To war once again (Moore)
Started by Anastasia, January 17, 2018, 04:21:53 PM
Lemme reroll the crit then.
> roll 2d8+67+3d6+2d6+1d6
<Serith> Kotono roll for Serith < 89 > [d8=5,4][d6=2,2,3,3,2,1]
HP after that?
Also to speed it along, three Fort saves.
> roll 1d100 vs 1
<Serith> Kotono roll for Serith < 23 > [d100=23]
> roll 1d100 vs 2
<Serith> Kotono roll for Serith < 29 > [d100=29]
No joy on the quilium cloak. Saves, Moore?
[21:44] <Nephrite> roll 3#1d20+60 mettle
[21:44] <Serith> Nephrite roll for Serith < 69, 67, 65 >
I forgot the +2, so that's not included if that matters.
HP is 328
You are stabbed, three blades coming down at once. Yet you endure the blow, grazing your sides and drawing blood, but little more. The injuries feel wrong to , burning hot and icy cold at the same time. The figure looms over you, armor well made but worn, dents and repairs showing the signs of many battles. Then...
Init.
[22:01] <Nephrite> roll 1d20+44 init, beat that you asshole
[22:01] <Serith> Nephrite roll for Serith < 59 > [d20=15]
Mirima gets +16 if she's included.
> roll 1d20+23
<Serith> Kotono roll for Serith < 25 > [d20=2]
Mirima's currently otherwise occupied. Open.
Any K check to identify if this is an Important Person?
The spear rings a bell. The Three-Fold Spear, an artifact from hundreds of thousands of years ago. It was lost in a crusade into Avernus and...oh, you remember now. It was made by Gond, who decided why have a greatspear that hits once when you can have one that hits three times?
The wielder less so, but old dented armor isn't much of a tell, unfortunately.
'I could use some assistance with someone wielding Gond's Three-Fold Spear. I'll be fine for right now, but anyone who can spare themselves, I'm right near Mirima, but she's got her hands full! I'm going to open a gate' Moore sends to anyone listening.
He can't really fight toe-to-toe with someone like this, but...
Would Greater Blink work here at all? I forget the rules on it...
I will just paste the text since I'm sure I'll explain it wrong even if I try to.
This spell functions like blink (PH 206), except that you have control over the timing of your "blinking" back and forth between the Ethereal Plane and the Material Plane. You can also ready an action to blink away from any physical or magical attack. The attack misses automatically unless it also affects ethereal targets (as a force effect does). While blinking, you have no chance of interfering with your own attacks or your own spells. When moving through solid objects, you do not risk materializing inside one unless you actually end your movement there, in which case you materialize and are shunted off to the nearest open space, taking 1d6 points of damage per 5 feet traveled in this manner.
This is the material plane so it would work - unless he can damage ethereal creatures, at which case all bets are off.
