML, Energy Immunity, +1 morale to ATK & Will, Immune to Fear, +18 armor to AC (applies to incorporeal touch)
Resources Used: 167/789, 2 charges of Paragon's Fortune.
HP: 345+54=399+18
Spells Active: Fortunate Fate (CL13), Planar Tolerance (CL7), Greater Mage Armor (CL5), Heroes Feast (CL20), Elemental Body (fire) (CL28), Surraruthru's Stupendous Dragonskin (CL28), Strength of the Dragon Princess (CL28), Mind of the Dragon Princess (CL28), Agility of the Dragon Princess (CL28), Endurance of the Dragon Princess (CL28), Beauty of the Dragon Princess (CL28), Create Magic Tattoo (+1 luck ATK) (CL24), Create Magic Tattoo (+2 comp ATK) (CL24). Create Magic Tattoo (+1 CL/ML) (CL24), Energy Immunity (all elements) (CL26), True Seeing (CL32), Inertial Armor (CL32), Intellect Fortress (CL 32)
Bonuses: +4 insight to STR/Dex/CON/Int/CHA, +1 luck to ATK, +2 comp to ATK, +1 CL/ML, Energy Immunity, +1 morale to ATK & Will, Immune to Fear, +18 armor to AC (applies to incorporeal), 18 temp HP
Resources Used: Hope, 68/800 Astral Legion Psicrown, 38/50 Wand of Cure Critical
Cool, Simmer holds for the moment since ow. Go ahead, Tryll and Surru. Plan dispel is a go?
Assuming it is, make your dispel check while you're here, Cor? I'll factor out the bonuses on my end.
A flick of her wrist restores the vitality of her friends and allies, but Jaela's focus is fully taken by the nefarious spell draining her beloved Lifasa's life!
Quickened Mass Heal for 250hp to everyone, then timed Twinned Superb Dispelling:
[21:04] <@Lisa> roll 1d20+46 Rei
[21:04] <Rei-chan> Lisa rolled : 1d20+46 Rei --> [ 1d20=18 ]{64}
I still have a swift and a move that I'll use after this resolves!
Init: +22 (Sign, Grace), CHA +2, CL31
HP: 520+20/520
AC: 89 =76base+2Foresight+3Recitation+5ShieldOfWarding+1Grace+2AotDP, 20% miss chance
Touch AC: 83 =70base+2+3+5+1+2
Full Attack (Gae Buidhe +7, haste, HW, K:D +5): +51/+51/+46/+41/+36, 1d8+38+3d12 goldenfire
Full Attack (Gae Bolg, GMW, Haste, HW, K:D +5, vs devils only): +53/+53/+48/+43/+38, 4d8+40+11d6 and 1 negative level
Combat: Greater Heroism +4 morale/attack, Good Hope +2 morale/damage, Recitation +3 luck/attack, SotDP +2 attack/+3 damage, CMT +2 competence/attack, Celestial Valor +4 sacred attack/damage, Divine Might +17 damage: +15 attack, +26 damage
Gae Buidhe: The wielder acts outside of fate and destiny, they are immune to divinations (with the exception of detect good, which always reveals an overwhelming aura of good). Luck and insight bonuses to attack rolls, weapon damage rolls and DCs do not apply against attacks on the wielder, while the same bonuses to armor class and saving throws do not apply against attacks the wielder makes. Additional abilities that explicitly manipulate destiny or use it as a tool also fail (the DM's discretion is used to determine abilities that qualify for this).
[not used: Divine Favor +3 luck/damage]
Spells Active: Spell Turning CL26, Contingency CL36, Permanency/Greater Blindsight CL36, Permanency/Mantle of Good CL37, Foresight CL27, Moment of Prescience CL25, Lore of the Gods CL30, Invisibility Purge CL30, Fortunate Fate CL15, Mind Blank CL17, Greater Mage Armor CL7, Planar Tolerance CL7, Heroes Feast CL20, Righteous Halo CL30, Vision of the Omniscient Eye CL30, Greater Heroism CL30, Shield of Warding CL31, Conviction CL31, Crown of Flame CL30, Sign CL30, Divine Insight CL30, Interplanar Telepathic Bond CL26, Sublime Revelry CL31, Mass Death Ward CL30, Good Hope CL30.
Short Duration Spells: Grace CL30, Recitation CL30, Haste CL27, Celestial Valor CL32.
Tryll: Intellect Fortress round 1/5: All savable damage halved so long as SR/PR applies.
