To war once again (Moore)
Started by Anastasia, January 17, 2018, 04:21:53 PM
His first action will be to use his boots of temporal acceleration -- does this yahoo have the trick of being able to move in a time stop, before I do anything else?
Fantastic.
Okay, so I have so far used a Swift action for the round outside of Time Stop.
Time Stop Round 1:
Move: 60 ft.
Standard: Wall of Stone around This Asshole to box him in, creating a cube with the stone walls. He's got 85 ft of wall to work with and each wall is 4 inches thick. He's Basically going to put 4 walls around, 1 on top and repeat that as many times as he has walls for so it'll hopefully buy a turn. Of course the asshole can probably just teleport, but whatever.
Swift: Nothing good to use here since no one can be affected by his songs, so whatever.
Time Stop Round 2: Move next to Mirima.
Standard: Another Wall of Stone on top of / around the first one. Guess who he's borrowing the idea from??
Normal Time:
Standard: Heal Mirima for 150 HP.
Movement: Inspire Greatness.
[13:20] <Nephrite> roll 12d4 nonlethal
[13:20] <Serith> Nephrite roll for Serith < 28 > [d4=1,1,1,2,1,4,3,3,1,4,4,3]
Mirima, Moore and 3 other random nameless people get +8d10 temp hp, +8 Attack rolls, +3 fort.
Time resumes a second  later, healing watching over everyone. A flash of light as you heal, stone entombing your opponent. A flash as Afina and friends appear, the walls shuddering from the inside as battle rages just below and...
Init, everyone.
[13:29] <Nephrite> roll 1d20+40 init
[13:29] <Serith> Nephrite roll for Serith < 45 > [d20=5]
[18:29] <@Ebiris> roll 1d20+32+14
[18:29] <Serith> Ebiris roll for Serith < 66 > [d20=20]
Afina 383+20/383
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 29), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), interplanar telepathic bond (CL 26), strength of dragon princess (CL 28), mind of dragon princess (CL 28), agility of dragon princess (CL 28), endurance of dragon princess (CL 28), beauty of dragon princess (CL 28), magic tattoo (CL 24), magic tattoo (CL 24), magic tattoo (CL 24), energy immunity (sonic) (CL 26), energy immunity (acid) (CL 26), sublime revelry (CL 27)
defences: AC 102 (touch 64), spell resistance 42, immunity to fire, water, earth, cold, sonic, acid, disease, poison, fear, mind-affecting, critical hits, 25% spell failure
spell slots: 6/9/10/7/4/9/9/6/8/7/5/4/3
2 moments of prescience left.
> roll 1d20+21 Dana
<Serith> Kotono roll for Serith < 29 > [d20=8]
> roll 1d20+41 Sylvie
<Serith> Kotono roll for Serith < 49 > [d20=8]
> roll 1d20+25
<Serith> Kotono roll for Serith < 42 > [d20=17]
Init is Afina (66) > Sylvie (49) > Moore (45) > Armored Knight (42) > Dana (29)
Afina and friends, you're 25ft away and just behind the Graceful Blow lines. Afina opens.Note the enemy is currently trapped between many walls of stone by Moore.
Afina attempts to do a time stop!
[18:42] <@Ebiris> roll 1d100 7th level slot time stop spell failure
[18:42] <Serith> Ebiris roll for Serith < 68 > [d100=68]
Which succeeds! She then hastes herself and casts shadow form...
[18:43] <@Ebiris> roll 1d100 haste spell failure
[18:43] <Serith> Ebiris roll for Serith < 80 > [d100=80]
[18:43] <@Ebiris> roll 1d100 shadow form spell failure
[18:43] <Serith> Ebiris roll for Serith < 44 > [d100=44]
Three for three! Where was this focus when she was facing Tiamat? Next she flies into the cube of stone Moore's captured the enemy inside (her eyes are good enough for her to have seen that from Aurora earlier so she's not confused) and creates some fire seeds which she drops by his feet.
SLA for fire seeds so no spell failure. Shadow form lets me phase through walls with my epic escape artist check.