Surru Spells: Energy Immunity (Acid, Cold, Sonic, Electricity) CL26, Elemental Body/Fire CL28, *Surraruthru's Stupendous Dragonskin CL 28, Strength of the Dragon Princess CL 28, Mind of the Dragon Princess CL 28, Agility of the Dragon Princess CL 28, Endurance of the Dragon Princess CL 28, Beauty of the Dragon Princess CL 28, *Create Magic Tattoo (+1 Luck to attack) CL 24, Create Magic Tattoo (+2 Competence to attack) CL 24, Create Magic Tattoo (+1 CL) CL 24,
Resistances and Immunities: Fire Immunity, Cold Immunity, Acid Immunity, Electricity Immunity, Sonic Immunity, Damage Reduction 25/Epic and Evil and Cold Iron, Spell Resistance 37 (49 vs Evil spells/permanent Mantle of Good), Immunity to Disease (normal and supernatural/magical), Immunity to Compulsion effects, Immunity to Petrification, Immunity to Sickened/Nauseated, Immunity to fear and poison/Heroes's Feast, Immunity to dazzled and blinded/Vision of the Omniscient Eye, Never surprised or flat-footed/Foresight, physical damage reduced by half/Sublime Revelry. You are immune to poison, sleep, paralysis, and stunning, and are not subject to extra damage from critical hits or flanking/Elemental Body.
Old: Cold Resistance 10, Acid Resistance 20, Electricity Resistance 20, Sonic Resistance 20
Original:
Spells Left (1-9): 10/9/9/7/9/9/8/7/8
Spells Left (10-12): 8/6/4
Current:
Spells Left (1-9): 5/5/5/3/7/8/8/5/6
Spells Left (10-12): 6/0/3
Saves: conviction +5, recitation +3, hidden dawn +7, celestial valor +4 : +19; eotdp fort +2; foresight ref +2, haste ref +1, shield of warding ref +5, grace ref +1, aotdp ref +2.
Saves: Fort +73, Ref +74, Will +71
Gae Bolg: GMW, Keen Edge
Gae Trocaire: GMW, Keen Edge
Turning Left: 17/20
-Smites x1
-Mountainous Fire summons
-Channeled twinned Bolt of Glory into Gae Buidhe
-Bead of Karma
-True Strike x2
-Time Stop x1
-Spell Turning x1
-Foresight x1
-Moment of Prescience x1
Taking ten for K:A 62, K:N 41, K:R 66, K:P 66, Spellcraft 56
Hidden Dawn used with Mirajane
Golden Bracers (Hidden Dawn):
Flame Strike at will as an SLA
Sunburst at will as an SLA
Immunity to fire
Save bonuses increase to +7
Goldenfire damage on weapon damage rolls, natural attacks and spells and spell-like abilities with the fire descriptor rises to +6d6, unlimited range as long as on same plane.
Goldenfire Spell [Epic, Exalted]
Prerequisite: Searing Spell, con 25, must worship Lathander or another of the House of Nature
Benefit: A goldenfire spell ignores the immunity and resistance to fire of creatures affected by the spell. Evil creatures take 50% more damage from a goldenfire spell and suffer a -7 penalty to the saving throw, if applicable. The spell gains the good descriptor if it does not already have it. Any spell modified with goldenfire gains a sacrifice component of 1 point of Constitution damage. A goldenfire spell uses up a spell slot 3 levels higher than the spells's actual level.
Plan Dispel All The Things is indeed go.
Tryll's mind reaches out to disrupt the link in tandem with Surraruthru and Jaela, attempting to strike at the same point in the weave in order to disrupt it.
Manifesting Twinned Dispel Psionics
Dispel checks:
[blockquote]Rolled 1d20+20 : 10 + 20, total 30[/blockquote][blockquote]Rolled 1d20+20 : 3 + 20, total 23[/blockquote]
HP: 691+54=745
Resources Used: 177/789, 2 charges of Paragon's Fortune.
HP: 345+54=399+18
Waiting on Surru then and I'll resolve the whole thing at once.
Surraruthru casts a pair of spells, one strengthening the other!
Spell Enhancer, CL 24.
Next Spell gets +2 CL.
Superb Dispel, CL 34.
> roll 1d20+44 Superb Dispel Serith
<Serith> Iddy roll for Serith < 58 > [d20=14]
Correction: My bonus is +45, so the total is now 59.
Magic shatters. It's the only word for it. Magic shatters - along the ley line, along them. The connection severs with a burst of unmagic, the unmaking of such a potent spell causing a cascade. No, that's not right - a trigger? Something. Whatever it is, it rips through all the magic in the room and...
All spells with a caster level of 30th or lower are dispelled on everyone here. Note the losses. Additionally, each of you need to make a Reflex save here to protect your magical items. Evasion doesn't matter here, it's all or nothing anyway.
Simmer, having been through something like this in her creation as a pyrodryad, gains a +5 circumstance bonus to the saving throw.
Tryll[blockquote]Rolled 1d20+25 : 15 + 25, total 40[/blockquote]Calleigh[blockquote]Rolled 1d20+27 : 13 + 27, total 40[/blockquote]
HP: 691+54=745
Spells Active: True Seeing (CL32), Inertial Armor (CL32), Intellect Fortress (CL 32)
Bonuses: +18 armor to AC (applies to incorporeal touch)
HP: 345+54=399
Bonuses: +18 armor to AC (applies to incorporeal)