Then as time restarts she stabs him twice in the back of the head before she flies back out of the cube next to Mirima and her holly berry bombs detonate!
He should definitely be flat-footed for this, but if he has uncanny dodge my last d6 is the sneak attack damage.
[18:49] <@Ebiris> roll 1d20+66
[18:49] <Serith> Ebiris roll for Serith < 84 > [d20=18]
[18:49] <@Ebiris> roll 1d20+61
[18:49] <Serith> Ebiris roll for Serith < 75 > [d20=14]
[18:49] <@Ebiris> 8th level arcane strike on those
[18:49] <@Ebiris> Also +4 more from dread weapon
[18:50] <@Ebiris> roll 1d4+31+3d6+3d6+4d6+6d6+2d6+8d4+1d6
[18:50] <Serith> Ebiris roll for Serith < 119 > [d4=4][d6=4,3,2,5,2,2,3,5,5,5,4,1,4,5,3,1,1,5][d4=2,4,2,2,4,4,3,1][d6=2]
[18:50] <Serith> Ebiris roll for Serith < 124 > [d4=3][d6=4,1,5,4,3,3,6,6,2,2,6,1,3,1,6,4,5,5][d4=4,2,2,2,3,4,1,4][d6=1]
[18:50] <@Ebiris> And 2 negative levels per hit
[18:51] <@Ebiris> roll 8d8+216 holly berry DC 36 ref half, fire damage ignores resistance, half vs immune
[18:51] <Serith> Ebiris roll for Serith < 251 > [d8=2,5,4,6,4,4,4,6]
Afina 383+20/383
active spells: glaciante's spiteful ward (CL 29 attached to epic mage armour), heroes feast (CL 20), mind blank (CL 17), fortunate fate (CL 15), planar tolerance (CL 7), epic mage armour (CL 27), many moments of prescience (CL 29), greater heroism (CL 25), afina's perfect vision (CL 27), shield (CL 27), interplanar telepathic bond (CL 26), strength of dragon princess (CL 28), mind of dragon princess (CL 28), agility of dragon princess (CL 28), endurance of dragon princess (CL 28), beauty of dragon princess (CL 28), magic tattoo (CL 24), magic tattoo (CL 24), magic tattoo (CL 24), energy immunity (sonic) (CL 26), energy immunity (acid) (CL 26), sublime revelry (CL 27), haste (CL 27)
defences: AC 103 (touch 65), spell resistance 42, immunity to fire, water, earth, cold, sonic, acid, disease, poison, fear, mind-affecting, critical hits, 25% spell failure, 50% miss chance, freedom of movement
spell slots: 6/9/10/6/4/8/9/5/7/7/5/4/3
Afina blurs into the walls of stone and through them, stabbing at the knight. The first manages to penetrate but the second slides off his armor, as a moment later...
He's pretty restricted thanks to the walls of stone, so -6 circumstance penalty to his Ref saves.
> roll 1d20+41-6
<Serith> Kotono roll for Serith < 47 > [d20=12]
The walls of stone sag, half melting into magma from AFina's intense heat. Within there is...
Sylvie's up, but she'll hold pending Moore. Go Moore.
#129
"Thanks for the assistance!" Moore calls out. His words then inspire everyone around him first before he heals Mirima's wounds a second time!
Inspire Courage, +16 blahblahblah. He's also going to recast Righteous Halo. Mirima seems to be out of danger so he doesn't think he needs to heal her right now. Righteous Halo wasn't borked when he got dispelled, so scratch that. He'll just heal Mirima just to be safe.
"Is he dimensionally anchored in there?" Sylvie asks quickly.
"Nope, I'm honestly surprised he's still in there." Moore responds.
Heal as in a heal spell on her, Moore?
Sylvie will hold pending the knight doing anything and react as needed.
As Mirima's wounds heal and the Graceful Blow battles just below your feet, warfare of all kinds clashing as the devils are pushed back on all sides, being enveloped as the line holds. Then...nothing happens, at least that you can see.
Dana holds. Afina.
